Old 12th April 2012, 21:38   #1081  |  Link
Schrade
Schrade's Avatar
Originally Posted by CruNcher View Post
Proper links to download the drivers:
http://downloadcenter.intel.com/Deta...21159&lang=eng (32-bit)
http://downloadcenter.intel.com/Deta...21160&lang=eng (64-bit)
Schrade is offline   Reply With Quote
Old 13th April 2012, 00:26   #1082  |  Link
endiz
Originally Posted by egur View Post
No, I don't have the bandwidth for it.
I understand. Thanks for the quick response!
endiz is offline   Reply With Quote
Old 13th April 2012, 11:37   #1083  |  Link
CruNcher
CruNcher's Avatar
2712 also leaked (was released through OEM) without IVB support http://www.station-drivers.com/forum...t=3741&p=13815
you need again to add the subsys id of your vendor to make it work, works fine so far no issues yet though also doesn't fix decodinerror.ts yet.
It is about Time
Old 14th April 2012, 13:07   #1084  |  Link
pulbitz
I've reproduced/confirmed the issue on another player. Still root causing it.
Bump.
Maybe You forget it?
P.S. LAV QuickSync, PotPlayer QuickSync is OK. Only ffdshow QuickSync has a trouble.
pulbitz is offline   Reply With Quote
Old 15th April 2012, 07:47   #1085  |  Link
egur
QuickSync Decoder author
Originally Posted by pulbitz View Post
Bump.
I've patched my code a while back when the post was new. This clip is part of my test suite.
I'll check again with the latest ffdshow using LAV and Haali splitters and report back.
Eric Gur,
Processor Application Engineer for Overclocking and CPU technologies
Intel QuickSync Decoder author
Intel Corp.
egur is offline   Reply With Quote
Old 16th April 2012, 21:07   #1086  |  Link
CruNcher
CruNcher's Avatar
Hey i just read that
Khenglish confirms 295.xx beta desktop driver drives the internal LCD in additional to providing the x1 pci-e compression making it unnecessary to use the modded Verde driver below.
It seems Nvidia is preparing Synergy (Optimus for Desktops, Lucid Virtu counterpart) into the Main Driver Stack (Framebuffer exchange) , so it cant be much long anymore before time to market is coming (i wonder if currently anyone is testing it under NDA by now already)
Maybe they wait for Ivy Bridge Release would make sense, though not nice to think about that SB users might not profit then again from it if it gets marketed Ivy Bridge exclusive hopefully not again MB exclusive though Nvidias plans where not todo that but still it needs a key in the Bios like Virtu (how i hate such things).
Many things Nvidia added now into the driver stack make it to some kind of enhanced Virtu like Lucidlogix is gonna market with the Universal and MVP series, so this will be really interesting how this here turns out it could also very well explain why Lucidlogix is preparing to sell their Virtu soon to anyone MB license independent
Btw lucid released something new from their Labs of Framebuffer Manipulation ideas http://eshop.lucidlogix.com/?q=dynamix1
these Israeli Researcher have implemented some similar thing to Intels Dynamic Resolution http://software.intel.com/en-us/arti...ering-article/ as a addon for Skyrim to show the Performance improvements that can gained from a Engine (Creation Engine,Modified Gamebryo Engine) not supporting it
The solution aims to enable a playable performance (fps) by dynamically transforming texture resolution mapped on objects in real time, considering object visibility and motion.
All informative elements , such as HUDs, texts, menus and maps remain unchanged and presented in full resolution.
The solution maintains the maximum possible visual experience while increasing game frame rate, bringing it to a playable performance level.
Though the License Process is awkward for something they call free they want you entire Data, and it's bound to a activation server as well geez :P
Though Game Developer have to implement it directly not some 3rd party via a addon interfering into the rendering, also the use for older Games and 3D Engines is near 0, guess this idea of them commercializing this will die fast, i guess next out of their Labs will be some 3D stuff ideas as addon from them stay tuned :P
It is about Time
Old 17th April 2012, 20:39   #1087  |  Link
egur
Bump.
I don't see any issue using LAV splitter - 32 bit playback.
Eric Gur,
Intel Corp.
Old 18th April 2012, 12:00   #1088  |  Link
pulbitz
strange...
I test MPC-HC, KMPlayer and PotPlayer with LAV splitter 32bit.
Only ffdshow QuickSync like yadif output mode 25p/30p.
Other(LAV QuickSync, PotPlayer QuickSync, DXVA and libavcodec) like yadif output mode 50p/60p.
P.S. another sample file http://www.sendspace.com/file/whr0pa
Old 18th April 2012, 12:18   #1089  |  Link
egur
strange...
Which renderer is used in MPC-HC?
Does it work with standard EVR?
FYI, EVR-CP is known to have issues which I can't solve.
Does anyone else have issues with this clip?
Eric Gur,
Intel Corp.
Old 18th April 2012, 14:55   #1090  |  Link
pulbitz
I tested with standard EVR. (I don't use EVR-CP.)
CPU/GPU: i5-2500 with HD Graphics 2000
OS: Windows 7 Ultimate x64 SP1
Driver: 2696
Old 18th April 2012, 15:00   #1091  |  Link
egur
I'll test it with MPC-HC+EVR and report back.
Update
Works fine in the above configuration. Can't reproduce.
Second clip plays fine too.
Eric Gur,
Intel Corp.
Old 18th April 2012, 22:06   #1092  |  Link
tomos
hi,
just tried this today on my new laptop (win7x64 ult / 2670qm i7) in mpc and it worked like a charm. no probs at all on a few different samples.
thanks
tomos is offline   Reply With Quote
Old 19th April 2012, 15:02   #1093  |  Link
pulbitz
Update
It is very wired.
Then problem cannot be resolved in the future.
I'll just have to wait.
Old 20th April 2012, 11:46   #1094  |  Link
JohnPeterson
What about QSV encoding through ff_vfw.dll?
The availability of an open QSV encoder would encourage QSV encoding implementation in popular encoding software such as VLC. It would make sense to have a #transcode{venc=qsv) option in VLC.
JohnPeterson is offline   Reply With Quote
Old 22nd April 2012, 01:45   #1095  |  Link
ajp_anton
ajp_anton's Avatar
I get glitches when decoding this with QuickSync. Software decoding works fine.
http://www.multiupload.nl/9YC1XS9JNY
Old 22nd April 2012, 09:47   #1096  |  Link
egur
I'll check it out but please provide more details (player/renderer/splitter)
Eric Gur,
Intel Corp.
Old 22nd April 2012, 14:20   #1097  |  Link
ajp_anton
ajp_anton's Avatar
I use MPC-HC, LAV splitter and madVR/EVR, but it looks very much like a decoder-only problem.
Old 22nd April 2012, 16:18   #1098  |  Link
pulbitz
I test with 2696 driver.
libavcodec is OK.
H/W decoders get glitch.
(MS DTV-DVD DXVA, PotPlayer DXVA/QS, ffdshow QS)
Old 22nd April 2012, 16:32   #1099  |  Link
CruNcher
CruNcher's Avatar
yup same here every DXVA implementation fails too, very strange artficating could be custom matrix caused
http://img9.imageshack.us/img9/2373/quicksynccmfail.png
It is about Time
Old 22nd April 2012, 16:45   #1100  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
CUVID also has artefacts (much smaller, though)...
vivan is offline   Reply With Quote
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
