Old 8th January 2012, 14:23   #7961  |  Link
CoRoNe
CoRoNe's Avatar
I'd like to report a little bug. Initially reported as a MPC-HC bug by someone else, but it looks like to be a Lav Splitter bug instead.
http://sourceforge.net/apps/trac/mpc-hc/ticket/1933
My hobby website
CoRoNe is offline   Reply With Quote
Old 8th January 2012, 14:34   #7962  |  Link
Paladin77
Originally Posted by Paladin77 View Post
Hi Nev!
I am having issues playing some realmedia files. If I use madVR renderer I get weird diagonal and side green lines. If I revert to EVR I get corruption and sound dropouts. Sample: http://megaupload.com/?d=IQZI23J6
Using latest LAV,madVR, MPC. both lower end system (in sig) and other rig (5650 ATI card).
Thank you so much for you work!
EDIT. Ok initial troubleshooting shows its splitter related. Activating MPC source alleviated the issue. Will test further!
ok It seems LAV splitter doesn't like that specific file. Tried another file and it works well. EVR corrupts and sound drops while madVR I get a nasty diagonal green line.
Motherboard: GIGABYTE GA-990FXA-D3
Processor: AMD FX 8150 Black Edition 8-core @3.6 Ghz.
RAM: G-Skill Ares 16GB dual channel DDR3.
GPU: 2X Crossfire AMD RADEON HD 6850.
OS: Windows 7 Utlimate x64.
Paladin77 is offline   Reply With Quote
Old 8th January 2012, 15:08   #7963  |  Link
nevcairiel
Was a LAV Audio bug, but fixed
Fixed with madVR, didn't encounter issues with EVR
Old 8th January 2012, 15:25   #7964  |  Link
AmshTemp
The installer doesn't check for x64 before installing IntelQuickSyncDecoder.dll.
Source: bin_x64\IntelQuickSyncDecoder.dll; DestDir: {app}\x64; Flags: ignoreversion restartreplace uninsrestartdelete skipifsourcedoesntexist; Components: lavvideo32
Should have been:
Source: bin_x64\IntelQuickSyncDecoder.dll; DestDir: {app}\x64; Flags: ignoreversion restartreplace uninsrestartdelete skipifsourcedoesntexist; Components: lavvideo64
AmshTemp is offline   Reply With Quote
Old 8th January 2012, 15:36   #7965  |  Link
CoRoNe
CoRoNe's Avatar
Lav Audio has nothing to do with this. It's all about the splitter. It hangs/crashes with 0.44.
My hobby website
Old 8th January 2012, 15:42   #7966  |  Link
nevcairiel
Plays just perfectly.
There was a bug that caused it to never output any audio when lav audio was used, which i fixed.
That was also the original bug report.
Old 8th January 2012, 16:36   #7967  |  Link
CoRoNe
CoRoNe's Avatar
You're right, I take it back. Normally I only use MPC-HC, but after having tested the wav-file in Zoom Player and with MONOGRAM GraphStudio, where it plays perfectly fine, I have to conclude that MPC-HC is indeed the culprit, like the guy said.
My hobby website
Old 8th January 2012, 16:41   #7968  |  Link
nevcairiel
But, it works fine in MPC-HC for me.
Old 8th January 2012, 17:38   #7969  |  Link
DragonQ
Possibly, go test it?
I don't use Media Portal, so it might as well have been another error, but an error of that kind was fixed.
OK well I've selected LAV Filters for my LATM AAC decoder in MediaPortal but I don't know when I'll get to test it - I only watch/record Freeview HD channels (which use LATM AAC audio) when my DVB-S2 decoder is in use!
I'll let you know if I get any more problems though.
Old 8th January 2012, 18:48   #7970  |  Link
STaRGaZeR
4:2:0 hater
nev, when seking in this VC-1 file using QS the image freezes. It doesn't hang the player, but it doesn't recover either.
http://www.multiupload.com/2403BDXAFT
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 8th January 2012, 21:40   #7971  |  Link
ajp_anton
ajp_anton's Avatar
Originally Posted by easyfab View Post
I don't think the GPU is that important because QS is a separate hardware transcoder. For example in encoding tasks with QS, you have almost the same speed with a i5 2300 and a i7 2600
It was the shortest way of saying I don't have a pre-Sandy Bridge CPU, and no additional GPU connected.
