#1 | Link | |
JMkvpropedit v1.4.3 - Batch GUI for mkvpropedit
Okay, I rewrote this thing and it's now a batch GUI for mkvpropedit, so it may be actually useful now.
For now you can: -Set title; default, forced, track name and language of video, audio and subtitle tracks (it was compiled for maximum of 30 tracks of each kind, I don't think it's needed, but can be changed easily on the source). -For title and track names there's a basic numbering function, where you specify the starting number and the padding. -You can set the path for mkvtoolnix now. -It's possible to just get the command line instead of actually editing the files. -You can add extra command line parameters for general and each track. Screenshots: ![]() ![]() ![]() ![]() Quote:
#7 | Link |
Now it starts, but retrieving the info with MediaInfo.exe does not really work. It will start, but of the four times I tried opening a file, each time MediaInfo showed different results, strange windows, empty captions, an error etc. Does it rely on MediaInfo being pre-configured with certain settings (like language)?
VirusTotal complains, though only two scanners, btw.: http://www.virustotal.com/file-scan/...8b0-1326030103 |
#10 | Link |
MKVToolNix author
I've added a link on the MKVToolNix links page to this thread.
Latest MKVToolNix is v68.0.0 If I ever ask you to upload something, please use my file server. |
#11 | Link |
Wow, I feel honored!
![]() If anyone is interested, I'm updating the code to pass everything but the extra arguments to an option file (or maybe everything, if I find a good way to do it). It made sense after I saw Mosu talking about the Windows command line character limit. |
#13 | Link |
I just wanted to let you know how much your work is appreciated! I have literally scoured the net and reached the end looking for this program that didn't exist until now. I've made pleas to the dev of mkvpropedit, as well as the devs of mp3tag and puddletag respectively in the hopes that someone would take up the cause.
Making it cross-platform was another win for me as I'm running xubuntu, and was just sure that if anyone would make this program it would be native to windows. **End Gushing** The one question I would ask, is if it's possible to pass a group of files to the program using a file manager. (Thunar in my case) Thunar lets you create custom actions and I've tried everything I could think of but with no joy. exec java -jar "~/.bin/JMkvpropedit.jar" "%F" Thunar uses these substitutions: %f — The path to the first selected file. %F — The paths to all selected files. %d — Directory containing the file passed in %f. %D — Directories containing the files passed in %F. %n — The first selected file name (no path.) %N — the selected file names (without paths.) Even without this functionality I'm still ecstatic, but if this is possible it would really shine. Many Thanks, E |
#14 | Link |
It's possible, but it didn't work because there's no command line parameter parsing as of now, I have to add it.
You can compile the JAR to a Linux binary using Launch4j, then you don't have to call it using "java -jar". Edit: Launch4j is only for creating Windows executables, I didn't actually test it, sorry. ![]() Last edited by [ReX]; 4th March 2012 at 05:29. |
#16 | Link |
Outstanding!
![]() Works like a charm. Tagging my collection won't be such a daunting task now. You have my gratitude. E P.S. Thanks for clarifying Launch4j. I checked it out but just figured I was missing something. It doesn't matter anyway as I am able to just dbl-click the .jar to launch if I want but I prefer to call it from the file manager with the files I want selected. |
#17 | Link |
Knows a thing or two...
I would like to use this tool so i can easily change properties of my mkv files (default subtitle flags mostly).
For some reason when i load a file, nothing seems to be recognised or analysed though. For example... a mkv file i loaded has 7 different subtitles, but this tool is not showing any of them, Am i doing something wrong? ![]() |
#18 | Link | |
To change all 7 subtitles tracks, go the the subtitle tab and click the plus button until you have all 7 tracks there. Don't worry, only the things that are checked are changed; if you don't want to change the track name, for example, don't check it and it won't be touched at all. As was said in this thread, if you want something to change just one file that shows the current properties, just use mkvmerge GUI's header editor (File -> Header editor). Last edited by [ReX]; 18th June 2012 at 14:27. |
#19 | Link |
To be frank i think your tool has a better user interface than the MKVMergeGUI header editor.
Suffice to say it looks like i get an error message on the output tab once i try to process your suggestion (go to the right track number and edit the 'default' flag). For some silly reason the command line seems to automatically adjust to my windows language but translated it says something like: "Warning: The properties 'track:s4' and 'track:s4' lead to the same track with UID ######". After that it still states "Changes are being written to file. Done." But after that when i check the mkv file, nothing has changed. -- The MKVMergeGUI header editor has a few major turn-offs... opening as well as writing to a file make the window 'not responding' there's no progress bar or anything. Editing the subtitle track properties is bothersome to say the least since you have to collapse the right headers and scroll up and down the window while that seems to work rather limited. [Edit]: Looks like your tool is working regardless of the output message! The track properties are being changed...i just had to un-default the other ones for the changes to become visible (must have slipped me somehow). ![]() Last edited by Da_maniaC; 18th June 2012 at 18:35. |
#20 | Link | |
1.0.9.1 released!
matroska, metadata |
