Old 29th February 2012, 23:17   #1  |  Link
MasterElwood
remux canon Videos for PS3 playback
Someone did this with Iphone Videos here:
http://forum.doom9.org/showthread.php?t=156768
I need the same thing for my "Canon Power Shot SX220 HS" .movs
here is a sample:
http://dl.dropbox.com/u/3775237/Cano...p%20Sample.MOV
Please help.
And thanx in A.
MasterElwood
MasterElwood is offline   Reply With Quote
Old 29th February 2012, 23:27   #2  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
remux with tsmuxer to .m2ts. if tsmuxer won't like .mov then remux first to .mkv with mmg.exe and then import mkv in tsmuxer.
if .mov has aac audio then you should use .mp4 container .
ffmpeg.exe -i video.mov -vcodec copy -acodec copy -o remuxed.mp4
Old 1st March 2012, 00:04   #3  |  Link
MasterElwood
i tried to put that in a .bat like in the iphone sample but i am to stupid
can u put that in a batch .bat please?
thanx in A.
Old 1st March 2012, 00:34   #4  |  Link
poisondeathray
for %%a in ("*.mov") do ffmpeg -i "%%a" -vcodec copy -acodec copy "%%~na.mp4"
pause
The link is down. Are you sure the video & audio compression are PS3 compatible ?
What does mediainfo (view=>text) say ?
Old 1st March 2012, 01:48   #5  |  Link
Audionut
Canon DSLR's are Baseline Level 5.0 (1 Ref frame) with PCM audio.
Default bitrates of around 45Mbps.
I would assume the little 'Power Shot' would be the same as I think it has the DIGIC 4 processor.
http://www.7-zip.org/
Old 1st March 2012, 02:07   #6  |  Link
poisondeathray
Yes, DSLR's are, but I believe the power shot is point and shoot
They often use mjpeg in MOV
Old 1st March 2012, 03:13   #7  |  Link
Audionut
Other brands perhaps, but Canon uses the same DIGIC processors as the DSLR's in ther point and shoots.
http://www.canon.com.au/For-You/Digital-Cameras/SX220HS
Movies
MOV (Image Data: H.264; Audio Data: Linear PCM stereo)
Old 1st March 2012, 09:45   #8  |  Link
Ghitulescu
Ghitulescu's Avatar
Other brands perhaps, but Canon uses the same DIGIC processors as the DSLR's in their point and shoots.
Just that the Canon DSLRs shoot in AVCHD, not in MOV, DiGiC or no DiGiC. I know this is just a marketing decision and not a technical one, but this doesn't magically change the MOV into AVCHD. In fact the quoted message explained in fully this power of marketing, to make people believe they can get more with less money, which is false, of course.
The only solution is to convert/demux the MOV into another format. I don't know Canon (I'm a Nikonist), but my experiences with small cameras [improperly] used for filming is that one needs the Quicktime fullversion (ie one has to pay ) to properly decode these files or variable/uncorrectable audio delays may occur. Canon needs to protect its camcorder division, too.
