Old 11th May 2011, 07:10   #1  |  Link
Beatslars
[CWE]
Gray pixels at start frames of MKVS. Help?!
Name:  Screen shot 2011-05-11 at 1.05.46 AM.png
This is what happens to the very beginning of my MKVs after I successfully split the 3 episodes from the stream. These are only shown in the second and third episodes of the stream files, after the split. I even tried to re-split and it still does it.
I have no idea how to fix this.
Beatslars is offline   Reply With Quote
Old 11th May 2011, 07:15   #2  |  Link
sneaker_ger
As I already told you in your other thread: there are limitations on where you can cut in a video stream. If you do not cut at IDR frames, things like these are bound to happen.
Old 12th May 2011, 02:31   #3  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
^^ Sounds like this is exactly the problem.
How did you split the MKV file?
Derek
anime, encode, frames, gray, split
