Old 25th March 2011, 23:34   #1  |  Link
nevcairiel
LAV CUVID Decoder - High Quality Hardware decoding for NVIDIA
LAV CUVID is DEAD. All of its functionality has been merged into LAV Video. LAV CUVID will not be developed any further.
Hi folks,
i would like to introduce my LAV CUVID Decoder.
It is a DirectShow Video Decoder utilizing the NVIDIA hardware decoder engine through the CUDA Video Decoding API ("CUVID").
Its still in its early stages, but its already been tested thoroughly and supports all major formats that the NVIDIA hardware can decode, which are right now H264, VC-1, MPEG2 and MPEG4-ASP (DivX/Xvid). Both progressive and interlaced types are supported.
As a bonus, when decoding interlaced content, it can do full adaptive deinterlacing, the best your GPU has to offer.
So, without further introduction, here it is!
Features
- Decoding of H264, VC-1, MPEG2 and MPEG4-ASP (each given appropriate hardware support)
- Full Adaptive Deinterlacing, including Frame Doubling (perfect smooth playback of 1080i/60 content!)
- Usable with all renderers! Including madVR, which is recommended for the best playback quality!
- NV12/YV12 output
Download
Source Code is available from my Git repository
Binarys are available here:
Version 0.13: Installer (32/64-bit, CUDA 4.0+) - 32-bit (CUDA 4.0+) - 64-bit (CUDA 4.0+) -- 32-bit (Older CUDA)
A note on the different versions: The CUDA 4.0 builds require a 270 series driver (or newer). The "Old CUDA" build should in theory work with much older drivers, in case you cannot upgrade.
Changelog -- Full changelog -- Release Notes
0.13 - 2011/09/13
- Improved resource release behavior
- Improved VC-1 in EVO with pulldown flags
Old 25th March 2011, 23:35   #2  |  Link
nevcairiel
This is a decoder for NVIDIA GPUs, it does not work with ATI/AMD or Intel, and it never will!
Requirements/Recommendations
- NVIDIA PureVideo HD capable graphics card (VDPAU Feature Set A or better - see list here)
- At least 256MB of Video RAM, 512MB recommended
- Recent NVIDIA Drivers - CUDA 4.0 compatible driver recommended (270 series), older drivers may work with the "Old CUDA" build.
- Vista/7 recommended due to much improved driver handling, but XP SP3 "should work" (see hints below)
Performance
- 1080p60 decoding is only supported on VP4 hardware (VDPAU Feature Set C)
- When encountering performance issues, turning off the "HQ DXVA processing" option will yield the best gain in performance, at a minimal loss of quality.
- Using the latest driver (275.33 at the time of writing), can greatly improve the performance.
Hints
- When running on Windows XP, its recommended to turn the "Use HQ DXVA processing" setting off, its not fully supported on XP and might cause image corruption.
Known Issues
- The decoder will try to decode all video streams, and not refuse formats that are not supported.
- VC-1/MPEG4-ASP VFR content will most likely not play properly.
reserved for FAQ, etc.
Old 25th March 2011, 23:42   #3  |  Link
nevcairiel
To say a few words about 0.1:
First: This is a very early test version, it can quite possibly blow up.
It comes without any configuration, and its only tested on VP4 (Fermi) hardware.
In the future, you will be able to configure things like:
- Use Stream Aspect Ratio (currently always on)
- Which Codecs should be active
- Should Deinterlacing be performed (currently always in "adaptive" mode)
- And whatever i can think of.
Also, it only supports NV12 output. This might change in the future, but any conversion of course gives you a performance penality, and NV12 is the native format of the decoder.
Oh, and if you're using it together with LAV Splitter on interlaced VC-1, make sure to disable the VC1 timestamp correction in the LAV Splitter settings. The next version of LAV Splitter will have this decoder added to the auto-detect mode.
BTW, if anyone is good with assembler, i could need some asm function which changes the stride of a NV12 image. My C implementation is probably quite slow.
Old 25th March 2011, 23:46   #4  |  Link
Sebastiii
Amazing
Can't register filter, maybe need minimum driver version or hardware (9600GT) ?
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 25th March 2011, 23:46   #5  |  Link
adam777
Hi nev,
I'm unfortunately unable to utilize this decoder due to my laptop being equipped with an ATI card, but I suggest writing as clear as possible why ATI can't be supported, at least for the foreseeable future.
I suppose it won't be long before this question starts popping up.
adam777 is offline   Reply With Quote
Old 25th March 2011, 23:51   #6  |  Link
BatKnight
BatKnight's Avatar
When I use your LAV CUVID Decoder to play a 1280x688 movie at a 1920x1080 resolution in MPC-HC, what is doing the upsample? My GPU? The MPC-HC?
When I used ffdshow I had an Avisynth script to spline36resize my videos to 1920x1080, but when using CUVID I no longer know if it is being done by the graphics card (would this be a good thing, quality-wise?) or being done by what I have selected at the MPC-HC Resizer's drop-down box.
Nuno
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers
MPC Home-Cinema
madVR
LAV Filters
BatKnight is offline   Reply With Quote
Old 25th March 2011, 23:52   #7  |  Link
nevcairiel
The decoder does not do any upscaling, so it'll be the renderer MPC-HC uses.
Which driver are you using?
The CUDA SDK 3.2 is relatively new (Jan. 2011), could be that you need at least a 260 series driver.
I can probably use a bit older SDK, and switch to dynamically loading the dlls, so such issues can be avoided.
