Old 23rd June 2012, 21:18   #1  |  Link
lansing
how to fix this 50i to 60i field blended problem?
normally i would just let it be, but this one is so noticeable that i wanted to get rid of. I know there's a few of deblend filters out there but i don't know which one to use.
sample in here:
http://www.mediafire.com/?hn9hag9cw3gikag
Old 24th June 2012, 06:43   #2  |  Link
manono
It seems to be 12.5 fps (to me). To get 25fps use:
Yadif(Order=1,Mode=1)#or your favorite bobber
SRestore(Frate=25)
Old 25th June 2012, 01:20   #3  |  Link
lansing
default srestore setting doesn't seems to work well, what are the parameters for better detection?
Old 25th June 2012, 01:40   #4  |  Link
manono
Worked for me with your sample. Did you set the field order correctly? Without me doing that with your sample (using just Yadif(Mode=1)), I got back blends and missing frames.
Old 25th June 2012, 02:10   #5  |  Link
lansing
what i mean is something like this:
there're still so many blending frame during the dance.
Old 25th June 2012, 06:23   #6  |  Link
manono
I don't see any blends, just a crummy source.
Old 27th June 2012, 01:53   #7  |  Link
lansing
Ok, thanks, I will stick with the srestore then.
50i, 60i, fieldblended, vhs
