#21 | Link | |
I will check my wife's machine which may be 32 bit (XP) and if so give it a run on there. When I get some quiet time (later today?) I will create a SourceForge project (is that the preferred vehicle?) , upload the source code and executable, and add a note on this forum (new plugin thread?). Phill |
#23 | Link |
I have created a project on SourceForge for this:
https://sourceforge.net/projects/watermarkplugin/ I will add a note to the new plugin thread |
#25 | Link | |
Excessively jovial fellow
I have not tested the filter but here are some source comments. I haven't really read all of the source, I mostly just skimmed it looking for suspicious things.
moveit.cpp
Watermark.cpp No comments except again the .cpp/.c debate. Watermark3.cpp
In general it seems like the effects of this filter could be duplicated fairly easily with existing filters, for example FluaG. Regarding portability: it's not very meaningful to try to make Avisynth plugins portable, since Avisynth itself is so extremely unportable and the plugins aren't useful without it. Still, your code seems portable enough. It doesn't include any Windows headers at all and there are no particular MSVC-isms that I could spot. Quote:
Now go to the project properties in Visual Studio. Hit the debugging tab, set the debug command to run to X:\path\to\virtualdub.exe and the commandline to X:\path\to\debug.avs. Set a breakpoint on AvisynthPluginInit2 (or the Avisynth C equivalent, or just your GetFrame implementation) and hit start debugging. When you do that VS will warn you that it can't find debugging symbols for virtualdub.exe; don't worry about that and just tell it to continue. You'll hit your breakpoint and now you're running your plugin in interactive debug mode. Go hog wild. Last edited by TheFluff; 28th January 2012 at 05:25. |
#26 | Link |
Thank you TheFluff, for taking the time to examine my code and to comment here. There is a lot that is very helpful.
Forgetting the header file is a big blooper - I will correct that soonest. If codeblocks will compile *.c files in exactly the same way as *.cpp files, then I will change the names. I only used .cpp as I followed instructions on how to write a C interface plugin and that is what it said. That means that I will also have to use malloc and free rather than new and delete, but that is fine with me. Not freeing the params block is a definite blooper. The moveit funtion was just there to demonstrate that the watermark was dynamic, and that the algorithm could cope with edges. Anything problems specific to if can be documented. I did not realize that sourcePitch could change, and I am not sure that my algorithm would handle that gracefully... will change the code. The comments about size_t make a lot of sense - I vaguely remember them from an embarrassingly long time ago. They could easily be the source of crashes. #defines for vLight and hLight are a good idea the uppercase was left over from when the values were constant - will change. The nested loops are fairly ugly. - they just sort of grew. I will think about rewriting the algorithm - that is the bit I like doing the most. -------------------------------------------------------- I actually wrote the thing because the learning curve for the non-built-in filters seemed steeper than coding my own! Some scripts were suggested by experience folk here, but it seemed that things that I did not understand failed in ways that I could not describe for reasons that were unfathomable to me. I understand what you are saying about portability - so that is one less goal to aim for. I did try to keep my C as simple as possible so that others could use/compile it should they wish. As far as debugging goes - thanks for the info, but I will try to avoid that. :-) ----------------------------------------------- So in summary, thank you, you comments are greatly appreciated and will guide me to improve the code. I am working this weekend, but hope to have the improvements up by the end of Monday (but likely before if the weather is bad). Phill Last edited by DrPhill; 28th January 2012 at 08:11. Reason: To correct a typo |
#27 | Link |
I just tried changing the files to *.c, and started getting a compilation error that I do not understand:
C:\Users\Phill\VideoProject\Watermark\Watermark.c|26|error: conflicting types for 'avisynth_c_plugin_init'| Phill |
#28 | Link | |
Avisynth language lover
AVSC_EXPORT const char * AVSC_CC avisynth_c_plugin_init(AVS_ScriptEnvironment* env) { |
#29 | Link | |
Phill |
#30 | Link | |
struct wm3_Params { ... }; void wm3_initialise(wm3_Params* params, ... Code:
typedef struct wm3_Params { ... } wm3_Params; |
#32 | Link |
I have done some code tidying and put the results (source and dll) up on SourceForge as 'second cut'.
For convenience I have added the files as an attachment to this note (Moderators: If this is frowned upon, then my apologies, and please feel free to remove them). Changes - I have:
While doing this I removed a bug that could cause a memory access violation, so the problems seen by Emulgator may, just may, have gone away. I cannot promise anything though, but it did need fixing...... I think I addressed most things in the list by TheFluff. I will look at converting the files to *.c from *.cpp next. I am not sure that I can improve the algorithm - I need to do work around boundaries between watermark and not watermark. It seems to me the quickest way to reduce workload is to detect the boundaries first, and work from them. I would be perfectly happy to be shown to be wrong, though. Thanks all. |
#33 | Link |
I think I have spotted a blooper. Can someone confirm that increasing pixel coordinates go from left to right and bottom to top? I had assumed left to right and top to bottom, so I may need to change some of my comments/constants..........
