Old 21st September 2012, 10:05   #1  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
vsavsreader -- AviSynth script reader for VapourSynth
I wrote a VapourSynth plugin a few days ago.
This plugin works as a source filter on VapourSynth.
you will be able to use avisynth filters which does not exist yet for VS(e.g. DirectShowSource) and has some compatibility issue like ColorMatrix() with this plugin.
vsavsreader-1.0.0.zip
requirement:
VapourSynth-r30 or later
AviSYnth2.6/avisynth+
Microsoft Visual C++ 2015 Redistributable Packages
my repositories
Chikuzen is offline   Reply With Quote
Old 23rd September 2012, 10:41   #2  |  Link
tebasuna51
tebasuna51's Avatar
I get this error when load the plugin:
Traceback (most recent call last):
File "Version.py", line 6, in <module>
c.avs.LoadPlugin(path=r'C:\Temp\Python\plugins\vsavsreader.dll')
File "vapoursynth.pyx", line 741, in vapoursynth.Function.__call__ (src/cython\vapoursynth.c:10611)
vapoursynth.Error: 'Avisynth Loader: no entry point found'
Same error with vsavsreader.dll in same folder and:
c.avs.LoadPlugin('vsavsreader.dll')
VS r8
AviSynth 2.6.0a3
XP SP3
Old 23rd September 2012, 18:09   #3  |  Link
tebasuna51
tebasuna51's Avatar
Thanks. My mistake.
I copied other LoadPlugin without see the Readme.txt.
Old 27th September 2012, 13:41   #4  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
updated for VS-r9
see first post.
my repositories
Old 28th September 2012, 01:09   #5  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I looked at the source and spotted this small problem:
****vsapi->propSetInt(props, "_DurationNum", ah->avs_vi->fps_denominator * n, 0);
Should be
****vsapi->propSetInt(props, "_DurationNum", ah->avs_vi->fps_denominator, 0);
Myrsloik is offline   Reply With Quote
Old 28th September 2012, 07:20   #6  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
fixed.
my repositories
Old 1st October 2012, 12:24   #7  |  Link
Reel.Deel
Hi Chikuzen, thanks for this usefull plugin.
Since there are some plugins/scripts that can work with dither's lsb in/out.
I was wondering if would it be possible to add a function that can merge msb/lsb into a compatible YUVxxxP16 format?
Old 1st October 2012, 12:42   #8  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Originally Posted by HolyWu View Post
The clips loaded by vsavsreader could not be spliced.
I think that this is a VS's bug.
from vsstdlib.c
static int findCommonVi(const VSNodeRef **nodes, int num, VSVideoInfo *outvi, int ignorelength, const VSAPI *vsapi) {
    int mismatch = 0;
    int i;
    const VSVideoInfo *vi;
    *outvi = *vsapi->getVideoInfo(nodes[0]);
    for (i = 1; i < num; i++) {
        vi = vsapi->getVideoInfo(nodes[i]);
        if (outvi->width != vi->width || outvi->height != vi->height) {
            outvi->width = 0;
            outvi->height = 0;
            mismatch = 1;
        if (outvi->format != vi->format) {
            outvi->format = 0;
            mismatch = 1;
        if ((outvi->numFrames < vi->numFrames && outvi->numFrames) || (!vi->numFrames && outvi->numFrames)) {
            outvi->numFrames = vi->numFrames;
            if (!ignorelength)
                mismatch = 1;
    return mismatch;
Neither ”!=” nor "==" is used for comparison of two structs.
my repositories
Old 1st October 2012, 12:44   #9  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
use dither interleaved format.
stacked format is not supported.
clip = core.avsr.Import('foo.avs', bitdepth=16)
my repositories
Old 1st October 2012, 12:49   #10  |  Link
Myrsloik
Myrsloik's Avatar
You're probably on to something in there but that comparison is legal. It's pointer to struct,not struct.
