Old 11th May 2012, 05:47   #10921  |  Link
Andy o
Remuxing is for the most part dependent on HDD speed, or of course blu-ray drive speed. Interesting about DVDFab though. With LAV, I guess copyback would be an option for me if I do buy or build a new PC, since NV cards with my receiver are just annoying (yeah, yeah, I know I'm always going on about this ). My conundrum then would be that if it's a laptop, I want an NV card cause of Optimus. The new HP DV6t quad is looking mighty good.
GA-Z87MX-D3H (Intel Z87), i7-4770, AMD 7790, Win8.1-64
Pioneer VSX-01TXH, Pioneer KRP-500M
Andy o is offline   Reply With Quote
Old 11th May 2012, 07:15   #10922  |  Link
Mikey2
Has anyone had any problems using NVIDIA CUVID with 2 cards in SLI-mode? On other hardware decoders, including MPC-HC's internal one and even CoreAVC, the Video Decoding is done on the secondary card/GPU, thus leaving the primary card to do the rendering. However, according to GPU-Z, hardware decoding with LAV is being done on the primary card. This hurts my performance since everything is being run on one GPU, leaving the second one doing nothing. (Even CoreAVC runs more smoothly with fewer glitches than LAV Video Decoder on my system because of this!)
I can always go back to Software Decoding; however, I am running some CPU-intensive avisynth scripts, so I would like to free-up the CPU by doing decoding on my GPU...
Thanks much in advance for your help!
MikeY
Mikey2 is offline   Reply With Quote
Old 11th May 2012, 08:41   #10923  |  Link
Mercury_22
@NEV After the last ffmpeg update the building it's failing with the same old error "library.mak:95: *** missing separator. Stop."
Builds fine for me, must be on your end.
You should make sure ffmpeg is checked out with LF line endings (set git config core.autocrlf to "false" or "input", not to "true")
Edit:
I also fixed it in the repository that it shouldnt be needed anymore.
Can you please fixed it again in the repository ?
Windows 10 x64 CU, HD7790 Crimson 17.6.2, HDMI Full RGB 4:4:4
Mercury_22 is offline   Reply With Quote
Old 11th May 2012, 08:44   #10924  |  Link
nevcairiel
You should really fix your local setup.
Old 11th May 2012, 09:04   #10925  |  Link
Mercury_22
OK but now I'm getting
C:\Users\Administrator>cd C:\LAVFilters
C:\LAVFilters>git pull git://git.1f0.de/lavfsplitter.git
fatal: bad config value for 'core.autocrlf' in C:\Git/etc/gitconfig
C:\LAVFilters>git submodule update
C:\LAVFilters>pause
Press any key to continue . . .
What am I doing wrong ?
Old 11th May 2012, 09:05   #10926  |  Link
nevcairiel
OK but now I'm getting What am I doing wrong ?
Clearly, something is wrong.
it should be set to "false" or "input" to avoid the ffmpeg issue.
I just pushed a fix for the original issue, though.
Old 11th May 2012, 09:13   #10927  |  Link
Mercury_22
Working now
I was getting that error after changing it to "false" or "input"
After setting back to "true" and your update it's working again
Could it be cause I'm using http://code.google.com/p/msysgit/dow...09.7z&can=2&q= without any modifications ?
Old 11th May 2012, 12:22   #10928  |  Link
SamuriHL
SamuriHL's Avatar
Why do think I put a 256gb vertex 4 in my new machine, Andy. transcoding is very fast when read from an ssd and written to a fast he'd.
Sent from my Xoom using Tapatalk 2
HTPC1:W10 Creator Edition, I7 3770k, GTX 1060, Pioneer Elite SC-65, Panasonic 65" 1080p Plasma
Laptop: MSI GT70 Dominator
Old 11th May 2012, 15:26   #10929  |  Link
Andy o
Sure, I wasn't saying that transcoding can't be HDD dependent, especially with those crazy speeds QS gives you, only that remuxing usually is, unless you have a very old CPU with a relatively new hard drive.
Old 11th May 2012, 15:57   #10930  |  Link
SamuriHL
SamuriHL's Avatar
I can tell you that whatever QS is doing, it's super fast compared to even CUVID. CUVID transcoding takes almost double the time. I'm wondering if QS is better with LAV than CUVID? I've not had any issues with it, but, I simply meant is there some theoretical advantage using QS vs CUVID for decoding?
