Old 4th April 2012, 19:04   #1  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
TX264 0.9.8 - GUI for x264 with audio encoding support
TX264 is a GUI for x264, ffmpeg, mkvmerge, mkvextract, mp4box, faac, neroaacenc, qaac, oggenc2, aften and flac. It is written in Delphi.
Some features:
-All basic x264 options (profiles, crf, bitrate etc)
-64bit support
-10bit encoding depth support
-Advanced x264 options
-Resizing and cropping
-Split according to size or time
-Preview filters and encoding options applied
-Encode audio streams to aac, ogg, mp3, ac3 or flac
-Apply audio filters (resample, normalize, volume, channel downmix, DRC)
-Copy chapter info from mkv/mp4 source
-Mux encoded content to mp4 or mkv
-Mux all external or internal subtitles to the output mp4/mkv
-Pass custom options to tools
-Detailed info about selected file
Screenshots:
Bug reports and suggestions are more than welcome.
Download page: http://tx264.sourceforge.net/ just extract 7zip archive and run.
ozok is offline   Reply With Quote
Old 4th April 2012, 20:56   #2  |  Link
cengizhan
support for other encoders like qaac, quicktime for aac will be helpfull.
cengizhan is offline   Reply With Quote
Old 4th April 2012, 21:33   #3  |  Link
ozok
ozok's Avatar
I'm planning to add support for lame and qaac.
Old 5th April 2012, 09:55   #4  |  Link
Hobbe
qaac would be great.. and ac3 encoding with ffmpeg.
Hobbe is offline   Reply With Quote
Old 8th April 2012, 02:10   #5  |  Link
ozok
ozok's Avatar
Update @ 08.04.2012
What's new:
--0.2
-Added: Support for qaac
-Added: Support for oggenc
-Added: Support for aften
-Added: Console outputs are added to log right after that process is finished
-Added: TX264 now remembers last opened directory
-Fixed: NeroAacEnc profile could not be set problem
-Fixed: A few minor problems
-Updated: JVCL to 3.45
-Updated: MediaInfo.dll to 0.7.55
-Updated: FFmpeg to N-39494-g41a097a
-Updated: mkvmerge to 0.5.5
-Updated: mkvextract to 0.5.5
Old 10th April 2012, 13:59   #6  |  Link
ozok
ozok's Avatar
Hello,
I've just found out that MediaInfo.dll version 0.7.55 that comes with TX264 0.2 causes some problems. There is a new version of MediaInfo.dll (0.7.56) which solves that problem. You can manually change that file, but I'll post a new version of TX264 that'll come with that MediaInfo.dll today.
Old 17th April 2012, 21:02   #7  |  Link
ozok
ozok's Avatar
Update:
-Added: Advanced x264 options
-Added: FFMpeg as encoder
-Added: Option to disable "neroaacenc not found" warning
-Added: Option to copy chapters from source
-Fixed: Passed same fps value to mp4box
-Fixed: Bitrate tolerance could not be increased
-Updated: FFMpeg to N-39877-g4fa706a
Old 23rd April 2012, 00:17   #8  |  Link
ozok
ozok's Avatar
Update:
-Added: All the subtitle streams will be muxed into output mp4/mkv
-Fixed: Bitrate tolerance box could not be disabled
-Fixed: External subtitles could not be found
-Fixed: Open gop option was passed wrong
-Fixed: Partition options were passed wrong
Old 26th April 2012, 17:50   #9  |  Link
ozok
ozok's Avatar
Update
Update:
-Added: Time and size based splitting
-Added: Detailed log that'll keep every output of backends
-Added: Cropping for FFMpeg
-Fixed: A few small bugs
-Updated: x264 to rev 2197
-Updated: FFmpeg to N-40126-ga4b58fd
Old 29th April 2012, 17:46   #10  |  Link
meshaun
What's the difference between TEncoder and this? Same developer ?
meshaun is offline   Reply With Quote
Old 29th April 2012, 18:18   #11  |  Link
ozok
ozok's Avatar
Yes i develop both tool but they are very different tools. This is dedicated to h264 encoding.
Old 29th April 2012, 21:42   #12  |  Link
ozok
ozok's Avatar
Update:
-Added: Update downloader
-Added: CRF values are now float
-Added: Skin and images
-Added: Menus
After this version you'll be able to download just update.exe within program instead of whole package.
Old 30th April 2012, 10:29   #13  |  Link
meshaun
No autocrop option ozok?
That will be great, you know
Old 30th April 2012, 20:49   #14  |  Link
easyfab
Thanks for this GUI, it looks promising.
quick report :
- Audio/neroaac/quality : selection doesn't work correctly go directly from 0,00 to 1,00
- Filters/Resize/resize method (with x264 ) : Resize method doesn't apply ( I don't see it in the log )
Requests :
- Could you add a menu/option for --seek and --frames or something like that to select the start and the duration of the encode
- an option for output directory -> same as the original file
- WMV in the suported files list ( it works without problems for me )
easyfab is offline   Reply With Quote
Old 30th April 2012, 20:56   #15  |  Link
ozok
ozok's Avatar
@meshaun only way i know of detecting autocrop values is to run MPlayer. Is there any other way that wouldn't bloat file size?
@easyfab thanks for the bug report. I've already fixed resize method problem but i wasn't aware of Nero one. They will be fixed with next release.
And I'll add your requests as well, they seem to be easy to implement.
Old 1st May 2012, 01:57   #16  |  Link
meshaun
Avisynth can detect auto crop I believe. And MeGUI uses that. The MeGUI autocrop is working perfect. You can try that ozok
Old 4th May 2012, 14:08   #17  |  Link
ozok
ozok's Avatar
I tried using Avisynth for the first time in my life and managed to add resize, crop and deinterlace avisynth filters (with a bit of copying from Staxrip but hey who cares). But i couldn't get AutoCrop.dll working.
If you guys have other filters, please let me know so i can try and add them as well.
Old 4th May 2012, 16:16   #18  |  Link
meshaun
http://forum.doom9.org/archive/index.php/t-37204.html
http://avisynth.org.ru/docs/english/...s/autocrop.htm
http://doom10.org/index.php?topic=1255.0
Please check those. I really want to contribute to your project.
Did you think about the Extracting the subtitle files with the output? Like, encode the video file and select the subtitle files on the .mkv and extract them to the output folder too? Maybe a subtitle convertor intergration would be nice. I haven't seen that anywhere yet.
Old 4th May 2012, 18:36   #19  |  Link
ozok
ozok's Avatar
@meshaun i can add an option to whether to mux or just copy subtitles.
regarding autocropping, i'll look into it deeper but i'll be off for next 1-2 weeks.
Old 5th May 2012, 08:45   #20  |  Link
meshaun
Ohhh, that's a loss But it's your life, and I gotta thank for what you've done so far.
Be back and develop it
faac, mkv, mp4, neroaacenc, x264
