#1 | Link |
![]() Join Date: Jan 2006
Google "Next Generation Open Video" information posted
I attended Google's "Next Generation Open Video" summit back in July. They've now posted links to the presentations from that.
• NGOV Product Requirements (M. Frost / J. Luther, 68kB PDF)The two HTML5 links aren't working correctly for me. There's plenty of interesting ideas in there. I do think that they need to clearly define Levels, which wasn't then on their roadmap.
Ben Waggoner Principal Video Specialist, Amazon Instant Video My Compression Book |
#2 | Link | |
#3 | Link |
"Reduce video bitrate by 50% with image quality comparable to VP8 (SSIM, PSNR)."
This to me says they aren't looking to increase the video quality just reduce the bandwidth? 50% lower bandwidth than webm isn't as good as hevc is in quality terms. Google should just joing forces with mozilla and xiph and help with Daala video codec development. It says that NGOV must work on core i5 processors that are out in Q3 2013, so presumably NGOV won't be out atleast until then. Last edited by hajj_3; 6th September 2012 at 12:21. |
#5 | Link | |
I had the odd realization that I'd been working with the TrueMotion/VPx codecs and their developers for years longer than anyone currently working on the project! The last guy who was at Duck when I had my first business meeting with them left four years ago...
#7 | Link |
Posts: n/a
Apparently when On2 was bought, Google made sure to bring along their marketeers as well. It is laughable that they still try to claim VP8 is superior to H.264. As was noted when VP8 first came out, they basically gimped the output to make VP8 look better and then threw in a bunch of fancy looking graphs to "prove" how great it was.
#8 | Link | |
The current VP8 encoders are very much tuned for PSNR; althogh I think they have implemented an SSIM tuning mode recently. I wouldn't at all be surprised if when looking for the bitrate that gives the same PSNR between a typical x264 setting and a typical VP8 setting, VP8 would need a somewhat lower bitrate. However, I don't find that a particularly interesting comparison. The Google people certainly spoke about the importance of tuning for perceptual quality, not just PSNR and SSIM. But at that point in NGOV codec work, it didn't sound like they'd done that much perceptual tuning yet. Which isn't unreasonable at an early stage of codec development; I doubt that much percuptual tuning has been done for HEVC implementations yet either.
#11 | Link | |
Not what I could have hand-tuned on my own with a lot more CPU cycles, but their business is going to care a lot about picojoules per pixel!
#12 | Link |
Posts: n/a
While they may not have intentionally done so, the output still looked worse, yes even with high quality source, than anything I was able to do locally. This wasn't using some command string where I turned every knob thinking I was doing something magical, but simply just using the --preset and --tune system. Google could also easily afford to use more CPU cycles than I can.
#13 | Link |
Ah but how would Google decide which --tune to use? Also while they could afford it each CPU cycle costs money which they could be keeping, and remember they are encoding really a lot of video.
#14 | Link |
Posts: n/a
They don't need to. Just use the fast decode tune like I was.
Sure, but I was using the faster presets. If I was comparing their output versus using veryslow then sure that would be an absurd comparison. Considering the immense amount of capacity they have they could easily afford to use slower presets than I did especially with the clip length limits of 15 minutes and the fact that most clips are far shorter than that. Last edited by SassBot; 11th September 2012 at 20:47. |
#15 | Link |
/人 ◕ ‿‿ ◕ 人\
Looks like they messed up some graphs.
E.g. youtube doesn't use WebM for 480p. Also checked 10 random popular videos - for 360p resoultion youtube used 16-18% higher bitrate for WebM in all of them. And from 2 to hilarious 121% for 720p. Lol. And what about vimeo? What magic are they using, so their encoding is so much better? Last edited by vivan; 11th September 2012 at 21:18. |
#16 | Link |
The speed of stupid
Well too bad they absolutely insist on recoding every single x264 video so that it looks absolutely stunning.
Or well, You go compare the youtube version to the Original video. Of course I was very generous with bitrate on this one, but it's not like I can't get a fine looking video at half the size. (Merely, it's because I actually wanted to try and avoid argh quality on Youtube.) |
#17 | Link |
VP-Next renamed to VP9, update on current progress
There is an updated (2012-11-04) document about VP-Next: Overview of VP-Next - Objectives & Progress. This is the Google presentation for the first video-codec IETF working group (2012-11-05).
Also, on the libvpx experimental git branch, VP-Next was definitively renamed to VP9. The last slide of the PDF has current status: Last edited by oibaf; 24th November 2012 at 07:11. Reason: fix double image |
#18 | Link |
I mean why compare a Company Backed Resources Heavy Tuned Encoder to a Video Standard Codec's Reference Encoder? I bet x264 would have beaten the HEVC reference encoder as well.
Heck, when H.264 first came out it didn't even touch xvid in terms of quality. This whole thing is still very On2. Very unlike Google. Not that i like Google at all but i would have thought there will be less BS and more Engineering. |
#19 | Link |
There are two new branches on libvpx git: vp9-preview and pcs-2013 (this last one seems a showcase for Picture Coding Symposium 2013?).
#20 | Link |
Swallowed in the Sea
Wanna test VP9 compressor ?
In addition, Chromium has added VP9 support few days ago, including Opus as Audio Codec...
| Tags |
| google, ngov, vp8, vp9, vpx, webm |
| Display Modes | |
