Old 6th October 2011, 15:32   #6001  |  Link
upyzl
zj262144
upyzl's Avatar
Originally Posted by Calibro View Post
+1
I can't even get Lav Splitter to work no matter what I try.
How do I disable Haali and enable Lav?
you can use Codec Tweak Tool (just 672KB, single exe)
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14
Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated)
upyzl is offline   Reply With Quote
Old 6th October 2011, 16:14   #6002  |  Link
kennae
Originally Posted by roytam1 View Post
Normally if you want to use other (Video/Audio) decoder than ffdshow, you have to change the merit to "Normal" in ffdshow.
Put it to normal ages ago and tried to get LAV Audio to work many times after that. And have changed video decoder many times and it always worked. So it's not that, but good to know.
kennae is offline   Reply With Quote
Old 6th October 2011, 16:20   #6003  |  Link
CruNcher
CruNcher's Avatar
This is great nev the damaged AAC sound parts (latm) work now, no need for DivX AAC anymore
Though its interesting it still gets this 1 scene of the broken interview sync @ the end compared to Lav Audio (that nowhere can keep sync other then when you seek directly to it)
But its a 100% improvement never the less (instead of getting no audio or brake ups all the time)
PS: Cool i got it sync with Lav Audio too now without seeking
It is about Time
Old 6th October 2011, 19:06   #6004  |  Link
TheShadowRunner
TheShadowRunner's Avatar
- Fixed cropping of VP6 video
Arg, no sorry it's still broken:
Sample1 (bottom) / Sample2 (side)
- Performance enhancements in the CUVID decoder on some systems
Just.. awesome, thank you very much!
I see you integrated the changes from -delay4 build into 0.37 as I have ZERO "presentation glitches" with the forsaken BBC Japan video
XP SP3 / Geforce 8500 / Zoom Player
TheShadowRunner is offline   Reply With Quote
Old 6th October 2011, 21:35   #6005  |  Link
Plutotype
Originally Posted by SEt View Post
At least mine own renderer does it.
You expect user to apply the delay in all audio decoders and change everything if output is redirected to other screen? Not nice at all.
I thought your stance was "do it right regardless of existing broken code". >_>
I agree with you. Pls try contact madshi when his back on his madVR thread, maybe he can give us some hint how to create some code, where change of video output device would specifically instruct audio delay parameter at MPC-HC audio switcher or LAVaudio. I dont think it will be a easy one.
System: Intel Core i5-6500, 8GB RAM, GTX960/GTX1060, 55" Sony Bravia KDL-55HX850 @ 1920x1080 24p, Yamaha YSR-1100 surround bar
Setup: Win7/Win10 Pro, madvr/JRiver 24
Plutotype is offline   Reply With Quote
Old 6th October 2011, 22:55   #6006  |  Link
Mark_A_W
3 eyed CRT supporter
The Audio Delay is great but.....umm....any chance of per-channel delay? That's the type of delay that an audio decoder needs, to make up for the inadequacies of most audio drivers (they all should have delay but they don't).
Thanks
Mark
Mark_A_W is offline   Reply With Quote
Old 6th October 2011, 23:13   #6007  |  Link
Moti172
Hi
I'm having a problem when decoding DTS or DD to pcm via lav-audio, it look's like the channel's order is misplace.
Why is it happening and how can I fix it?
Thanks
Moti172 is offline   Reply With Quote
Old 7th October 2011, 01:26   #6008  |  Link
terminaldawn
I am hoping someone can help me out with a problem I am having.
I am unable to bitstream TrueHD files (mkv), all I get is static. (DTS-MA is working just fine).
I was able to stream TrueHD via FFDSHow before installing and configuring LAV.
I am using the latest version of MPC-HC, also latest version of LAV filter. I do not have haali media filters installed. I am using HDMI connected to a Denon AVR-591 and ATI HD-5850
How can I get TrueHD to work with LAV?
Thanks for any help!!!!
below are screen shots of my settings.
terminaldawn is offline   Reply With Quote
Old 7th October 2011, 02:02   #6009  |  Link
SEt
Plutotype, you don't need any complex interactions between video renderer and player/audio decoder even on display switch. It's the same 4 lines of code nevcairiel speak about, just in the video renderer. And as video renderer knows display it works on - it can compensate display delay internally without involving other parts of player.
Personally I don't understand all the fuss over madVR - it's as bad as any other widespread renderer and closed source.
