Old 12th September 2012, 05:40   #1  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic - BE Win32/x64
Media Player Classic - BE is a free and open source audio and video player for Windows.
MPC-BE is based on the original "Media Player Classic" project (Gabest) and "Media Player Classic Home Cinema" project (Casimir666), contains additional features and bug fixes.
Supported Operating Systems:
* Windows Vista, Windows 7, Windows 8 32bit/64bit, Windows 8.1 32bit/64bit, Windows 10 32bit/64bit, Windows 11 64bit
System Requirements:
* An SSE2 capable CPU. (Starting from version 1.5.1 build 2631 beta a CPU with SSE2 is required.)
* The latest DirectX 9.0c runtime (June 2010). Install it regardless of the operating system, they all need it.
DirectX End-User Runtime Web Installer
Links:
Project Page
Changes in release 1.6.6:
MPCStreamReader
Added support for URL redirection for HLS.
Improved work with some broadcasts.
AudioSplitter
Fixed playback of initial samples of FLAC files.
MpaDecFilter
Fixed decoding of some TrueHD streams.
Improved support for bitstreaming when changing device.
FLVSplitter
Improved HEVC video support.
MpegSplitter
Fixed time navigation for 3D Blu-ray.
Added option "Support 3D MVC Extension".
MPCVideoDec
Fixed decoding of some MPEG-4 ASP.
MpcAudioRenderer
Fixed audio dropout when changing speed at the end of playback.
VideoRenderers
Refactoring and optimization.
EVR-CP can now be used as a preview renderer.
Fixed output of some Stereo 3D subtitles for EVR-CP.
Added ability to convert Stereo3D from Half OverUnder to Interlace for MPC Video Renderer 0.6.4.1986 (393835e) or newer.
An experimental MPCVRFullscreenControl option is now available from the player interface.
Subtitles
Improved parsing of polygon parameters in SSA/ASS subtitles.
Minor rendering optimizations for PGS/DVB subtitles.
Fixed player crash on some corrupted subtitles.
YouTube
Significantly increased the speed of saving videos from YouTube.
Significantly increased the speed of the built-in Source Filters with YouTube.
Player
Added option to select preview renderer.
Fixed placement of a vertically stretched frame in the preview window.
Additional tracks will no longer appear in the list of recent Windows files.
Reduced the chance of false positives when moving a window by the video area.
Added saving the current position after a 5 second pause.
Added the ability to change the maximum number of entries in the history.
Various interface fixes.
Installer
Added the ability to install "MPC Video Renderer 0.6.5".
Updated Korean translation (by Potmarigold and Hackjjang).
Updated Italian translation (by mapi68).
Updated Hungarian translation (by mickey).
Updated Chinese (Simplified) translation (by wushantao).
Updated Turkish translation (by cmhrky).
Updated German translation (by Klaus1189).
Updated Dutch and Chinese (Traditional) translation (by beter).
Updated Spanish translation (by IPeluchito).
Updated libraries:
dav1d git-1.0.0-112-g77b3955;
ffmpeg git-n5.2-dev-2245-gab8cde6efa;
Little-CMS git-lcms2.14-44-ge71aeb6;
MediaInfo git-v22.12-17-gaa0dc68a2;
nanosvg git-9da543e
Media Player Classic - BE 1.6.6 x64 (Stable release):
Media Player Classic - BE 1.6.6 x64 (with installer)
Media Player Classic - BE 1.6.6 x64 (portable)
Standalone Filters Media Player Classic - BE 1.6.6 x64
Media Player Classic - BE 1.6.6 Win32 (Stable release):
Media Player Classic - BE 1.6.6 x86 (with installer)
Media Player Classic - BE 1.6.6 x86 (portable)
Standalone Filters Media Player Classic - BE 1.6.6 x86
Nightly Builds:
Nightly Builds
Report a problem.
Frequently Asked Questions about the GNU Licenses
alexins is offline   Reply With Quote
Old 12th September 2012, 06:20   #2  |  Link
Hypernova
At long last! I saw the "leak" has the seekbar preview. Gotta try this right away.
Edit: Request: Can you make the filename's font inside the seekbar respect cleartype setting?
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10.
Hypernova is offline   Reply With Quote
Old 12th September 2012, 10:12   #3  |  Link
cyberbeing
Broadband Junkie
Unchecking "Auto-load Subtitles" doesn't disable the internal subtitle renderer or gray out the Subtitles context menu during playback.
Unchecking "Enable built-in audio switcher filter" and restarting MPC-BE doesn't gray out the Audio context menu during playback.
Old 12th September 2012, 11:25   #4  |  Link
Aleksoid1978
Aleksoid1978's Avatar
"Auto-load Subtitles" - it's for auto-load external subtitle.
