#1201 | Link |
Why static titles flicker after QTGMC? This is white text on solid black background, not even text over video.
There is no motion- they should stay exactly as they are, but this is not the case- they "jump" between fields a bit. Last edited by kolak; 4th May 2012 at 19:49. |
#1202 | Link |
That's quite hard to explain.
Short answer: Try adding Rep1=4, Rep2=0 to your settings. This might fix your problem - it might rarely add a tiny bit of motion blur (hard to notice) Long answer: The core operation of TGMC is to blend 50% of the current frame with 25% each of the previous & next frames (motion-compensated). That removes all bob-shimmer and helps define the missing field lines. However, it also introduces motion-blur where the motion analysis is incorrect. So there is a repair step that only allows changes that affect thin horizontal areas - because bob-shimmer normally only affects thin horizontal areas. Occasionally there is shimmer that covers a wider area, especially on static detailed things such as text. That shimmer gets through because fixing shimmer in larger areas would potentially create motion blur elsewhere. There are settings controlling the shimmer repair step: Rep0, Rep1 and Rep2. Rep0 improves the motion search clip only so that isn't so relevant here. Rep1 and Rep2 are alternative ways to repair the output, you set them to a value from 1 to 5 to control the repair strength (it's a bit more complicated but that's the basic idea). The higher you set the value the more shimmer is removed but with the possibility that some motion blur might creep through. Rep1 has a stronger effect than Rep2, but again might let more motion blur through. The defaults are Rep1=0, Rep2=4. I suggest you switch the 4 to the stronger Rep1 and see if that works. You might wonder why TGMC doesn't just mask static areas and leave them untouched to avoid all this complexity. You can try it yourself: Code:
qtgmc = QTGMC() dw = DoubleWeave() mask = mt_lutxy( dw, dw.SelectEvery(1,1), "x y - abs", U=1,V=1 ).mt_expand(U=1,V=1).mt_binarize(0, U=1,V=1) mt_merge( dw, qtgmc, mask, luma=true ) It's very easy to create discontinuities by naive masking during deinterlacing, different algorithms often don't match up perfectly. You see this in other deinterlacers: "this part is combed so do A, this part is not combed so do B". We see the discontinuity between A and B. Softened masks help but blur detail. On a side note, the other problem with static detail in (Q)TGMC is that is loses too much vertical detail compared to other deinterlacers. Source match was specifically designed to greatly improve static detail. Sadly though it doesn't affect these minor shimmer issues. Last edited by -Vit-; 6th May 2012 at 13:43. |
#1203 | Link |
Good explanation, Vit.
![]() The following idea is years-old, it took only someone to actually ask about shimmer .... While QTGMC might not be perfectly stable on static features, it is at least fairly stable. With this background, shouldn't the TMM principle be applicable? Take result of QTGMC. Compare temporal variance to local vertical min/max. If temporal variance is smaller than, say, 10%~20% of local min/max, use weave.
#1204 | Link |
Thanks Vit- I think I understand it at least in some sense
![]() I think it appears more on thin, sharp text- once font is bigger/bolder/blurred it's less likely to happen. I also use fast or very fast preset (HD source)- does this have effect on Rep settings? I will try and report ![]() Last edited by kolak; 7th May 2012 at 22:04. |
#1205 | Link |
Rep settings did not help.
Your script does help, but of course during fade to credits problem is still present ![]() There is still small flickering happening in some cases (due this luma=0 probably), so I think best way is to process problematic frames separately. |
#1206 | Link |
On my test material, slightly higher Rep settings worked. Below is a minor tweak to QTGMC that allows Rep0, Rep1 and Rep2 to go up to 7. Try Rep2 or Rep1 = 6 or 7. Risk of blur elsewhere as described above. However, I found those effects inoffensive in my sample.
QTGMC-3.33 There's a couple of other very minor tweaks in there that I never posted, including a fix for a Bob / TFF / BFF problem noted by ajp_anton some time back. Last edited by -Vit-; 8th May 2012 at 15:51. |
#1208 | Link |
It's possible that your fade is failing because the motion analysis is failing, in which case you would effectively get a NNEDI3 deinterlace, which will certainly shimmer. It's a long shot given that you just have static text over no background, but just in case you could try setting DCT=5, which is more robust to fades.
More likely it's just that larger areas are being affected by the TGMC algorithm due to the fade, so they're not getting through the repair step even at that higher setting. Last edited by -Vit-; 8th May 2012 at 17:23. |
#1212 | Link |
@-Vit-
Please upload QTGMC-3.33 to another filehoster. hotfile.com is giving me some strange messages: Copyright infringement, blah, deleted by uploader, blah, already downloading, blah blah.... Thanks Edit: changed the IP on my router and now it works... Sorry for the hazzle. Last edited by Taurus; 8th May 2012 at 17:46. |
#1216 | Link |
Acid fr0g
-Vit-, I have some confusion about "Modded Plugins Package" and "new plugin pack using the updated Avisynth 2.6 interface".