SEt is offline   Reply With Quote
Old 7th October 2011, 02:14   #6010  |  Link
pankov
SEt,
why don't you like madVR? What do you find "bad" in it?
Can you elaborate on the subject of audio delay - from my point of view I think it's the audio renderer that has to do the delay, not the video one. Is it at all possible that the video renderer controls the audio delay?
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS
NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V
Win 10 64bit 1803 + Zoom Player v14
pankov is offline   Reply With Quote
Old 7th October 2011, 03:32   #6011  |  Link
terminaldawn
I figured this out. I just had to block FFDShow.
Old 7th October 2011, 09:21   #6012  |  Link
ryrynz
ryrynz's Avatar
The fuss is over the the picture quality (color reproduction and tear free playback) enhancements over the other renderers we currently have available.
There is the odd problem here and there but it's core functions work well. I haven't seen any other developers share the same opinion of it, is it that you have experience with better renderers or that MadVR does not do something you want it to do?
Old 7th October 2011, 09:30   #6013  |  Link
e-t172
In my experience it is much easier to get smooth playback (i.e. no dropped/repeated frames) using madVR than any other renderer. Sometimes it's the only way.
e-t172 is offline   Reply With Quote
Old 7th October 2011, 09:32   #6014  |  Link
RealSnoopyDog
Hi nev! Thanks again for this great software!
One short question: Do you think it's possible to demux quicktime (.mov) files without having quicktime installed? I remember, there was a splitter for this but it always required an installed quicktime library.
Ah, i forgot: when i compiled your latest version 4 days ago, i needed to copy the "libpthread-2.dll" into the LAVSplitter directory. Do you use this right now somewhere? I'm not that familar with VS2010 right now but i'm trying to learn. Currently i try to investigate an issue in libbluray.dll (bad i/o buffering and endless preloading when a new mpls file is opened, which makes playback choppy/stuttering in some cases (e.g. seamless branching to next mpls)).
RealSnoopyDog is offline   Reply With Quote
Old 7th October 2011, 10:45   #6015  |  Link
roytam1
Firefox User
LAV Splitter should be able to split QuickTime files.
The libpthread dll is used by libavcodec (i.e. gcc/mingw issue). I use gcc from xvidvideo.ru which doesn't need libpthread dll.
roytam1 is offline   Reply With Quote
Old 7th October 2011, 11:35   #6016  |  Link
pirlouy
_
Provocation. And the "closed source" is noting else than a troll.
If you don't want to be seen as a troll, you'll have to explain, or release a video renderer.
Old 7th October 2011, 12:33   #6017  |  Link
STaRGaZeR
4:2:0 hater
@nev, can you update ffmpeg? An old bug got fixed yesterday (regarding softdec) and it would be nice to have it in LAV.
Thanks to Michael for looking into it BTW.
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 7th October 2011, 12:56   #6018  |  Link
Carpo
Carpo's Avatar
Here is a strange issue, if I use Win7DSFilterTweaker_4_6 to set Lav Video as the preferred decoder for all formats, then start up Resident Evil 4 on the PC, the Ubisoft intro and all cut scenes play upside down, if I play the .mpg files directly from the Resident Evil 4 directory in MPC-HC they play fine, they also play fine if I remove Lav Video as the preferred decoder, has anyone else had this issue? I know there is a HD pack for it on certain sites, but I don't want to grab it just for the re-encoded videos as its rather large
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 7th October 2011, 13:01   #6019  |  Link
STaRGaZeR
4:2:0 hater
Ignore, fixed
Old 7th October 2011, 13:49   #6020  |  Link
Daiz
A bug report from a guy I know (who registered an account but haven't waited the required 5 days yet):
When I play a video after opening the options of LAV video decoder with 0.37 i get this:
I'm trying to lock it down, I'm using EVR-CP as the output renderer and when using save image in MPC-HC the image is saved properly, without all the screwed up colors.
- It doesn't appear to happen in madVR, EVR and EVR Sync
- It doesn't happen with 0.36
- It occurs even if you change no option after opening LAV video decoder properties and click cancel to close it
- It doesn't occur if you open the LAV video decoder properties while a video is playing, it must be opened when the player is not playing a video to cause the bug
I'm also using MPC-HC 1.5.3.3751 if that is relevant.
Where did neuron1 go? | Doom10
Daiz is offline   Reply With Quote