"Enable built-in audio switcher filter" & Audio Context Menu - they are different things, they have nothing in common.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 12th September 2012, 11:41   #5  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by alexins View Post
MPC-BE
Very
Many
filler56789 is offline   Reply With Quote
Old 12th September 2012, 11:59   #6  |  Link
cyberbeing
Broadband Junkie
So you're saying those are intentional changes you've made to MPC-BE compared to MPC-HC?
I don't care so much about Audio menu, but there should be a way to completely disable the internal subtitle renderer from loading any subtitles, which also prevents it from being enabled via context menus or hotkeys during playback. In MPC-HC the "Auto-load subtitles" check-box has that function, but it doesn't seem to have been replaced anywhere in MPC-BE.
Old 12th September 2012, 12:19   #7  |  Link
Aleksoid1978
I don't care how it's work in MPC-HC. But - it's work in MPC-BE. If you uncheck "Auto-load subtitle" - there is no Menu with subtitle list. In popup menu you can show only sub-menu with Subtitle Options.
Old 12th September 2012, 12:32   #8  |  Link
cyberbeing
Broadband Junkie
The problem is that having the Subtitle menu accessible when it's non-functional will lead to confusion when VSFilter or some other subtitle filter is used.
Old 12th September 2012, 13:39   #9  |  Link
Aleksoid1978
No. It's sub-menu does not interfere VSFilter or other subtitle filter.
Old 12th September 2012, 14:29   #10  |  Link
fairchild
Thanks, will give this a go and report any problems that I experience if any.
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 12th September 2012, 15:57   #11  |  Link
wanezhiling
http://i.imgur.com/QEu3s.png
http://i.imgur.com/tpzgY.png
Where is ** ?
Old 12th September 2012, 18:01   #12  |  Link
clsid
Why isn't there a public source repository so we can view individual changes?
Is there a list of changes and bugfixes compared to MPC-HC?
MPC-HC 2.0.0
Old 12th September 2012, 18:24   #13  |  Link
ney2x
I'm glad there's an official thread here for MPC-BE. I already switched player from MPC-HC to MPC-BE. I like the icons / GUI very much! I hope you replace the default Subtitle Filter to xy-VSFilter. Thanks!
ney2x is offline   Reply With Quote
Old 12th September 2012, 18:50   #14  |  Link
alexins
MPC-BE DEV
alexins's Avatar
The next three months, the source repository is not available for free access. After a time, we may make the transition from a closed cycle development to the open.
Personally for you, I can grant access because you always acted like a gentleman.
At the present moment, the ChangeLog is available in Russian language only.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
Old 12th September 2012, 19:00   #15  |  Link
alexins
MPC-BE DEV
alexins's Avatar
At the current stage of development, it is not included in our top-priority tasks. Maybe later...
Old 12th September 2012, 21:27   #16  |  Link
turbojet
Thanks for this, I really like that it's darker, less distracting then the old BE mod and putting the time counter on the status bar is a great idea.
One issue is preventing me from switching to it from BE 4360 is save window size and/or position is unreliable, works maybe 50% of the time. I like to watch in full window mode but half the time it's opening as a window with the same resolution of the video. Any chance for a fix?
Also a few requests:
- Use a wider font or bold for time so it's easier to read.
- Option to auto hide title bar, Splayer has this, and while frame only with no borders has some effect, it breaks save window size/position on old be mod and it's also nice to have access to the title bar on demand.
- Option to hide toolbars in window mode, could work just like fullscreen mode hiding.
Old 12th September 2012, 22:41   #17  |  Link
cyberbeing
Broadband Junkie
That doesn't make it any less confusing to users.
Old 13th September 2012, 00:40   #18  |  Link
Aleksoid1978
Why did you decide that we have SVN?
We upload to public source code for project.
Old 13th September 2012, 02:32   #19  |  Link
Superb
Well, it does say "SVN Build: 1122" in the About window... :P
EDIT:
- Love the seekbar preview feature. Nice touch there! But "Use the preview in the search"? How about something like "Show video preview on the seekbar" (or something similar)?
- MPC-HC's "Output" settings tab looks better.
- Any chance for a "Lite" version?
- Any chance to change the default subtitle rendering resolution to "Desktop"?
- Why doesn't the window auto-resizes to the video's resolution when you open a file? Changed defaults? How do I make it act like it did in MPC-HC?
- Program's icon looks great.
- "Logo" settings tab can be removed IMO.
Superb is offline   Reply With Quote
Old 13th September 2012, 04:14   #20  |  Link
Aleksoid1978
There is no Lite version be.
