#1 | Link |
L-SMASH Source
Since LSMASHSource came up in the FFmpegSource thread I thought it might be a good idea to have a separate thread for it.
![]() the_weirdo's Dropbox repository contains up-to-date downloads: http://www.dropbox.com/sh/3i81ttxf02...VhYLasmwa?dl=0 and here's the Wiki: http://avisynth.nl/index.php/LSMASHSource From what I gathered LSMASHSource.dll offers: LSMASHVideoSource(string source, int "track", int "threads", int "seek_mode", int "seek_threshold", bool "dr") LSMASHAudioSource(string source, int "track", bool "skip_priming", string "layout") LWLibavVideoSource(string source, int "stream_index", int "threads", bool "cache", int "seek_mode", int "seek_threshold", bool "dr") LWLibavAudioSource(string source, int "stream_index", bool "cache", bool "av_sync", string "layout") see: LSMASHSource.txt that comes with the download Does anyone know what the difference is between LSMASH..Source and LWLibav..Source source is? LWLibavVideoSource is basically a FFmpegSource alternative, which can be used without an index file. (index file will be created if cache is set to true) LSMASHVideoSource is a mp4 source filter. Cu Selur Last edited by Selur; 15th December 2014 at 19:34. |
#2 | Link |
Seems to belong to or part of L-SMASH-Works by "VFR Maniac", see his sig here:
http://forum.doom9.org/showthread.ph...34#post1567834
#4 | Link |
No, clue.
![]() For me so far: advantages
-> test and post if you find more pro's and con's |
#5 | Link | |
Yes, I'm weird.
EDIT: It seems it take less time than FFMS2 to create the index. EDIT (after some more testing): Its index file is much larger than FFMS2's. In case of MKV and MP4 container, it seems frame accurate as FFMS2. Not sure about other containers 'cause I don't have a reference, but in some of my test, it decodes MPEG-TS different from FFMS2.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain Last edited by the_weirdo; 18th March 2013 at 13:46. Reason: My English sucks! |
#8 | Link |
Spinner of yarns
I dislike compressed/encoded format.
Since people can't select which stream by looking the index file. So, I write the index file as human-readable.
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software |
#9 | Link | ||
Yes, I'm weird.
I hope L-SMASHSource will become a good MPEG-TS/PS source filter, too.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain |
#10 | Link |
Spinner of yarns
CODEC specific data (extradata) is written in the index file as well.
This makes more accurate seek possible. For instance, H.264 allows IDR-picture without SPS/PPS. For such IDR-pictures in TS, we can't treat as keyframe (random access point) but libavfomrat returns them as keyframe. So, the result will be broken when the current SPS/PPS in extradata doesn't match (and libavcodec shall not update AVCodecContext.extradata). This case is frequently present in BD m2ts. LWLibavVideoSource can handle correctly this case. About WMV3/VC-1 in ASF, libavformat may not return any PTS even if there is B-picture. LWLibavVideoSource attempts to generate PTS from DTS and picture type by actual __decoding__, and realizes frame accurate seek. So, creating the index file is to be slow. About MPEG-1/2 Video, libavformat might return no PTS for some frames in certain contaniers such as MPEG-PS. LWLibavVideoSource attempts to generate PTS from DTS and picture type, and realizes frame accurate seek. LWLibavVideoSource can handle audio stream of DV-in-AVI Type-I without crash. This format requires seek by special treatment in libavformat.
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software Last edited by VFR maniac; 18th March 2013 at 15:01. |
#11 | Link |
I have a source that I ripped from one of my BDs that is interlaced/TFF VC1 (1080i60) and I get an error: "Detected PTS duplication..." and LWLibavVideoSource(source="...", seek_mode=0) won't open the file. Expected behavior? Bad rip?
#13 | Link |
regarding indexing:
looking at the aui_indexer from rigaya, it is mainly a frontend for the lsmashinput.aui (library), sadly it does not offer any way to choose where the index will be created nor does it offer any progress indication during the indexing. -> so if someone is in contact with rigaya and/or lsmashinput.aui would be nice if adding progress indication and the possibility could be passed on to them as 'feature requests/wishes'. |
#14 | Link | |
Spinner of yarns
Now (@ rev499), I don't throw them but don't display any warning and non-fatal error. At least that message means the file is broken or libavformat TS demuxer is broken for the file, and means the seek may behave inaccurately. Well, I killed that message from LSMASHSource.dll so you can't see that message anymore :P unless I add the error threshold option.
#15 | Link | ||
Spinner of yarns
For frames structured by two separated pictures, LWLibavVideoSource will return correct frame and broken frame by turns. In this case, you can delete broken frames by SelectEven() or SelectOdd(). For progressive frames with pulldown/RFF flag, LWLibavVideoSource can't handle these flags. There is the patches for that, but impossible to apply to the latest repository. https://skydrive.live.com/?cid=8658EC275D9699D5&id=8658EC275D9699D5!236 https://github.com/maki-rxrz/L-SMASH-Works/tree/experimental_repeat_control About whether the index is written accurately or inaccurately, All I can say is that it depends on libavformat!! ![]() Quote:
Progress indication is displayed by another dialog. It can't specify any destination for the index file and the way of displaying progress as long as hitting through AviUtl API.
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software Last edited by VFR maniac; 19th March 2013 at 15:49. |
#16 | Link |
Testing on some old avi files that work fine with FFMpegsource, LwLibAvSource has the couple of flashes of green frames at the beginning, which then throws the video/audio sync out for the rest of the video.
Also, how do you use LsmashVideoSource? Does that only work on raw files or is it meant to open the video streams of Avi, MKV, VOV etc as well? |
#18 | Link |
Spinner of yarns
I don't know your old AVI files.
#20 | Link | |
Spinner of yarns
I build on MinGW32 only. Patches welcome if the compilation fails. BTW as far as I look at your log, it seems your ffmpeg or libav is old. I don't consider about backward compatibility for L-SMASH Works.
