Old 19th June 2012, 20:07   #1  |  Link
dadix
"Reverse engineering x264" program for video restoration
I think it could be built like this:
Just like for x264 encoding using different parameters to obtain high quality compression, this "reverse enginereeng" software must to have possibility for the user to enter various parameters in command line to be able to obtain as a result a source as close to an original .
Please tell me what you think about that
(I have a name for this program : RevX264 )
dadix is offline
Old 19th June 2012, 20:56   #2  |  Link
Asmodian
I don't understand what you mean.
What is being reverse engineered?
Asmodian is offline
Old 19th June 2012, 21:47   #3  |  Link
turab
Sounds like he wants to design a filter that tries to improve video quality, similar to a deblocking filter.
turab is offline
Old 20th June 2012, 09:01   #4  |  Link
Ghitulescu
Ghitulescu's Avatar
He wants something similar to obtaining the original WAV from an MP3 ("unRAR") in video domain.
Born in the USB (not USA)
Ghitulescu is offline
Old 20th June 2012, 09:04   #5  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
This makes no sense, and is rather silly.
Blue_MiSfit is offline
Old 20th June 2012, 09:33   #6  |  Link
dadix
Yes, something like that and i think is possible to "unrar" or "RevX264" to rebuild a source from a mkv (with x264 encoding or somthing else) but must to do reverse enginereeng for this compressed video.
dadix is offline
Old 20th June 2012, 09:39   #7  |  Link
Bloax
The speed of stupid
Bloax's Avatar
I thought "lossy" meant data loss, as in there's no way you're getting that data back.
Bloax is offline
Old 20th June 2012, 10:03   #8  |  Link
Groucho2004
Try to reverse-engineer the dinner you had last night from the dump you took this morning.
Groucho2004 is offline
Old 20th June 2012, 10:35   #9  |  Link
dadix
I think is just a reconstraction of movement , colors ... This things (Data video compression) have mathematical equations in the background not some mystical things or prayers.
If you know the result is 7 (compressed video with x264) and is obtained with x-3 (this is x264 encoding) with reverse enginereeng must to obtain original files x.
Why something like that may not be possible ?
dadix is offline
Old 20th June 2012, 11:25   #10  |  Link
Groucho2004
Which part of lossy don't you understand? Have a look here.
Old 20th June 2012, 14:03   #11  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
This program already exists; it's called a video decoder
Dark Shikari is offline
Old 20th June 2012, 15:45   #12  |  Link
dadix
I was afraid that someone will say that
dadix is offline
Old 20th June 2012, 16:38   #13  |  Link
Here's an analogy. I have two numbers A and B. I give you only the average (A+B)/2. No matter hard hard you want it, and no matter how hard you try, you cannot recover A and B using any algorithm. (You can try making an astronomically unlikely guess, however.)
Guest is offline
Old 21st June 2012, 06:29   #14  |  Link
bxyhxyh
@dadix
If you genius for avisynth, write a script to remove all kind of mosaic from all kind of videos.
If you can, that's not problem and you don't need any other program
But i'm afraid that is not possible.
bxyhxyh is offline
Old 21st June 2012, 08:12   #15  |  Link
Ghitulescu
Ghitulescu's Avatar
You don't wanna know what google displayed when I searched for RevX264
Old 21st June 2012, 12:50   #16  |  Link
dadix
I think the decoder function is limited and refers to entropy data. Reverse engineering go beyound that , to another level, and takes care of handling the coefficients to obtain spatial model and then getting forward to handling and obtain temporal model from residual data
dadix is offline
Old 21st June 2012, 13:36   #17  |  Link
Groucho2004
I think the decoder function is limited and refers to entropy data. Reverse engeneering go beyound that and takes care of handling the coefficients to obtain spatial model and then getting forward to handling and obtain temporal model from residual data.
Yes, some successful attempts have already been made with images. See here.
Old 21st June 2012, 14:24   #18  |  Link
dadix
Originally Posted by bxyhxyh View Post
@dadix
How about this? Maybe you implement this ?
http://www.cse.msu.edu/biometrics/Pu...35fenhance.pdf
I put this information because i think the ideas and formulas from this document can be adapted for vectors in reverse engineering technique for missing blocks and adding details.
dadix is offline
Old 21st June 2012, 14:47   #19  |  Link
Stay on topic guys, or the thread will be closed.
Guest is offline
Old 21st June 2012, 16:07   #20  |  Link
Bloax
The speed of stupid
Bloax's Avatar
Well, I'd be interested in seeing what you'll get out - if you're going to achieve any results. (I doubt you'd release anything if you didn't, which is why I state this for some reason. ;p)
But as you've seen, we're all pretty sceptical on whether that's even possible.
If you're determined on trying - however, please go ahead! (Trying has never hurt, has it now. :-))
Bloax is offline
restoration, reverse engineering, x264
