Old 23rd July 2012, 17:39   #21  |  Link
kingtmx
I think he should use "--preset magic" to sqeeze 2.5 hours @720p into < 1G.
were is this preset were can i get it
kingtmx is offline   Reply With Quote
Old 23rd July 2012, 17:40   #22  |  Link
kingtmx
Why do you need a profile? Just use --preset veryslow and --tune film.
thats it uh ????
Old 23rd July 2012, 17:41   #23  |  Link
SassBot
Posts: n/a
I think you missed that the post was being sarcastic.
thats it uh ????
Yes. What else did you need?
Old 23rd July 2012, 17:44   #24  |  Link
kingtmx
ok no avscripts need uh ???
Old 23rd July 2012, 17:47   #25  |  Link
SassBot
Posts: n/a
Without knowing anything about your source I have no clue what avisynth scipt you would need other than it having a source filter. There is no universal avisynth script that you can apply to all movies.
Old 23rd July 2012, 17:50   #26  |  Link
kingtmx
thats fine can u tell some best denosing filters names
Old 23rd July 2012, 17:54   #27  |  Link
kingtmx
Old 23rd July 2012, 17:57   #28  |  Link
SassBot
Posts: n/a
It's probably best to ask in the AVISynth forum.
Old 23rd July 2012, 17:59   #29  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
"Best" does not exists...
Old 24th July 2012, 09:01   #30  |  Link
Ghitulescu
Ghitulescu's Avatar
Some people are still living in XVID era Who these days encode to 700MB ??? No. WHO THESE DAYS STORES MOVIES ON CD when we have big portable usb hard-drives?
so why magic 700mb then ????
Maybe because these are the new standards (700 MB for 720p and 400 MB for DVDs)
Born in the USB (not USA)
Old 24th July 2012, 09:49   #31  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Well I try to make that too and my conclusion is that 700 MB is really too low size for 720p movie in general case.
Actually optimal quality/size with actual codec is:
- 720x400, 848x480 or 1024x576 for "1CD"
- 1280x720 for "2CD"
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 24th July 2012, 10:39   #32  |  Link
Atak_Snajpera
It all depends of movie's duration , aspect ratio and movie complexity (more talking heads ,less action).
700MB might be enough only for very static and short movie (less than 90min) in 1280x532 resolution.
@Ghitulescu
LOL. I wonder what does [Team DS] stand for? Team Dark Shikari ?
Old 24th July 2012, 13:14   #33  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
@Ghitulescu
general case is for [low-complex] interval ... ;-)
Old 24th July 2012, 15:23   #34  |  Link
kingtmx
yes yes
Old 24th July 2012, 15:26   #35  |  Link
SassBot
Posts: n/a
yes yes
Once again you are missing the fact that someone was being sarcastic...
Old 24th July 2012, 17:04   #36  |  Link
Groucho2004
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
Groucho2004's Avatar
yes yes
Ah, you're bound to the "scene" standards. I wonder why...
Old 24th July 2012, 18:55   #37  |  Link
kalehrl
I think the "scene rules" are very good for beginners to learn about encoding not only using h264 but xvid as well.
There are many reasonable rules to be found there contained in a single text file.
kalehrl is offline   Reply With Quote
Old 24th July 2012, 19:12   #38  |  Link
turab
You mean like what file size or bitrate is acceptable or good enough? I disagree. Not only do these things depend on the source, but the viewer as well. I personally don't understand why anyone would aim for 700MiB with a 720p full-length movie because it looks horrible to me, or why 5mbps seems to be another popular choice because half of that is usually more than enough to my eyes. It really isn't difficult to do your own tests and come to a conclusion yourself.
turab is offline   Reply With Quote
Old 24th July 2012, 19:33   #39  |  Link
SassBot
Posts: n/a
No, they are pretty terrible rules and often lead people to using bizarre commandline options with x264 that make little to no sense.
Old 24th July 2012, 19:48   #40  |  Link
Atak_Snajpera
i would be more happy if those pseudo scene experts just start using default x264 settings (--cfr 23 --preset medium) than 2pass with some odd settings
how to
