Old 2nd August 2010, 10:05   #21  |  Link
Ghitulescu
Ghitulescu's Avatar
Originally Posted by Ghitulescu View Post
Is there anything that can natively play 4k? I mean without downconverting for displaying ... Maybe I'm wrong with the question, I simply haven't yet seen 4k displays on the market, I mean for consumer use ...
So, you don't have a 4k display (BTW, display is not a TV only, can also be a PC monitor), you cannot play the file (natively or downconverted),...
Originally Posted by GuilhermeAraujo View Post
I downscaled the video to 1080p, 50 fps with an avarage bitrate of 42 Mbps level 5.1. As expected, no BSODs, but seems it's too much data to proccess.
The video was skipping, showing about 1 frame per 1,5 second, more or less. Most weird, GPU use didn't go above 25%.
..., you also complain about the amount of data (and it's 4 times less than 4k needs) to process ....
Using MPC-HC instead of VLC, the video, the playback goes a little smoother, but still unwatchable.
Activating ffdshow DXVA makes it run very smooth, but it doesn't play at 1x, plays at a lower rate.
there's no standardised interface (for consumer use)...
but you still want to use 4k. It's either extreme ambition or masochism.
I don't want to discourage you, just to pinpoint that 4k is not ready for the public.
2k = 2048x1152. I wouldn't call it "totally better than 1080". Just a little bit.
It's the same as 1080p/i, the numbers you have are used in the standard pretty much like the NTSC standard makes use of 525 scanlines. To split the hair, yes 2k is not 1080p, because it's a photographic term, not a cinematographic one, but the reason for 1080p was to accommodate 2k scans within a TV signal.
Old 2nd August 2010, 15:26   #22  |  Link
poisondeathray
You can get 4K projectors , and they have been available for a few years. They have come down in price, but still quite expen$ive - not for the general public. But if you can afford a Red One + gear, then you can afford a 4K projector
Old 4th August 2010, 00:32   #23  |  Link
GuilhermeAraujo
@Ghitulescu
Of course I don't plan to use 4k. Not at all. I just wanted to push my video card to the limit to see if it was able to handle it.
Even because ATI says it supports 4K x 2K and level 5.1 videos. Looks like it doesn't, after all...
Edit: I don't know if I'm doing everything fine. I converted to 720p with constant quality at 10. Got a 78.9 Mbps file, and it plays fine and smooth. Then set quality to 4, got a 118 Mbps and still is OK.
GuilhermeAraujo is offline   Reply With Quote
Old 4th August 2010, 00:43   #24  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
@Ghitulescu
2160p videos play fine on my ATI HD4670 using the overlay renderer.
Old 4th August 2010, 00:59   #25  |  Link
GuilhermeAraujo
What is this "overlay renderer"? Is it something I can activate/deactivate?
Old 4th August 2010, 01:15   #26  |  Link
Dark Shikari
x264 developer
It's just the fastest (and simplest) renderer option in MPC-HC...
Old 4th August 2010, 01:48   #27  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Indeed. I think it's called "Overlay Mixer".
D_S, do you use DXVA or software decoding for this? I'm assuming DXVA from the context..
Derek
Old 4th August 2010, 03:35   #28  |  Link
Dark Shikari
x264 developer
Derek
Software; DXVA is laughably slow.
Old 8th August 2010, 05:21   #29  |  Link
Blue_MiSfit
I see. I thought you were saying that your 4670's ASIC could handle 4K H.264 decode, which was SLIGHTLY unexpected.
I'm sure anyone with a modest dual core could play a "4k" video file if it's average bitrate was like 5mbps
Old 5th September 2010, 15:42   #30  |  Link
NikosD
I have an ATI 5750 card - UVD 2.2 - Win 7 x64 and Catalyst 10.8 -C2D-E7300
It is very difficult to play the new 4K videos by YouTube in CPU only at x1 speed. With the sample below I get ~18fps
Sample here:
http://rapidshare.com/files/41498552...7_fps.mp4.html
But the main problem is that DXVA mode to such clips -UHD- gives BSOD with VLC, MPC-HC internal DXVA codec, FFDshow DXVA and DivX DXVA.
WMP12 and PowerDVD 10 give black screen and audio decoding.
It SHOULD work according to ATI release notes, but it seems they haven't opened the feature yet or the ASIC of UVD 2.2 is not fast enough.
