#1 | Link |
Totally Clueless
avs2pipe
avs2pipe is a tool to output y4m video, wav audio, dump some info about the
input avs clip or suggest x264 blu-ray encoding settings. Usage: avs2pipe [audio|video|info|x264] input.avs audio - output wav extensible format audio to stdout. video - output yuv4mpeg2 format video to stdout. info - output information about aviscript clip. x264bd - suggest x264 arguments for blu-ray disc encoding. Download: http://doobrymedia.com/avs2pipe-0.0.3.zip It simply takes a path to an avs script that returns a clip with audio and/or video and outputs it as a y4m (--video) or wav (--audio) stream to stdout. It can also generate information about the clip (--info) in an easily parsable format for gui's. The advantage of avs2pipe over other solutions, other than it doing multiple things in one and supporting more colorspaces is that it links directly with avisynth.dll via the C interface, so it compiles with both Visual Studio and MinGW and when used with wine in linux simply requires that the avisynth dll's are in PATH, so no need to have vfw configured correctly. Also as it uses WAVE_FORMAT_EXTENSIBLE for wav output and directly takes data from avisynth it will output exactly the same data as avisynth uses internally. Source is provided in the src folder and is released under the GPL-3.0. In addition to the source is: src\avisynth25 - header and link lib from AviSynth 2.5.8 src\avisynth26 - header from http://git.videolan.org/?p=x264.git;...th_c.h;hb=HEAD link lib from AviSynth AVS 2.6.0 Alpha 2 [090927] Projects and scripts to build the source are located in: vs2010 - Project for Visual Studio 2010 Express mingw - Batch file MinGW on Windows, sh script for MinGW under Linux The YUV4MPEG2 output is inspired by Avs2YUV by Loren Merritt, it is basically the same method, converted from C++ to C. The changes are: Interlaced Support - Picks up the flags for interlaced content from AssumeFieldBased(), AssumeTFF() etc. and will pass this on to programs such as x264 eliminating the need to add flags to the encoder command. Extended Color Spaces - Thanks to Chikuzen when compiled against AviSynth 2.6 there is support for a whole host of extra colorspaces. The WAV output is coded from scratch using specs from "the internet" and so could be full of problems, altho I have not found any in testing yet. Examples: avs2pipe info input.avs avs2pipe info input.avs > info.txt avs2pipe video input.avs | x264 --stdin y4m - --output video.h264 avs2pipe audio input.avs | neroAacEnc -q 0.25 -if - -of audio.aac avs2pipe audio input.avs > output.wav Included Binaries: avs2pipe_gcc.exe - compiled with MinGW gcc 4.5.2 on Windows avs2pipe_vs.exe - compiled with Visual Studio 2010 Express cl 16.00.30319.01 avs2pipe26_gcc.exe - gcc compiled for AviSynth 2.6 Alpha 2 avs2pipe26_vs.exe - VS2010 compiled for AviSynth 2.6 Alpha 2 Changes: Version 0.0.3 - Added Blu-Ray x264 command generator based on specs from http://sites.google.com/site/x264bluray/ Added Support for new Colorspaces in AviSynth 2.6 with code written by Chikuzen Version 0.0.2 - Added Support for Interlaced Output, AssumeFieldBased etc. Version 0.0.1 - Removed Progress Output for "Speed" Pre-Alpha - Initial Release on doom10.org Forum Links: Original - http://doom10.org/index.php?topic=759 Doom9 Continuation - http://forum.doom9.org/showthread.php?t=160383 --- Hi, Last year I wrote a little program called avs2pipe which combines avs2yuv and wav output into a single program. The main advantage over the current solutions, and the reason I wrote it, is that it is in C and so can be compiled with gcc (mingw) under linux, or visual studio, and when used in a "wine" environment just requires the avisynth dlls to operate. However I abandoned it as it worked for my task and no one really seemed that interested, but I just found people refering to it on google, so... Is there anyone who would be interested in a newer build with the logging removed / optional to increase speed? Last edited by doobry; 4th April 2011 at 18:12. Reason: New Version |
#2 | Link | |
typo lover
![]() Because you did not reply to Underground78 for a long time, I thought that you had stopped that work.
my repositories |
#3 | Link |
i am interested too..
