Old 22nd September 2012, 09:59   #1  |  Link
zmejce
How to deinterlace, deblend, denoise & sharpen video with avs script on Vdub?
For deinterlacing I'll probably use LeakKernDeint or Yadif (which one is better-sharper?). Yadif on vdub with default settings does very nice job settings, but maybe LeakKern is better?
For deblending, Srestore.
For denoise & sharpening, MCtepmoral denoise with builtin presets.
Please write a guide or example of how would a avs script look to do this!
The Avisynth filters aren't documented well and I'm not very familiar to them.
zmejce is offline   Reply With Quote
Old 23rd September 2012, 08:13   #2  |  Link
SyntheticEmpathy
1. For deinterlacing try Tdeint. Or even better, try TIVTC without tdecimate if your footage is 29.970fps.
2. Srestore works great .
3. Personally I like to use FFT3DFilter but that's up to the user.
Script would be like:
avisource("Your file")
Tdeint("Choose filed order and deinterlace mode here")
MCtemporaldenoise("Settings corresponding to the instructions")
Someone will give you more detailed instructions if you need more help than the above script.
SyntheticEmpathy is offline   Reply With Quote
Old 23rd September 2012, 15:05   #3  |  Link
zmejce
Yep, I need more detailed instructions.
Whats FFT3D for?
Old 23rd September 2012, 22:03   #4  |  Link
manono
Better would be for you to read the documentation enclosed with each filter, write your own scripts, and then post both the scripts and the error messages you receive (if any) when opening them in VDub. You'll learn much more that way.
Old 24th September 2012, 00:25   #5  |  Link
manono, I tried that approach. He's not willing to read anything or learn anything. He thinks there is a single magic script for every type of video and he wants you to give it to him.
For example, see here:
http://forum.doom9.org/showthread.php?t=165825
That's just one. It seems every time I take the time to try to help him he just disappears from the thread. Trolling?
Old 24th September 2012, 00:51   #6  |  Link
manono
Hehe, maybe I should investigate a poster's past history before offering advice.
Old 24th September 2012, 00:56   #7  |  Link
Especially advice he's already rejected.
Old 25th September 2012, 13:37   #8  |  Link
zmejce
neuron2, yes, Im familiar with vdub and things but I wrote that I'm not familiar with avisynth and its filters.
Old 25th September 2012, 13:53   #9  |  Link
Groucho2004
Groucho2004's Avatar
That can be remedied by reading the documentation and the many, many threads here on the subject. Also:
Not true. Finally:
Would you like fries with that?
avisynth, deblend, deinterlace, denoise, sharpen
