Go Back   Doom9's Forum > Announcements and Chat > News
Old 28th October 2011, 18:09   #1  |  Link
PatchWorKs
PatchWorKs's Avatar
Apple Lossless Audio Codec is now open source (Apache license)
The Apple Lossless Audio Codec (ALAC) is an audio codec developed by Apple and supported on iPhone, iPad, most iPods, Mac and iTunes. ALAC is a data compression method which reduces the size of audio files with no loss of information. A decoded ALAC stream is bit-for-bit identical to the original uncompressed audio file.
The Apple Lossless Audio Codec project contains the sources for the ALAC encoder and decoder. Also included is an example command line utility, called alacconvert, to read and write audio data to/from Core Audio Format (CAF) and WAVE files. A description of a 'magic cookie' for use with files based on the ISO base media file format (e.g. MP4 and M4A) is included as well.
The Apple Lossless Audio Codec sources are available under the Apache license. Details can be found here http://www.apache.org/licenses/LICENSE-2.0.
http://alac.macosforge.org/
PatchWorKs is offline   Reply With Quote
alac, apple, codec, lossless, open soure