Born in the USB (not USA)
Old 1st March 2012, 10:12   #9  |  Link
MasterElwood
pause
New link:
Media info (other file - same camera):
General
Complete name : F:\VIDEOS SELF VORHOF\CaliWornia 2012\KINDI\2012-01-28_16-41-20-SID.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 41.3 MiB
Duration : 13s 714ms
Overall bit rate : 25.3 Mbps
Encoded date : UTC 2012-01-29 00:41:21
Tagged date : UTC 2012-01-29 00:41:21
CNTH : ,|
Video
Format : AVC
Format profile : Baseline@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 23.7 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.857
Stream size : 38.7 MiB (94%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 2.51 MiB (6%)
Language : English
Old 1st March 2012, 10:18   #10  |  Link
MasterElwood
pause
not working
C:\Users\Elwood\Desktop\Iphone to PS3 tests>for %a in ("*.mov") do ffmpeg -i "%a
" -vcodec copy -acodec copy "%~na.mp4"
C:\Users\Elwood\Desktop\Iphone to PS3 tests>ffmpeg -i "video.MOV" -vcodec copy -
acodec copy "video.mp4"
FFmpeg version SVN-r22520-Sherpya, Copyright (c) 2000-2010 the FFmpeg developers
built on Mar 14 2010 12:21:30 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
libavutil 50.12. 0 / 50.12. 0
libavcodec 52.59. 0 / 52.59. 0
libavformat 52.55. 0 / 52.55. 0
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.18. 0 / 1.18. 0
libswscale 0.10. 0 / 0.10. 0
libpostproc 51. 2. 0 / 51. 2. 0
Seems stream 0 codec frame rate differs from container frame rate: 60000.00 (600
00/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'video.MOV':
Metadata:
major_brand : qt
minor_version : 537331968
compatible_brands: qt CAEP
Duration: 00:00:10.04, start: 0.000000, bitrate: 24835 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1280x720, 23221 kb/s, 29.97 fps, 29.
97 tbr, 30k tbn, 60k tbc
Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[mp4 @ 03850050]track 1: could not find tag, codec not currently supported in co
ntainer
Output #0, mp4, to 'video.mp4':
Metadata:
encoder : Lavf52.55.0
Stream #0.0(eng): Video: libx264, yuv420p, 1280x720, q=2-31, 23221 kb/s, 30k
tbn, 30k tbc
Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, 2 channels, 1536 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Could not write header for output file #0 (incorrect codec parameters ?)
C:\Users\Elwood\Desktop\Iphone to PS3 tests>pause
Drcken Sie eine beliebige Taste . . .
sad thing: i dont understand a single word
Old 1st March 2012, 10:38   #11  |  Link
J_Darnley
J_Darnley's Avatar
Originally Posted by MasterElwood View Post
[mp4 @ 03850050]track 1: could not find tag, codec not currently supported in container
What's not to understand about this? Not to mention the fact that it should be highlighted in red.
You cannot put PCM audio into mp4, you will have to encode it into some supported format: aac, ac3 or mp3
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 1st March 2012, 10:40   #12  |  Link
Ghitulescu
Ghitulescu's Avatar
http://forum.doom9.org/showthread.php?t=140877
EDIT: J_Darney was faster, I was searching in doom9.
Old 1st March 2012, 12:17   #13  |  Link
Atak_Snajpera
pcm is allowed in .m2ts. it is worth to try at least.
Old 1st March 2012, 21:19   #14  |  Link
b66pak
b66pak's Avatar
@MasterElwood use this line:
ffmpeg -y -i Canon.mov -async 1 -vcodec copy -acodec libvo_aacenc -ac 2 -ab 192000 Canon.m4v
make sure you have the latest ffmpeg build...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 1st March 2012, 23:51   #15  |  Link
Audionut
What nonsense are you on about? Canon DSLRs do output into MOV!!!
I know this because I am a Canon user, and have a DSLR.
Old 2nd March 2012, 13:17   #16  |  Link
MasterElwood
_
THIS WORKS!!!
Thank you. Thank you all!!!
Old 2nd March 2012, 14:10   #17  |  Link
Ghitulescu
Ghitulescu's Avatar
Sorry, I don't have a Canon, this is the info I got from the web.
Old 22nd April 2012, 08:10   #18  |  Link
moonwander
_
I used this for my Canon Elph 300 HS videos, when I playback, it has audio only but no video.
moonwander is offline   Reply With Quote
Old 23rd April 2012, 06:14   #19  |  Link
moonwander
Can somebody help, please?
Old 23rd April 2012, 11:16   #20  |  Link
nm
You didn't give any information that could help solve the issue. What did ffmpeg print out when you did the conversion? What does Mediainfo say about the original file?
Or even better, post a sample clip. Straight from the camera without conversions.
canon, ps3, remux
