Old 10th November 2011, 20:47   #1  |  Link
oreons
MkvToMp4 author
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
Download - http://www.mediafire.com/?1a0oc04u539b5eg
Features:
- Change the container to Mp4 without transcoding video (If the original video in h264 format)
- Support for multiple internal and external audio tracks
- Support subtitle formats: srt, ass, ssa, ttxt. Changing colors for subtitles.
- Add and edit tags for Mp4 files (m4v, m4a, m4b)
- Artworks and chapters for Mp4 files.
- Encode video for non-h264
- Correction of the atoms in Mp4 files to be able to change the audio and subtitle on Apple devices.
- Searching tags on TheTvDB, TheMovieDB and iTunes web sites
- English and Russian interface.
Requirements:
Microsoft Visual C++ 2008 Redistributable Package for WinXP only
QuickTime codec (recommended)
Screenshots:
oreons is offline   Reply With Quote
Old 10th November 2011, 20:49   #2  |  Link
b66pak
b66pak's Avatar
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 11th November 2011, 20:12   #3  |  Link
Vize99
Nice one !
So far all remuxed files I tried stream nicely to the iPhone 4 using the "Air Video"-App.
10x faster then using conversion (or re-encoding) and no strain on CPU (greetings from my Laptop).
Only thing missing would be a remote control app for the Iphone...
Using Remote Desktop Apps to initiate the re-muxing is quite a challenge for people with full sized hands&fingers like me
Vize99 is offline   Reply With Quote
Old 12th November 2011, 11:40   #4  |  Link
Hobbe
Thanks! Great program! Any plans to support downmix of multichannel audio.. 7.1,6.1 -> 5.1 ?
I think I also have found a bug.. dts-es 6.1 audio encoding dosent seams to work.. you just get one channel aac in the resulting file.
Hobbe is offline   Reply With Quote
Old 12th November 2011, 17:48   #5  |  Link
oreons
MkvToMp4 author
You need AAC 5.1 or AC3 5.1 from DTS 6.1?
Try to install Arcsoft dts decoder. Eac3To uses the default libav decoder that works incorrectly with DTS 6.1-7.1
Old 12th November 2011, 23:28   #6  |  Link
Hobbe
aac 5.1.. ac3 always downmix to 5.1.
I'm using arcsoft dts decode v1.1.0.0..
Old 13th November 2011, 14:37   #7  |  Link
oreons
MkvToMp4 author
I tested the file 7.1 DTS -> 2.0 AAC. The sound is normal.
When make DTS 7.1 -> AAC multichannel, the sound is wrong. In future versions I will add a decrease to 5.1. This is one option for Eac3To (-down6).
log:
Started processing file: D:/Video/dts71/file7_1.dts
Copy file D:/Video/dts71/file7_1.dts to Temp\file7_1_internal_audio_0.DTS
Starting Eac3To with the parameters:
Tools\eac3to\eac3to  "D:/Download/MkvToMp4/0.217/Temp/file7_1_internal_audio_0.DTS" "Temp\file7_1_internal_audio_0.wav" -down2  -normalize  -down16 -progressnumbers
DTS Master Audio, 7.1 channels, 16 bits, 48kHz
(core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz)
Decoding with ArcSoft DTS Decoder...
Mixing surround channels...
Downmixing multi channel audio to stereo...
Reducing depth from 64 to 16 bits...
Writing WAV...
Creating file "Temp\file7_1_internal_audio_0.pass1.wav"...
Clipping detected, a 2nd pass will be necessary.
The original audio track has a constant bit depth of 16 bits.
Starting 2nd pass...
Reading WAV...
Writing WAV...
Applying -2,99dB gain...
Creating file "Temp\file7_1_internal_audio_0.wav"...
Done.
Starting Qaac with the parameters:
Tools\qaac\qaac  --tvbr 95 "D:/Download/MkvToMp4/0.217/Temp/file7_1_internal_audio_0.wav" -o "Temp\file7_1_internal_audio_0.m4a"
initializing QTML...done
qaac 0.86, QuickTime 7.7.0
Old 16th November 2011, 14:48   #8  |  Link
Rat Killer
Does this support placing ac3 5.1 audio in an mp4 file? IE recoding from AAC or DTS TO AC3?
Rat Killer is offline   Reply With Quote
Old 16th November 2011, 15:57   #9  |  Link
oreons
MkvToMp4 author
You can put original AC3 to Mp4 file, select the checkbox in the settings of track.
DTS can transcoded to AC3. AAC is not encoded.
Old 17th November 2011, 08:14   #10  |  Link
Hobbe
Some requests if it's possible
Show fps and remaining time when encoding.
Allow encode from mov and mp4. You may want lower resolution/bitrate.
Make it possible to change number of channels when edit audio stream from wmv. I have set 5.1 in global aac options but if audio source is 2 channel I want 2 channels
Is it possible to use quicktime/itunes portable? And use qaac with just the required dll's?
Old 17th November 2011, 09:13   #11  |  Link
oreons
MkvToMp4 author
From Mov and Mp4 you can encode for this turn to edit mode in the stream window (right mouse click).
If source is 2-channel, the output will also be 2 channel.
What about portable I do not know, but it works with QT Lite
Old 17th November 2011, 12:56   #12  |  Link
Hobbe
Ahh ok. Thanks. I missed edit mode
Ok. It said Output AAC 5.1 in the audio window..
Old 17th November 2011, 13:05   #13  |  Link
oreons
MkvToMp4 author
This is a display information bug
Old 9th December 2011, 00:08   #14  |  Link
yunapolaris
Encode noob
Very helpful tool!! I use it to convert MKV movies to watch on PS3 with my family . Thank you so much for sharing this !
yunapolaris is offline   Reply With Quote
Old 9th December 2011, 01:35   #15  |  Link
DarkT
I've read through it, I saw somebody write that he/she did dts --> something else, does this program allow one to change that? Right now I got WDTV, and it reads lots of things, but DTS... Ugh... So, would be nice if I could just auto-reencode the DTS with 1 program... Right now I extract, use behappy on the DTS, then I re-package... Also, does it have batching?
DarkT is offline   Reply With Quote
Old 9th December 2011, 08:59   #16  |  Link
oreons
MkvToMp4 author
You can convert DTS to AC3 or AAC.
Old 9th December 2011, 14:28   #17  |  Link
Rat Killer
It saves files with the extension .m4v
any way to have it output .mp4 files so I do not have to rename every file? I could not find an option for this but perhaps do not know where to look.
Thanks!
Old 9th December 2011, 14:36   #18  |  Link
oreons
MkvToMp4 author
Thanks!
The program is not possible to switch to mp4 extension. You can rename the files manually. M4v extension is chosen because that Apple only allows to switch tracks on m4v files.
Old 9th December 2011, 15:03   #19  |  Link
Rat Killer
Any way to specify AC3 audio as the default output rather than aac?
Can the AC3 audio bitrate be set?
Can the files be output in IMSA standard streamable mp4 format (IE with the moov atom at the front of the file)?
Thanks for your help. The utility is very useful and fast. Appreciate your work on this.
Old 9th December 2011, 20:12   #20  |  Link
oreons
MkvToMp4 author
You can disable the encoding to AAC taking off checkbox in the settings. Change the number of tracks can not be.
Yes, when encoding DTS.
Yes, in the tags settings you can set the MP4 optimization checkbox.
mkv, mkvtomp4, mp4, repack, video