Anyway, updated drivers and it works now. Didn't think it would make a difference since ffdshow used to work before.
Old 8th January 2012, 22:38   #7972  |  Link
egur
QuickSync Decoder author
Originally Posted by ajp_anton View Post
It seems that when using QS on any video (h264 or mpeg2, don't have vc1) in mkv or mpg with any splitter and any renderer gives a chaotic frame order. GPU is HD3000 (only).
I've seen this before.
Do you have Lucid Virtu installed and and playing using the 64 bit version?
If so, then it's a lucid Virtu bug. Somehow it's mixing the frame order. 32 bit was fine (on 64 bit OS).
Eric Gur,
Processor Application Engineer for Overclocking and CPU technologies
Intel QuickSync Decoder author
Intel Corp.
egur is offline   Reply With Quote
Old 9th January 2012, 02:23   #7973  |  Link
CruNcher
CruNcher's Avatar
@nev
ftp://132.185.142.44/video/maybefina...romo-tr1500.ts plays way to slow (8 FPS) compared to VLC
also can you please add wma lossless to lav audios selection (WMAL) option so that it wont try to playback streams with it and fallback to wmaudio decoder accordingly http://roundup.libav.org/issue421 putting wmaudio decoder above lav audio works too but it's not the correct way of handling it
It is about Time
Old 9th January 2012, 12:01   #7974  |  Link
Pat357
Originally Posted by kolak View Post
I've reinstalled filters and it works now.
It's quite funny- DNxHD encoder is multithreaded, but decoder not. ProRes is opposite
Where are the ProRes and DNxHD codecs available ?
Here is something strange:
I've made AVI Prores file and it works fine except when it's loaded to some software directly it gets decoded in one thread.
When I load same AVI through avisynth (directshow source) than it works fine- all cores are working and speed is good.
Why?
Are you running an MT version from Avisynth ?
I have this often with lossless codecs, where the VfW codec is multithreaded, but the Dshow (Libav, FFmpeg) version is not.
Also the VfW is often more optimized then the Dshow version. (UTVideo, Lagarith,...)
Because you're using directshowsource, you 're basically using the Dshow version, so the speed difference is not clear to me;
the avisynth way should not be noticeble faster unless using MT version....
Can we also have dithering as an option?
I think ditthering is not dependent from the codec, you probably have already dithering if you're using Lav-video.
Pat357 is offline   Reply With Quote
Old 9th January 2012, 12:17   #7975  |  Link
nevcairiel
Intra-only codecs are usually very easy to multi-thread in decoding, because every frame is "stand-alone" and doesn't have to wait for the previous reference frames to be decoded.
Multi-threaded decoding was just recently added to ffmpegs UtVideo decoder. Adding the same for DNxHD would probably be rather easy, someone just has to do it.
Old 9th January 2012, 17:34   #7976  |  Link
egur
QS decoder rev20 is committed.
Changes are:
Added MT copy. A mild performance gain. Added flag to disable it
Fixed bad seeking in VC1 (nev's report). On every seek in every codec, the entire session is destroyed. Works smoothly.
Added flag to report a corrupted frame (what MSDK reports).
Cosmetics.
FYI, I'm not building a version myself ATM, I want to address 2 other issues.
One of them is VC1 decoder sends the same buffer over and over with different time stamps which breaks my code.
Eric Gur,
Intel Corp.
Old 9th January 2012, 18:19   #7977  |  Link
kolak
LAV decoder supports ProRes and DNxHD.
Problem is opposite what you described.
I wrap ProRes into AVI and when it's loaded to some application- eg Premiere it works slow.
If I load it through avisynth (directshowsource) using fake AVI (virtual file system for avisynth) than it's fine- all cores are used. Not sure why it's happening.
Old 9th January 2012, 18:50   #7978  |  Link
STaRGaZeR
4:2:0 hater
Originally Posted by egur View Post
QS decoder rev19 is committed.
Changes are:
Cosmetics.
Looks like you forgot to commit some new files to the repository . Will test it as soon as you upload these.
Old 9th January 2012, 19:10   #7979  |  Link
egur
Working too hard lately...
Rev 20 has the files
Eric Gur,
Intel Corp.
Old 9th January 2012, 20:08   #7980  |  Link
Cyber-Mav
i dont get hardware acceleration on xvid standard definition files. gpu = gtx560 ti.
Cyber-Mav is offline   Reply With Quote
