Old 2nd March 2013, 07:31   #14321  |  Link
itsonlyjustincase
Hi could you help me ? I have run CCLEANER and uninstalled all codecs. Then when i try to install LAV filters (last version) only the 64 bits are present (i verify with Win7DSFilterTweaker_5.7). It seems my win 8 pro (official) doesn't allow me to install 32 bits codecs anymore :s even if there is no error at the installation
itsonlyjustincase is offline   Reply With Quote
Old 2nd March 2013, 09:32   #14322  |  Link
marc99
Originally Posted by Aspeh View Post
Good Question
Can any experts answer this as i'm looking to upgrade my XP machines to Win 8 and was thinking of getting the N version as well as it doesn't have any Media player installed.Or would i be better getting the standard Windows 8 pro version for the WMV9 DMO decoder WMV3 and VC-1 option ???
"Windows Media Feature Pack for Windows 7 N and for Windows 7 KN.
The Media Feature Pack for N and KN versions of Windows 8 will install Media Player and related technologies on a computer running Windows 8 N or Windows 8 KN editions."
http://www.microsoft.com/en-us/download/details.aspx?id=30685
Windows 7 RC 64bit, NVidia GF8600GT 190.38
marc99 is offline   Reply With Quote
Old 2nd March 2013, 10:09   #14323  |  Link
Aspeh
Thanks for the reply's but it's not what i ment or what i think Blexley was asking either.
At the bottom of Lav Filters video configuration is Use Microsoft WMV9 DMO decoder WMV3 and VC-1
Would it be better to have Windows Media Player installed to use this Lav option?
Aspeh is offline   Reply With Quote
Old 2nd March 2013, 11:27   #14324  |  Link
itsonlyjustincase
Someone ?
Old 2nd March 2013, 20:30   #14325  |  Link
Tornado15550
I've heard that LAV dithers 10bit/14bit video (from a Hi10P or Hi444P file) down to 8bit.
Is this true?
Tornado15550 is offline   Reply With Quote
Old 2nd March 2013, 20:37   #14326  |  Link
nevcairiel
Only if its required, because your renderer doesn't support 10-bit content for example. Untouched is always preferred, but not always possible. If you use madVR, you should get untouched.
Old 2nd March 2013, 21:59   #14327  |  Link
aufkrawall
afair libav supports Dxtory codec for some time now.
Could you add support for it in LAV, nev?
Old 2nd March 2013, 22:21   #14328  |  Link
nevcairiel
Sample?
Old 2nd March 2013, 23:20   #14329  |  Link
aufkrawall
Tomorrow, got not enough upload bandwidth today.
Old 3rd March 2013, 10:05   #14330  |  Link
blexley
Thankyou Aspeh that is exactly what i'm trying to get an answer for aswell.
Nevcairiel is always saying that Win XP is a problem yet when asked about a Lav filters setting for Windows 8 he rudely ignores people.
Go figure.
blexley is offline   Reply With Quote
Old 3rd March 2013, 10:16   #14331  |  Link
sneaker_ger
Or maybe he simply doesn't know the answer because he's not using Windows 8 N?
I remember reading that Windows 7 N does indeed not have the codecs in addition to not having the media player, so I would not get the N version. I don't know if this applies to Windows 8 as well.
Old 3rd March 2013, 10:25   #14332  |  Link
blexley
That still doesn't answer the question as that is not what is being asked.
Is it better to use that option if available or is it not needed ?
If it's not needed or doesn't give any advantage over Lav filters for WMV9 DMO decoder WMV3 and VC-1 then you don't need mediaplayer installed.
A developer doesn't need a version of windows installed to know if an option is best used or not because knowing if it's best used or not then the rest can be worked out by ourselfs.?
Thanks
Old 3rd March 2013, 10:45   #14333  |  Link
Superb
Geez.
If you have the DMO Decoder installed -> The option will work.
If you don't have the DMO Decoder installed -> Initializing the decoder will fail.
http://code.google.com/p/lavfilters/source/browse/decoder/LAVVideo/decoders/wmv9.cpp
  hr = CoCreateInstance(CLSID_CWMVDecMediaObject, NULL, CLSCTX_INPROC_SERVER, IID_IMediaObject, (void **)&m_pDMO);
  if (FAILED(hr)) {
    DbgLog((LOG_TRACE, 10, L"-> Failed to create DMO object"));
    return hr;
Will it fall back to software? Probably. Didn't have a closer look at the code.
No one owes you any answers, and therefor it isn't rude to ignore you. Welcome to the internet.
Also, support given by nev in this thread is much better than MANY open source developers I've seen on the net... so don't b!tch. :P
Superb is offline   Reply With Quote
Old 3rd March 2013, 10:46   #14334  |  Link
nevcairiel
This is also "software". And no, there is no fallback. It'll refuse connection if the option is enabled and init fails.
In any case, LAVs default settings are the recommended settings (why would anything else be default?), you can figure it out from there.
Old 3rd March 2013, 10:47   #14335  |  Link
sneaker_ger
Just because he develops LAV Filters does not mean he magically knows whether Windows 8 N has the things needed for these LAV Video options. You didn't ask whether these were "best used" or not. If Nev didn't think they were needed he wouldn't have added the function to LAV Video to utilize them and definitely wouldn't have activated them by default.
Old 3rd March 2013, 11:11   #14336  |  Link
Aspeh
I'm not sure if you guys are just naturally rude and obnoxious or it's a case of Asperges.
How can anybody know apart from you if LAV can decode DMO without microsoft codecs and if this would be the default option if installed on a version of windows without mediaplyer.
Ridiculous to expect us to buy Windows 8 N to find out when you could just simply answer if Lav Filters prefers to use Windows Media DMO or not and without it if it would limit media playback.
No need for anyone to be a complete ass over it like media is some sort of leet club.
Old 3rd March 2013, 11:16   #14337  |  Link
nevcairiel
If it didn't have any advantages, it wouldn't be the default.
So concluding from that, disabling it does give you disadvantages.
Obviously this option only works if the DMO decoder is present in your system. If this is the case on a "N" install? I don't know. Feel free to find out and report your findings.
You're the one being rude, there is no magic secrets here, just logical conclusions anyone can arrive at.
Old 3rd March 2013, 11:21   #14338  |  Link
blexley
It doesn't say anywhere and you gave no indication that enabled was the default setting and was recommended.
That is what was being asked.
Sheeeeesh
Old 3rd March 2013, 11:35   #14339  |  Link
aufkrawall
Here is one Dxtory sample:
http://www36.zippyshare.com/v/60688661/file.html
There can be also different colorspaces and compression.
Old 3rd March 2013, 12:01   #14340  |  Link
nevcairiel
It doesn't seem like the decoder likes this file, i get a lot of errors and no image.
It appears it uses a variant of the codec not supported yet.