I have seen that some file dates are newer in the first, even if the 2.6 should be the latest pack you released. If I use AviSynth 2.6 *AND* I do MT, which one should I use? 2nd question: is there any reason why some modded plugin versions are older than the newer "official" release? I.e. the AddGrainC you provide is 1.5.1 while the one I found somewhere is 1.6.1. P.S: As I suggested in the "color banding" thread, LVVM has added CUDA support. Could be nice to see it implemented. ![]()
@turment on Telegram |
#1217 | Link | |
Hello to all,
I come on this forum often and read a lot of very good stuff that helped me a lot, but i'm a noobie when it comes to more complex things and this is my first post here asking for a little specialists help. I have many footage that i record using Fraps in resolution 960x540 @ 60 FPS in normal mode, not the forced RGB one ( half size on a 1080p screen ) I'm trying to get a very good result while upscaling the videos to 720p but i would need some help especially for the noise and sharpen reduction while using QTGMC if possible, if any of you have suggestions for the best way to upscale from 960x540 to 720p please. Actually the part of the script regarding the upscale looked like this : Quote:
![]() My script was probably wrong used like this but i found this way months ago after testing various things and for now that's was the best results i could get, some things are not very good so I'd like to use more options from QTGMC to get the best possible result using only QTGMC for the upscale and keep the maximum details in the videos. I use Megui once my script is done to encode the video in x264 ( same here, still trying to find the best optimized settings/ profile for fraps videos, i search and read the more i can but i don't understand everything sadly ) I hope someone can help a little a noobie like me, like i said I read a lot of things here but i'm totally lost with all this now. Thx guys. |
#1218 | Link |
kolak: Glad DCT=5 worked. Did you still need the higher Rep value or that extra script I posted to stabilize the sections outside the fade?
___ SubJunk: Thanks for the link. I agree DCT=5 can be useful when there are luma change problems, but I am less convinced in general - it can make some strange choices. I certainly wouldn't say it was essential for QTGMC. ___ cybersharky: I can't tell what your problem is without part of your source video. ___ Tormento: I reverted to an older (original) fftw3.dll because I had previously been using a renamed version the newer libfftw3f-3.dll instead, which is not appropriate given the interface/functionality may not be the same. The old version is used by fft3dfilter, the new one by dfttest. If you don't like using a file from 2004, then your can rename the newer one to copy over the older one - it seems safe enough, but if it makes your cat explode then it's not my problem. I have been trying to use the latest "official" version of all the plugins. However, you're correct - someone did some new development on AddGrain and I forgot, I'll have a look. MVTools2 and dfttest are a small problem because they are now effectively maintained by cretindesalpes - and I'm not up to date with them. That's because I hope that cretindesalpes will create new-interface-2.6 versions - then I wouldn't have to compile my own versions at all. In any case, you can use either set of plugins, it's up to you. You can even mix them up safely on 2.6MT, for example to use cretindesalpes versions. I hope that we will be able to reduce this dll bloat soon. An official 2.6 beta with the new interface would help. A new CUDA compiler will not help QTGMC because none of the plugins use CUDA. ___ Yanak: you question is quite general - in fact I'm not exactly sure what the focus of your question is. QTGMC is not a script for upscaling. There are better denoisers than QTGMC, and I don't know what you mean by "sharpen reduction". QTGMC is mainly for deinterlacing (is your footage even interlaced?). I think you would be better to post a new thread, maybe even in the Newbies forum, because I don't think your answer is specifically to do with QTGMC. Last edited by -Vit-; 10th May 2012 at 23:49. |
#1219 | Link |
Thx for answering -Vit-
In fact i thought that using QTGMC could help having better results when we upscale with noise reduction, sharpen etc, but i guess i'm too noob to have understood correctly. I will do like you suggested and try to find the newbies section of the forum and see if i can find something that suits my needs there. Sorry for th dumb question and thanks for your quick answer. |
#1220 | Link |
Yanak!
Try Code:
SetmtMode(3,4) AVISource("yoursorce.avi") AssumeTFF() SetmtMode(2,4) Edibob=source.nnedi3(field=-2,threads=1).nnedi3_rpow2(2,nsize=4,cshift="Spline36Resize",fwidth=1280,fheight=720,threads=1) Edibob.SeparateFields().SelectEvery(4,0,3).Weave().AssumeTFF() QTGMC( Preset="fast", FPSDivisor=2, Ediext=Edibob,EdiThreads=1 ) Script work with Set 2.6 last build. yup. |