Thanks |
#35 | Link | |
#36 | Link |
Old thread and plugin but does some very interesting things, digging in this forum is full of surprises, the author have not logged since years apparently but i have 2 little questions, maybe one of the knowledge guru's of this forum can help :
- Is there a x64 version of this of this available somewhere please ? It will be really great. For now i have to use MP_Pipeline to make it work in my x64 workflow: Code:
MP_Pipeline(""" ### platform: win64 LoadPlugin("H:\LSMASHSource.dll") LSMASHVideoSource("H:\00.mp4", format = "YUV420P8").ConverttoRGB32 ### ### ### platform: win32 LoadPlugin("H:\test\Watermark.dll") myWatermark = ImageSource("H:\03.png", pixel_type = "RGB32") Watermark(watermark = myWatermark, displace = 20, light = 200, depth = 6, softEdge = true, lightFrom = "NE") ### ### """) - The input video needs apparently to be converted into RGB32 which isn't always the best thing, so I'm wondering if it is possible with avs+ to do something like : LSMASHVideoSource("H:\00.mp4", format = "YUV420P8").AddAlphaPlane() Tried this quickly but i get a returned message telling me the video needs to be on a single plane, maybe i am using the AddAlphaPlane incorrectly... i don't know ![]() Too bad the part about moving the watermark was not finished apparently, this could really have been a great plus if we could have set some coordinates to define a part of the video where the watermark had to move inside, this could have been a terrific thing but even without this option it's a nice little tool. For now i will be more than happy with a x64 version of this plugin to bypass MP_Pipeline and a way to convert my input sources with the minimal quality loss possible or no loss of quality at all with something like like adding only an alpha channel to it ( i maybe misunderstood how exactly this function is supposed to work tho) If anyone have any infos about a possible x64 version of this little thing or ideas to bypass the ConverttoRGB32 step with no loss of quality i will be really grateful. Thanks in advance for any help. Last edited by Yanak; 22nd January 2018 at 23:59. |
#37 | Link |
Long time since anyone posted on this thread...... I have not thought of this stuff for ages.
![]() The source code is up on sourceforge - link in a post above. Note that TheFluff said 'In general it seems like the effects of this filter could be duplicated fairly easily with existing filters, for example FluaG.'. This may be a better route as I am/was a novice at this type of coding in this type of environment, and C is not my strongpoint. I eventually gave up on trying to do the video project using AviSynth and wrote my own tool in Java. Once I had achieved my goal with the java tool I forgot all about it. Where did the years go? Good luck with your endeavours. Phill |
#38 | Link |
Good to see you here
![]() Like i said there is sometimes surprising things to discover digging this forum, the plugin does exactly what i needed with the few parameters it have, just perfect in terms of results. There is indeed probably other ways to do this now, i'm not a avisynth knowledge guru like many around so i'll have to dig more into all this. I saw the FluaG plugin too but have no tried it yet, it's also not updated since like 6 years on his github page... ![]() I just needed exactly what the watermark plugin does with the parameters it offers, it's perfect for me so i did not bothered much more once i saw the results obtained on my tests. I saw there was the source code published but I don't know how to convert nor re-compile this into a x64 version sadly, maybe someone around will be kind enough and take a look at this. This plugin had a nice potential, the option to make it move had been a blast if finished, at worst i will continue to use it with MP_Pipeline and the rgb32 conversion if i don't find any other way to obtain the same effect or if nobody tries to convert it into a x64 version + a way to byapss the converttorgb32, will have to dig into all this in the next days and see what i can do. Thanks for the reply and for this plugin, still helpful years after ![]() Last edited by Yanak; 21st October 2017 at 14:35. |
#39 | Link |
Glad the plugin is of help - sorry I cannot be!
Making the code work on 64-bit might just be a case of choosing the right data types as indicated by an earlier post. (size_t instead of int) Building the thing is a different matter, and part of the reason I went off the C/C++ languages quite early. For someone who does this regularly it probably raises no sweat, but to do it occasionally means a bit of set up. If you do decide to jump into the development then take heart from the fact that I managed to do it and produce a pluggin. Good luck. |
#40 | Link |
Yeah i will probably not put my hands into this , tried a few things in the past but it's a bit too much for me :/ Will cross fingers in hope a good soul will find it interesting as i did and find it worth a x64 version based on the source code (and why not add finish the options to animate it, you never know
![]() Thanks again. |