For Hardware Support, Wikipedia to the rescue. You need at least VDPAU Feature Set A for H264 decoding, B for VC-1 and MPEG2, and C for MPEG4-ASP.
http://en.wikipedia.org/wiki/Nvidia_..._.28HD.29_GPUs
The 9600GT is a "A" Feature Set, so at least you get H264 decoding out of it.
Old 26th March 2011, 00:08   #8  |  Link
SamuriHL
SamuriHL's Avatar
Oh sure. This gets released while I was just forcing my bedroom machine to use software decoding temporarily while I waited. Guess I'll go back in there and get this set up. Thank you so much, Nev!!!
Old 26th March 2011, 00:16   #9  |  Link
BatKnight
BatKnight's Avatar
I am getting dropped frames every 5 seconds approximately when playing 1920x1080 movies, either AVC or VC-1.
I get smooth playing on 720p movies or others.
My specs are in my signature.
At the moment of playing my GPU is at 20% usage at most, measured by EVGA Precision.
I've tried EVR Custom and EVR Sync, and every option in MPC-HC, and all kind of combinations don't make a difference.
BUT, maVR is flawless. No dropped frames at all. In fact it solved my dropped frames problem with madVR when using ffdshow.
But, why is EVR Custom and Sync dropping frames?
How can I help you debug this?
Nuno
MPC Home-Cinema
madVR
LAV Filters
Old 26th March 2011, 00:17   #10  |  Link
bjd
@nevcairel
This really is impressive work. Just testing it with my bluray collection - awesome performance with 1080p VC-1,AVC and MPEG2. No issues on a GT430 just simply amazing PQ via MadVR.
Also tested on some MPEG2 576P/50i material - works a treat.
bjd is offline   Reply With Quote
Old 26th March 2011, 00:19   #11  |  Link
nevcairiel
Not sure whats going on there. Do you have frame time correction on in EVR? Try enabling/disabling it, depending what you had before.
My movies play just fine in EVR Custom as well as madVR.
Old 26th March 2011, 00:22   #12  |  Link
SamuriHL
SamuriHL's Avatar
Ok, initial impressions. WOW! This is AWESOME! My "problem" MKV that nothing does well is Golden Compass. It's a blu-ray rip and is VC-1. Nothing really plays it well, including DXVA, at 24Hz. Before I came out and saw you had released this, I had set up ArcSoft video decoder to handle VC-1 decoding. It pegged the CPU but was decent enough to watch. With your decoder, CPU utilization went down to about 25% or so, which for that machine, is VERY good. Had no problems with subtitles or video. Next up was an AVC MKV blu-ray rip. CPU was again good, but, unfortunately, when skipping around in the video to test certain parts I got a very odd thing going on. It gives me a green block overlay in the middle of the screen. It comes and goes quite a bit. I haven't tried other AVC movies to see if that's reproducible or not. Don't forget that my goal here is to pump this out to madVR in MPC-HC, so, that's how I'm testing this. I didn't see these issues with CoreAVC on that same video.
Old 26th March 2011, 00:38   #13  |  Link
BatKnight
BatKnight's Avatar
Nope, it was off, but enabling it didn't change anything.
The graph is a mess, even playing at 24Hz I used to have a perfect straight green line, but with CUVID it is a mess, full of spikes.
I've found that disabling Wait For Flushes stops the dropping frames but now I get noticeable tearing and stuttering.
But like I said, madVR is almost perfect.
Any ideas?
Nuno
MPC Home-Cinema
madVR
LAV Filters
Old 26th March 2011, 00:42   #14  |  Link
sneaker_ger
Thank you.
I did a short test with a 9200M GS (VP3 feature set B) and it will attempt to open ASP, which is bound to fail of course: the screen stays black. H.264 and VC1 worked fine in a short test. It will also attempt to decode H.264 with the resolutions not supported by VP3 which will also result in a black screen.
Old 26th March 2011, 00:45   #15  |  Link
sneaker_ger
Amazing
Did you install the VC++2010 runtime components yet?
Old 26th March 2011, 00:59   #16  |  Link
BatKnight
BatKnight's Avatar
More feedback.
I've done testing and testing and got to a conclusion: When playing an AVC/H.264/x264 1920x1080 MKV the audio doesn't match/sync with lips after seeking. This happened on all my AVC movies. This only happens with 1920x1080 AVC videos, with 1920x800 or lower then I can't reproduce it...
With VC-1 movies the audio matches/syncs perfectly with lips and I've randomly seeked and couldn't make it unsync.
Nuno
PS: Tested it with madVR, with Aero on and off
MPC Home-Cinema
madVR
LAV Filters
Old 26th March 2011, 01:37   #17  |  Link
yesgrey
nevcairiel,
I just want to say a big thanks!
I was hoping that someone would bring something like this, so that I could be able to watch those WVC1 interlaced music concerts with hardware deinterlacing. It's working very good with me.
Old 26th March 2011, 02:02   #18  |  Link
Sebastiii
Yep
I think it's nev answer me need recent driver and surely more recent video card
Thanks, will update this soon
Old 26th March 2011, 02:06   #19  |  Link
ranpha
Running my test files over this decoder (testing mostly XviD files first), but I am very impressed by the decoder-level deinterlacing capabilities.
ranpha is offline   Reply With Quote
Old 26th March 2011, 02:09   #20  |  Link
SamuriHL
SamuriHL's Avatar
No one else is seeing the issue I'm having with a greenish rectangle showing up in AVC playback?
