#1 | Link |
MP_Pipeline 0.18 - run parts of avisynth script in external processes [2014-04-06]
This plugin is originally written for my friend to work-around the [del]2GB[/del] 4GB problem of 32-bit process. (Well, also for fun.
![]() As of 0.11, overhead of the plugin is much smaller, it may be possible to use it to speed up more scripts. Change log: Code:
0.18 * Fix deadlock when exported clip is consumed by multiple script block 0.17 * Properly terminate slave processes when initialization fails * Fix "Not a clip" error when using ### inherit and the last block is empty 0.16 * Try to silent all error dialogs on exit of slave process * Slave process shouldn't be stuck on exit anymore, it will terminate itself if it doesn't exit cleanly after 15 seconds * Fix ### branch statement, previously it incorrectly rejects some input 0.15 * Properly clean script environment up on exit * Allow using different avisynth dll to run script block (### dll) 0.14 * Fixed another crashing bug 0.13 * Fixed a bug that causes occasional crashing 0.12 * Fixed a problem that makes scripts unable to be loaded in some programs 0.11 * Greatly improved performance, maximum 80% overhead reduction * New feature: Ability to lock threads to cores, may improve performance in some cases * (0.10 is skipped to avoid confusion) 0.9 * New feature: Frame prefetching * New feature: Exporting multiple clip variables in a single process * New feature: Code block can be shared between processes 0.3 * Binaries in the x86 folder are in correct version now (In 0.2 the win64 slave is actually win32...) * Integrated a patched TCPDeliver, no longer depend on the external one * Fixed random crash when filter chain is destroyed * Thunked branching 0.2 * x64 support (please copy TCPDeliver.dll in the package to respective plugin folder) * x86/x64 mixed slave process (requires both x86/x64 version of AviSynth to be installed) * Add a script variable in branch slave process, make it distinguishable in script * Since each process have its own script environment, all script variables and loaded plugins won't be inherited, they must be re-initialized if needed * Due to the limitation above, manually-loaded plugins and imported scripts need to be reloaded/re-imported before they can be used in new process (Or use inherited script snippet, please see MP_Pipeline_readme.avs for details) * Clips before MP_Pipeline will be ignored * Audio is not supported * Every script block must return a clip (i.e. "last" must be a clip), otherwise MPP will raise this error: Invalid arguments to function "MPP_PrepareDownstreamClip" Binary: http://nmm.me/z6 Source code: https://github.com/SAPikachu/MP_Pipeline/tree/0.18 Some example: 1. Basic usage: Code:
MP_Pipeline(""" FFVideoSource("SomeVideo") QTGMC() ### prefetch: 16, 0 ### ### """) MCTD() # MCTD and QTGMC will be run parallelly in 2 separate processes Code:
# Must be 64bit system with at least 8GB memory to run this script MP_Pipeline(""" # This may be smaller, but I only tested this number SetMemoryMax(3072) FFVideoSource("SomeVideo") MCTD(settings="high") ### prefetch: 16, 0 ### ### """) # Some time ago I used a script similar to this one for encoding, it is about 20% ~ 30% faster than plain MCTD. Code:
MP_Pipeline(""" FFVideoSource("SomeVideo") TNLMeans() ### prefetch: 16, 0 ### branch: 4 ### ### """) # TNLMeans will be run in 4 processes with branching (please see example script in the package for details) Code:
MP_Pipeline(""" FFVideoSource("SomeUnseekableVideo", seekmode=-1) TNLMeans() ### prefetch: 32, 24 # It is important to use a big backward cache since we can't seek ### ### MCTD() """)
f3kdb 1.5.1 / MP_Pipeline 0.18 ffms2 builds with 10bit output hack: libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1 Built from ffms2 6e0d654 (hack a9fe004) Mirrors: http://bit.ly/19TwDD3 Last edited by SAPikachu; 6th April 2014 at 10:57. |
#3 | Link |
User processes can only use 2GB of full address space, don't they? (well... actually 3GB on some conditions, but that's a special case)
f3kdb 1.5.1 / MP_Pipeline 0.18 ffms2 builds with 10bit output hack: libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1 Built from ffms2 6e0d654 (hack a9fe004) Mirrors: http://bit.ly/19TwDD3 |
#5 | Link |
Didn't notice that until read this. Learned something today, thanks.
#6 | Link |
Compiling Encoder
generally everything has to be compiled with large address awareness for the 32bit binaries (executable and dlls) to really allow addressing over 2GB of memory.
as this is also not usually a default build option iirc, most things don't have it enabled, preventing beyond 2GB of addressable memory. |
#7 | Link |
Software Developer
![]() Join Date: Jun 2005
So this basically is an AVS2YUV clone, but not as a stand-alone application, but as an Avisynth plug-in?
I think this would be particularly useful to load 32-Bit plugins (that don't have 64-Bit equivalents) into a 64-Bit Avisynth environment. Or vice versa. Is that supported/intended?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 1st December 2011 at 15:01. |
#9 | Link | |
Software Developer
http://blogs.msdn.com/b/oldnewthing/.../10065933.aspx But then loading a DLL into some "LARGEADDRESSAWARE" process might break it, if the code in that DLL isn't prepared to deal with addresses beyond 2 GB.
#10 | Link | |
That is not my original intention, but it is interesting. It only supports x86 now, I will add x64 and mixed script environment support later when I have time.
#12 | Link |
soy sauce buyer
Now add large memory aware flag to exceed 2GB limit in avs4x264mod.
#13 | Link | |
MP_Pipeline(""" WhateverSource("Some\Source") ### ### QTGMC("Placebo") ### branch: 4 ### ### """) By comparison, splitting the video and running many separate single threaded encoding processes, or just using SetMTMode gives 20-25fps. SetMTMode uses a lot less memory. |
#15 | Link | |
#16 | Link | |
#18 | Link |
Splitting the whole clip into big thunks doesn't make sense as we can't have parallelism in avs filter in this way. But I think we can split the clip into small thunks (32 frames each thunk for example), and use it with ThreadRequest. This may reduce duplicated processing, the speed may increase (but I'm afraid that this method will never be faster than SetMTMode since the overhead is much bigger) I need to make some new filters for that. Again, when I have time...
#19 | Link |
Ooh!
![]() So does this mean I can at last do: Code:
LoadPlugin("MP_Pipeline.dll") LoadPLugin("PB_3D_tools.dll") AVIsource("some_anaglyph_3D_thing.avi") MP_Pipeline(""" global LeftEye = ExtractOneSide(Eye="Left") ### ### global RightEye = ExtractOneSide(Eye="Right") """) StackHorizontal(RightEye,LeftEye) ![]() I'm assuming "last" is passed though in the normal way. Have got the right idea about getting data back from the processes? Do LeftEye and RightEye need to be global variables, and if so, where should they be defined: Inside MP_Pipeline, outside, or both? |
#20 | Link | ||
Avisynth language lover
I expect also that the script in quotes must return a clip, and yours doesn't. |
avisynth, multi-process, pipeline |