Old 1st October 2012, 12:58   #11  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Then, is pointing out the same address right as for format of node[0] and format of node[1] ?
my repositories
Old 1st October 2012, 13:03   #12  |  Link
Myrsloik
Myrsloik's Avatar
I found the problem. You're never supposed to create a format struct yourself, you query it from the core.
format->id = table[i].id;
    strcpy(format->name, table[i].name);
    format->colorFamily = table[i].color_family;
    format->bitsPerSample = ah->bitdepth;
    format->bytesPerSample = (ah->bitdepth + 7) / 8;
    format->subSamplingW = table[i].subsample_w;
    format->subSamplingH = table[i].subsample_h;
    format->numPlanes = avs_is_y8(ah->avs_vi) ? 1 : 3;
    return format;
should simply be:
return vsapi->getFormatPreset(table[i].id, core);
The whole function set_vs_format() function can also be simplified to one call to vsapi->registerFormat()
something like:
return registerFormat(cmYuv/cmRgb/cmGray, stInteger, bitsPerSample, subSamplingW, subSamplingH, core);
If you register a duplicate a pointer to the already registered format struct will be returned. => the same format always has the same pointer so the comparison I make is valid.
Old 1st October 2012, 13:13   #13  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
ok, I understood.
Since this plugin was written when the source code had not been opened yet, I was not using vsapi in the place which needs it.
my repositories
Old 1st October 2012, 13:21   #14  |  Link
Reel.Deel
Did not know I could do that. Thanks Chikuzen.
* Edit *
Maybe it's not such a bad idea to add that information to the readme.
Old 1st October 2012, 14:10   #15  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
fixed Splice issue.
please download fixed version from the link of first post.
I appreciate advice of Myrsloik.
my repositories
Old 1st October 2012, 17:43   #16  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
I'm not good at english to write such complicated descriptions.
If you write them, I'll add them into the readme.
my repositories
Old 2nd October 2012, 13:05   #17  |  Link
Reel.Deel
Sounds like a deal. I'll put something together in the next couple of days.
I wish my Japanese were half as good as your English.
* Edit *
Here's the description I wrote on how to import Dither's msb/lsb format into Vapoursynth.
I'm not an expert so I hope it makes sense.
VsAvsReader is able to convert Dither's interleaved MSB/LSB format into a compatible Vapoursynth YUV4xxP9/10/16 format.
Dither's MSB/LSB must be interleaved, stacked format is not supported.
Only YUV planar formats are allowed.
example 1: Use VsAvsReader's Import function to load external Avisynth script.
Vapoursynth script
	# Core
	import vapoursynth as vs
	core = vs.Core(accept_lowercase=True)
	# Import plugins
	core.std.LoadPlugin('C:/vsavsreader.dll')
	# Use "Import" to load interleaved MSB/LSB Avisynth script.
	clip = core.avsr.Import('C:/script.avs', bitdepth=16)
External Avsiynth script being imported.
        # script.avs
	LoadPlugin("C:/plugins/DGDecode.dll")
	LoadPlugin("C:/plugins/Dither.dll")
	Import("C:/scriptss/Dither.avsi")
	MPEG2Source("D:/source.d2v")
	Dither_convert_8_to_16()
	Dither_resize16(1280, 720)
	Dither_convey_yuv4xxp16_on_yvxx()
_____________________________________________________________________
Example 2: Use VsAvsReader's Eval function to create Avisynth script inside a Vapoursynth script.
Vapoursynth script
	# Core
	# Import plugins
	# Use "Eval" to create interleaved MSB/LSB Avisynth script.
	lines = '''
	video = core.avsr.Eval(lines=lines, bitdepth=16)
Old 5th October 2012, 05:58   #18  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
@Reel.Deel
added
my repositories
Old 6th October 2012, 13:21   #19  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
update
vsavsreader-d219012.7z
* change RGB plane order from G->B->R to R->G->B.
my repositories
Old 16th November 2012, 02:30   #20  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
update
download it from the link of first post.
* support alpha channel
If input avs is RGB32, alpha will be stored in "_Alpha" prop.
my repositories