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
#6 | Link |
Totally Clueless
ok i'll pull out the sources from my dead projects and get it checked and uploaded tomorrow.
as for the channel mapping, at the moment it doesn't remap any channels, but i wrote the wav output from scratch using the specs I found on the internet, so it should be "100%-compliant Wave-Format-Extensible", the urls for the specs should be in comments in the source, so if i can work out channel mapping it will not be hard to add it, the main challenge would be parsing the command line options, as the current method simply matches the first argument. as for ubuntu and mac os x, assuming you have a working wine install, it should just work... you would only need mingw if you wanted to compile it yourself. |
#7 | Link |
![]() Join Date: Feb 2005
A program like this don't need make channel mapping.
The channel mapping is a encoder/decoder job. There are enough AviSinth audio decoders than work fine. @space1999 wavi works fine, maybe is a decoder problem, can you put some sample.
#8 | Link |
Banned
@tebasuna51
This is really weird, but I swear, some weeks ago, Media Player Classic refused to play a 3.0 WAV file written by wavi, but today, the same file is accepted fine, ![]() ![]() ![]() Anyway, here goes an example of the difference between the WAVs outputted by wavi and the WAVs rewritten by sox: Code:
from wavi: 52 49 46 46 3C 61 52 01 57 41 56 45 66 6D 74 20 28 00 00 00 FE FF 03 00 80 BB 00 00 00 65 04 00 06 00 10 00 16 00 10 00 07 00 00 00 01 00 00 00 00 00 10 00 00 80 AA 00 00 38 71 9B 64 61 74 61 00 61 52 01 00 00 00 00 00 00 00 00 00 00 00 00 from sox: 52 49 46 46 3C 61 52 01 57 41 56 45 66 6D 74 20 28 00 00 00 FE FF 03 00 80 BB 00 00 00 65 04 00 06 00 10 00 16 00 10 00 00 00 00 00 01 00 00 00 00 00 10 00 80 00 00 AA 00 38 9B 71 66 61 63 74 04 00 00 00 80 65 38 00 64 61 74 61 00 61 52 01 |
#9 | Link |
Totally Clueless
@tebasuna51
the initial problem that I had was that all the audio 2 pipe type programs for avisynth did not "work fine", all the ones I could find were just vfw programs, or are written in .NET etc, which for me under wine was causing problems. avs2pipe directly links with the avisynth.dll which solved me a lot of problems under linux and gives direct access to any avisynth stuff. As far as I can tell wavi etc just use vfw and so have no real idea about avisynth at all. as for the channel mask, the support is "already" in there, it just sets the mask to 0 at the moment, so i could add wavi style support of just specifying the mask as an int at the command line, but that seems a little user unfriendly. a suggestion for how it should work from a users point of view is welcome. i could for example let people specify a variable in the avs script and pull it out. @space1999 one of them programs is using a different endianness to the other for the subformat waveex field, which means one of them probably has a mistake in it. next post should be the same thing as was on doom10, but without progress reporting... Last edited by doobry; 1st April 2011 at 08:28. |
#10 | Link |
Totally Clueless
Here is the zip file with the source, updated visual studio project files, a batch script to build it on windows using mingw and two pre built binaries...
http://doobrymedia.com/avs2pipe-0.0.1.zip Comments and suggestions are more than welcome. @tebasuna51 if you could have a look at the source for anything stupid I'd be grateful, the wav handling is mostly in wave.c and wave.h and is pretty heavily commented as I was trying to work it all out from the specs. |
#11 | Link |
Totally Clueless
from wavi: 52 49 46 46 3C 61 52 01 57 41 56 45 66 6D 74 20 28 00 00 00 FE FF 03 00 80 BB 00 00 00 65 04 00 06 00 10 00 16 00 10 00 07 00 00 00 01 00 00 00 00 00 10 00 00 80 AA 00 00 38 71 9B 64 61 74 61 00 61 52 01 00 00 00 00 00 00 00 00 00 00 00 00 from sox: 52 49 46 46 3C 61 52 01 57 41 56 45 66 6D 74 20 28 00 00 00 FE FF 03 00 80 BB 00 00 00 65 04 00 06 00 10 00 16 00 10 00 00 00 00 00 01 00 00 00 00 00 10 00 80 00 00 AA 00 38 9B 71 66 61 63 74 04 00 00 00 80 65 38 00 64 61 74 61 00 61 52 01 Grabbed a sample from http://www-mmsp.ece.mcgill.ca/docume...E/Samples.html and it matches sox and myself, the endianess I think can be architecture specific, but as everything is running on x86/x64 I believe they should match. Last edited by doobry; 1st April 2011 at 17:11. |
#12 | Link |
typo lover
It seems that ver 0.0.1 is only support YUV420 on video.
