Old 23rd April 2012, 22:48   #10561  |  Link
nevcairiel
Originally Posted by andyvt View Post
Just had to comment out some code in LAV, FWIW the ArcSoft TMT filter works too.
I should try to make auto-detection work, but its not like there is alot of content available.
Old 23rd April 2012, 22:50   #10562  |  Link
andyvt
It's an academic problem right now. Only really useful for reviewers
babgvant.com
Missing Remote
andyvt is offline   Reply With Quote
Old 23rd April 2012, 22:56   #10563  |  Link
NikosD
Yep, it's going to be a while before there are consumer 4K displays.
Nevcariel wasn't talking about 4K displays.
He was talking about motherboard limitation of HDMI on Ivy Bridge motherboards.
Nevcariel or someone else, can you post DXVA benchmarks of 4K clips ?
Also what is the QuickSync utilization of 4K clips during normal playback ?
You can use Intels Performance monitor to see that.
What are the benchmark figures of QuickSync 2.0 (Ivy Bridge), using my H.264 video collection ?
Thanks!
Win 10 x64 (17134.1) - Core i3-4170/ iGPU HD 4400 (v.4835)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 23rd April 2012, 23:01   #10564  |  Link
andyvt
How useful is that feature when it's not possible to buy an HDMI displays capable of that resolution? Until that changes, this is an academic annoyance (which is why I addressed what I did).
babgvant.com
Missing Remote
Old 23rd April 2012, 23:10   #10565  |  Link
jakmal
And people in the industry I have seen some people try to play 4K in VLC on a 4 x Eyefinity setup!
Ganesh T S
Sr. Editor, AnandTech Inc.
jakmal is offline   Reply With Quote
Old 23rd April 2012, 23:12   #10566  |  Link
jakmal
Andrew, There is at least one 4K projector available for consumer purchase, the Sony VPL-VW1000ES. I am quite confident that with the Sharp announcement, they will become as common next year as the 2560 x 1600 monitors are right now.
Ganesh T S
Old 23rd April 2012, 23:13   #10567  |  Link
nevcairiel
More importantly, Intel needs to finally address the bug that doesn't reliably let you configure Full Range RGB over HDMI. They have a switch for it, but it doesn't do anything, and it resets on reboots or resolution changes ... very annoying.
Old 23rd April 2012, 23:19   #10568  |  Link
jakmal
Btw, where exactly in the control panel is this setting?
Ganesh T S
Old 23rd April 2012, 23:20   #10569  |  Link
nevcairiel
Display -> Monitor / TV Settings. "Quantization Range"
It only shows up when you actually have a HDMI connection (or DVI->HDMI Adapter), it always gives you full range on pure DVI connections to a PC monitor.
You can trick it into using full-range RGB by creating some custom resolutions, but for some reason its being stupid about it for me, and doesn't accept a bunch of resolutions.
If i don't find a solution, i'll put my old GPU back in there, wrong black levels are a deal breaker. NVIDIA should hurry with their 600 series mid-end/low-end cards, i would get one.
Old 23rd April 2012, 23:25   #10570  |  Link
jakmal
Couple of related questions:
1. Are you able to drive 1080p50 through HDMI using the IVB system ?
2. Is chroma upsampling working well with the latest NV drivers on the Fermi cards ?
Ganesh T S
Old 23rd April 2012, 23:27   #10571  |  Link
andyvt
You know that's $25K?
IVB (and SNB IIRC) support 2560 x 1600 over DisplayPort, which most high res monitors also provide. You might even be able to use a DP->HDMI adapter in the scenario where it doesn't.
babgvant.com
Missing Remote
Old 23rd April 2012, 23:29   #10572  |  Link
nevcairiel
Short of the wrong black levels, yes all the resolutions seem to be working.
As good as the default algorithms can be expected to work, so i guess thats a yes. I think you're confusing AMD with NVIDIA here, i don't think i ever saw chroma issues on a NVIDIA card.
Old 23rd April 2012, 23:30   #10573  |  Link
andyvt
This issue has been raised and an RCR created. They haven't provided a timeline for changing the behavior (the current implementation is by design), but it is in the system.
babgvant.com
Missing Remote
Old 23rd April 2012, 23:31   #10574  |  Link
jakmal
Yes, I have 'access' to one Most of the industry is developing 4K capable gear with that unit as the HDMI sink.. Outside of the home, I see there is a lot of demand for reliable 4K decode and display. A couple of weeks back, I set up a configuration with an AMD A8-3850 doing software decode (avcodec) of a 4K clip and outputting it over a 7750's HDMI port to that projector.
Ganesh T S
Old 24th April 2012, 00:00   #10575  |  Link
CruNcher
CruNcher's Avatar
IVB supports HWA 4K decoding (although oddly the QS decoder doesn't - not sure why) via DXVA2.
nice tests andyvt
liked especialy this one
http://www.missingremote.com/sites/d...dbraketime.jpg
http://www.missingremote.com/sites/d...brakepower.jpg
finally someone who compares this
It was quiete anyoying all the time seeing reviewers show time or fps and then you had only the compare with some artificial power outputs from prime or Game runs totally useless :P
It is about Time
Old 24th April 2012, 00:09   #10576  |  Link
andyvt
Originally Posted by CruNcher View Post
nice tests andyvt
Thanks
babgvant.com
Missing Remote
Old 24th April 2012, 00:11   #10577  |  Link
andyvt
I don't mean to say that it isn't an important feature, just that it's so niche that it's mostly academic. When I can buy a 75-80" 4K PDP for $5K, then it will be a major, blocking, earth stopping problem
babgvant.com
Missing Remote
Old 24th April 2012, 00:16   #10578  |  Link
CruNcher
CruNcher's Avatar
As we can see the Core i7-3770K is the clear winner in the time taken to convert the thirty minute 480i
Is this the same Video you used later on with MediaConverter also ?
if yes excellent (not like other reviewers who change the files from one Software to the next jeez)
It is about Time
Old 24th April 2012, 00:22   #10579  |  Link
andyvt
Yep. Same file.
babgvant.com
Missing Remote
Old 24th April 2012, 00:25   #10580  |  Link
DragonQ
That setting works on my Core i5-430M. Always defaults to TV levels when I plug it into my mum's TV but I need to change it to PC levels to avoid black crush. It does introduce video noise though, which sucks.
HTPC Hardware: Intel Celeron G530; nVidia GT 430; OCZ Vertex 2 (120 GB)
HTPC Software: Windows 7; MediaPortal 1.16.0; Kodi 17.3; LAV Filters (CUVID); MadVR