Old 11th May 2012, 16:02   #10931  |  Link
nevcairiel
QS is faster, so seeking may be faster in some situations. QS may also use less power, because in default mode any CUDA access forces 3D performance clocks. Not sure if thats still valid for 6xx cards though, they redid power/performance management.
Old 11th May 2012, 16:03   #10932  |  Link
SamuriHL
SamuriHL's Avatar
Interesting. Maybe I'll set that up again and check it out. I'm really liking the 680 a lot so far. Hell, I'm really enjoying the whole machine. But I'm now nVidia on both HTPC's which I consider a good thing. Now I have options...
Old 11th May 2012, 22:24   #10933  |  Link
nevcairiel
LAV Filters 0.50.3
LAV Splitter
- Fixed playback of raw PCM in AVI streams
- Fixed a rare misdetection of MPEG-2 as VC-1
LAV Video
- QuickSync: Fixed playback of some H.264 streams that would run out of sync on newer drivers
- Fixed a memory leak when playing H.264 RGB (and some other formats)
- Improved behaviour for H.264 and MPEG-2 on Live TV channel changes
LAV Audio
- Added support for Speex (via libspeex)
- Improved support for AMR-NB/WB (using OpenCore decoder)
Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Another small bugfix release, nothing big and special. Maybe for some people Speex support may be useful. Note that it only works really well with LAV Splitter.
Something some people already noticed, i created a Git clone of the QuickSyncDecoder repository, and added it as a new submodule into my Git tree.
This makes integrating it into the build process and debugging much easier. It should hopefully also make building the whole package a bit easier for everyone else.
I still plan to work on audio mixing as the next big project, just not sure when i'll find the time exactly.
In the meantime, take care and have fun!
Old 11th May 2012, 22:56   #10934  |  Link
Sebastiii
Nice
Big thanks.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 11th May 2012, 23:16   #10935  |  Link
terence_13
Originally Posted by Leapo View Post
Guess there's still no option for DXVA + Subs on AMD graphics cards
??? I am puzzled, of course there is: ffdshow dxva (dont forget to enable postprocessing) together with Media Control
http://sourceforge.net/projects/mediacontrolmce/files/
terence_13 is offline   Reply With Quote
Old 11th May 2012, 23:20   #10936  |  Link
DragonQ
Nev, I'm having trouble with files that have had cuts made in TS-Doctor, which is configured to use LAV Splitter and LAV decoders. I always make edits at key frames, trying to avoid issues.
When I playback this sample, the edit point (at ~19 seconds) plays as you would expect when using MadVR + software decoding (LAV 0.50.3). However, it briefly goes a bit weird when using EVR + software decoding (minor flashing). The main issue is when using EVR + DXVA2 Native (nVidia) - it basically goes mental (a lot of flashing and the audio cuts out for about a second).
Is this something that can be fixed? If it's a problem with how the file is put together then I'd appreciate any info you can provide so I can pass it on to the author of TS-Doctor (who is very good at helping on his forum and fixing bugs).
Thanks!
HTPC Hardware: Intel Celeron G530; nVidia GT 430; OCZ Vertex 2 (120 GB)
HTPC Software: Windows 7; MediaPortal 1.16.0; Kodi 17.3; LAV Filters (CUVID); MadVR
Old 12th May 2012, 07:37   #10937  |  Link
nevcairiel
ffdshow dxva has serious issues with subtitles, it will cause corruption on certain files.
You cannot just modify the surfaces of the video to add subtitles, because those surfaces are still used as reference frames.
Old 12th May 2012, 07:57   #10938  |  Link
nevcairiel
I see no big issues.
It flashes a bit more then software decoding (but still not "mental"), but audio keeps going, and its not really all that bad.
Anyway, you need to make sure the edit is at an IDR frame, not just an I frame.
I didn't look what is in this file, its always a bit hard to find those spots exactly.
Other then that, i dunno.
Old 12th May 2012, 09:18   #10939  |  Link
nevcairiel
LAV Filters 0.50.4
LAV Video
- Fixed seeking with QuickSync running in madVR Exclusive Mode
Some stupid error managed to sneak into the last version, so here is a new one!
Really, only that one commit.
Old 12th May 2012, 09:26   #10940  |  Link
wanezhiling
Excellent!
