#1 | Link |
AvxSynth: a Linux port of AviSynth
We are happy to announce AvxSynth, a native port of AviSynth 2.5.8 running on Ubuntu 32/64. Details can be found here: www.avxsynth.org.
#2 | Link |
Excessively jovial fellow
Interesting. I see you've made a slightly modified FFMS2 source plugin; if you want to have your own branch of FFMS2 on the official repository for that, feel free to contact me. Or is the plan to make the plugin interfaces compatible?
#3 | Link |
Very nice work, videophool! I have been able to play video via an Avisynth script in a VirtualBox Ubuntu 64. Sweet!
This will make a lot of people very happy. DG tools for Linux now becomes a real possibility. Last edited by Guest; 9th March 2012 at 23:10. |
#8 | Link |
Will it be possible or is it already possible to patch ffmpeg / libav with .avs file support for Linux like the avisynth support compile option on Windows.
Just thinking about Linux ffmpeg based NLE's like kdenlive and media toolkits like MLT to be able to handle .avs files as if movie, audio or image files. Although I happily use Avisynth + AVSPmod via wine on Linux this is really excellent news. |
#10 | Link |
This is excellent news! Will have to have a look at the code at some point. Is there any intention to support multithreading right from the ground up? Did not see a mention on the site at a glance, but will keep reading.
#14 | Link |
very nice indeed, are you guys a company or something as it says you are hiring an avisynth guy, if so did you port this so that your company software can work on linux using avxsynth or something?
great job, i'm sure more video software will become available on linux over the coming months and years as a result of this. |
#15 | Link |
Since our work was a business decision we worked from the stable 2.5.8 branch, the same branch that we use for production encodes. However, we have established a porting model for AviSynth, and it would take a few committed developers about 2 months to port 2.6, if they were so motivated. That is left as an exercise for the reader.
#16 | Link | |
#17 | Link |
Cheers, ooooh I'm up and running, the last step 'Build Test' instructions threw me a bit not knowing KDev but by that time the executables we're built in the folder anyway. Going to play. :-) Thanks again.
**EDIT** Ok, error trying to replicate your Youtube Demo but FFVideoSource not found, looking in my /home/.AVXSynth/plugins folder all plugins except ffms2avs are there, going back to the KDev project and trying to build the ffms2avs gives me this error: compiling avsutils.cpp (g++) compiling ffswscale.cpp (g++) compiling avssources.cpp (g++) compiling ffpp.cpp (g++) In file included from src/ffpp.cpp:21:0: src/ffpp.h:33:37: fatal error: libpostproc/postprocess.h: No such file or directory compilation terminated. make[1]: *** [src/ffpp.o] Error 1 So I assume libpostproc in libav doesn't build by default, so added it to the ./configure line for libav, --enable-postproc, rebuilt libav, back into KDev project and built the ffms2avs plugin and we're away, WOOT! :-) **EDIT**EDIT** Ok first test something simple opened a flagged full range luma, h264AVC MOV off a DSLR, using FFVideoSource and histogram=classic, output is scaling luma 16 - 235 in the waveform, played back in MPlayer. If this is ffms2 v2.16 rather than 2.15 or 2.17 then that'll be the reason, known to be buggy and fixed in later revisions. I did download 2.17-src and it made a 2.16-1_amd64 deb package? Apart from that the script works, plays the file and segfaults at the end of playback. :-( ALERT : Module=appInterface,Address=src/avxSynthAppInterface.cpp:453,Type=Alert,Message=Reached end of stream at frame #475 Segmentation fault I'm aware this is WIP and extremely impressed non the less. Netflix eh? Last edited by Yellow_; 11th March 2012 at 11:42. |
#18 | Link |
Wow, this is just the best Avisynth news in a long time. Just one question - why do you create your own IDE(AvxEdit), can't the wxPython of AvsP(mod) used in Linux?
DVD slideshow GUI(Freeware). |
#19 | Link | |
#20 | Link | |
I am not seeing the segfault. can you give some repro steps? |