Do you have any schedule for supporting other colorspaces (YUV422/YUV444) and latest YUV4MPEG2 format?
my repositories Last edited by Chikuzen; 1st April 2011 at 13:59. |
#13 | Link |
Totally Clueless
@Chikuzen
I have no schedule for supporting other colourspaces, as I have nothing to test against, i.e. samples, encoders, players, and have not seen the YUV4MPEG2 specs. However I'm more than willing to have a go at adding it if someone comes up with a way for me to test it, and some specs. At the moment it simply adds a ConvertToYV12 filter to anything that is not YV12. FYI, a quick google turned up http://wiki.multimedia.cx/index.php?title=YUV4MPEG2 is that what you mean by the new format? Update: I've had a play and avisynth 2.58 doesn't support YUV422/YUV444 so I assume you are using 2.6, and if so where did you get it, and can you give me a link to the sources. Last edited by doobry; 1st April 2011 at 17:12. |
#14 | Link | |
typo lover
and you will be able to test about YUV422 by using rawsource.dll . http://forum.doom9.org/showthread.ph...66#post1470266
my repositories |
#16 | Link |
typo lover
I'm using 2.6.0alpha2(x86) now. http://forum.doom9.org/showthread.php?t=149113
but that RawSource.dll is for 2.5. 2.6.0alpha is completely compatible with 2.5.6 or later. If you want to develop for 2.6 or later, then see manao's code. http://forum.doom9.org/showpost.php?...&postcount=473 it includes 2.6 header file.
my repositories Last edited by Chikuzen; 1st April 2011 at 14:40. |
#17 | Link |
Totally Clueless
From what I can tell avisynth 2.5 does not support YUV422/YUV444 colourspaces, so if i add support for them it will have to be for 2.6 only.
Had a look at the rawsource source code, and it seems to "mangle" for want of a better word the input into one of the 2.5 supported formats. I'm not sure exactly what your requirement is, I assume you want to be able to output YUV422 video from avisynth and have avs2pipe provide it as YUV4MPEG2 output without any conversion? If that is the case could you provide me with a small sample of your input YUV4MPEG2 and avs script so I can have a play with it. Thanks for the header link, but I need the c header avisynth_c.h and the .lib to link with, really I'd like to track down the cvs people are using, but the sourceforge one seems stale, and it seems 2.6 is mostly passed about via forum links to random hosts, which is not good if i'm trying to develop against it. Last edited by doobry; 1st April 2011 at 14:51. |
#18 | Link |
typo lover
ah, i understood what you say.
I must study how to write the code that convert YUY2 to Planar YUV422.
my repositories |
#19 | Link |
Totally Clueless
I'm pretty much willing to add any support that people want, provided I can do it, all I really need is a test case and samples so I can make sure it works.
Personally I don't have any current use for anything other than 420 as I've only got DVD / BluRay sources, but I can see how it could be useful, so I'm willing to stick it on the todo list and add some macro's to enable 2.5 & 2.6 builds. Altho in this case I'm kinda stuck without an updated C interface that has support for the colourspaces. However this has all caused me to add interlaced video support to the YUV4MPEG2 header, which I'm testing now, means I can convert interlaced mpeg2 to interlaced h264 without specifing extra options to x264. PS. When you learn how to "convert YUY2 to Planar YUV422" please share the info with me, I'm clueless on these formats. |
#20 | Link | ||
Avisynth language lover
http://avisynth2.cvs.sourceforge.net...nth2/avisynth/ Quote:
Chikuzen posted the link to the current 2.6 release (see above). Perhaps you are thinking about the various unofficial MT builds floating around. |
avs2pipe |
