Old 25th May 2012, 08:00   #1  |  Link
meshaun
10bit Video playback
Hello guys, I encoded a x264 10bit video file, and I'm unable to play it. Here's my PC specs:
I can flawlessly watch 8bit 1080p video's. But with the 10bit,there are multiple problems that I seek answers.
1- The video get's lagged. stuck and flickering.
2- The Audio skips like 1 second or two together with the video lagging.
I've installed MPC + LAV Filters + madVR . here are some screens of my settings.
What can I do to improve my playback?
meshaun is offline   Reply With Quote
Old 25th May 2012, 10:51   #2  |  Link
Qaq
AV heretic
Hard to say w/o madVR stats (ctrl+j).
Qaq is offline   Reply With Quote
Old 25th May 2012, 11:11   #3  |  Link
renq
COrrect me if I'm wrong but to my knowledge HW acceleration (PureVideo, UVD, not sure about Intel) isn't available for 10bit videos
My HTPC: Intel Celeron G1610, 4x2GB 1066MHz DDR3, HD Graphics, Win 8.1 Pro N
renq is offline   Reply With Quote
Old 25th May 2012, 11:53   #4  |  Link
Qaq
AV heretic
AFAIR, "HW acceleration" setting doen't matter for 10 bit. Active decoder will be switched automatically to something compatible - SW.
Old 25th May 2012, 12:02   #5  |  Link
lachs0r
eccentric
With that system you could most likely just use SMPlayer2 with the gl3 video output. This is guaranteed to be quite a bit faster than your current setup.
Also, your system temperatures are pretty alarming.
lachs0r is offline   Reply With Quote
Old 25th May 2012, 18:19   #6  |  Link
Hera
.NET Web App Dev
Avoid MadVR is the best advice I can give you.
Intel i7 5820k / 16 GB DDR4 / NV 970 / 4K ASUS
Windows 8.1
Hera is offline   Reply With Quote
Old 26th May 2012, 00:48   #7  |  Link
namaiki
+1
Not sure why you would say that, but I think that GPU is strong enough for madVR.
namaiki is offline   Reply With Quote
Old 26th May 2012, 02:59   #8  |  Link
meshaun
Hello guys, thank you all for your comments.
I fixed my Heat thing and now it's working flawlessly ?
Could that be a heat problem and lack of performance?
Now, a slight change of settings, from Minimal to max.
How to change the settings to MAX settings, so that I can try to get the best quality possible
Old 26th May 2012, 07:58   #9  |  Link
Qaq
AV heretic
I thought so. Make screenshot again and do not set a movie on pause this time. Better try to set display refrash rate to 23.
Old 26th May 2012, 14:13   #10  |  Link
namaiki
Or if not that, the highest multiple of 23.976Hz that your monitor can do properly. You should hopefully be able to do a custom resolution in the Nvidia control panel.
10bit, hi10p, playback