Old 25th May 2012, 22:14   #31  |  Link
vanden
Centralization of some 4k samples :
3840x2160/29.970fps/50Mbits(Constant) or Mirror
3840x2160/119.880fps/100Mbits :
Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.mkv
Or
ed2k://|file|Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.mkv|2706942815|70cf7fd7e1dd0b61cae96dff22d99bc5|h=bwg7va6gmcdomin6orcreagnxvr5adlb|/
Or
Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.part1.rar
Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.part2.rar
Girls.Generation.Oh.4in1.201002.HDTV.x264.2160p.120fps.DTSES.6.1ch.part3.rar
For Download : pressed the green button.
I also encoded sequences (the same as in the link given by Dark Shikari / CrowdRun_ParkJoy_DucksTakeOff_InToTree_OldTownCross), but into a single file.
The original 16-bit SGI Images are available here:
ftp://vqeg.its.bldrdoc.gov/HDTV/SVT_...ter_SVTdec05_/
Available in diferents, Framerate/Bitrate.
Quality Blu-Ray (equivalent to 1080p/25fps/30Mbits/BitPixel0.579) :
- 3840x2160/25fps/120Mbits/NormalMotion (only half of the images are encoded) or Mirror
- 3840x2160/25fps/120Mbits/SlowMotion (Frame Rate slows @ 25fps) or Mirror
- 3840x2160/50fps/240Mbits/NormalMotion/OriginalFramrate :
For this file, just remux (3840x2160/25fps/120Mbits/SlowMotion) with mkvtoolnix and change the framerate @ 50fps (50p).
Quality BD9 (equivalent to 1080p/25fps/9Mbits/BitPixel0.174) :
- 3840x2160/25fps/36Mbits/NormalMotion or Mirror
- 3840x2160/25fps/36Mbits/SlowMotion or Mirror
- 3840x2160/50fps/72Mbits/NormalMotion/OriginalFramrate :
For this file, just remux (3840x2160/25fps/36Mbits/SlowMotion) with mkvtoolnix and change the framerate @ 50fps (50p).
Lower quality (equivalent to 1080p/25fps/5.625Mbits/BitPixel0.109) :
- 3840x2160/25fps/22.5Mbits/SlowMotion :
For this file, just remux (3840x2160/50fps/45Mbits/NormalMotion/OriginalFramrate) with mkvtoolnix and change the framerate @ 25fps (25p).
- 3840x2160/50fps/45Mbits/NormalMotion/OriginalFramrate or Mirror
I also encoded various "RED" clips into a single file, original R3D files are available here:
http://www.reduser.net/forum/showthr...th-a-Scarlet-X
http://www.reduser.net/forum/showthr...M-X-REEL-R3D-s
http://www.bealecorner.org/red/test-080108/page2.html
Quality Blu-Ray (equivalent to 1080p/23.976fps/28.1Mbits/BitPixel0.566)
- 4096x2160/23.976fps/120Mbits or Mirror
Quality BD9 (equivalent to 1080p/23.976fps/8.45Mbits/BitPixel0.170)
- 4096x2160/23.976fps/36Mbits or Mirror
All my encoding is done in 3 pass
EDIT
One another : SINTEL
Original 4k png/tiff (16 or 8 bpp)
And official H264 version (equivalent to 1080p/24fps/11.6Mbits/BitPixel0.233) :
- 4096x1744/24fps/40Mbits
vanden is offline   Reply With Quote
Old 3rd June 2012, 12:17   #32  |  Link
TheElix
Thanks a lot, vanden! But it's going to take several days to direct download some of these files (2 Gb, for example). Maybe make a torrent with all these files and put it somewhere? For example, here: http://rutracker.org/forum/index.php
TheElix is offline   Reply With Quote
Old 4th June 2012, 17:07   #33  |  Link
vanden
Establishment of a miror for all files
Old 15th June 2012, 09:25   #34  |  Link
pokazene_maslo
Maybe first commercial movie available to end users in 4K: http://timescapes.org
TimeScapes was shot in 5K resolution on Red Epic and Canon DLSR cameras, edited in 4K
pokazene_maslo is offline   Reply With Quote
Old 13th October 2014, 11:28   #35  |  Link
vanden
Ok I just tested the x264 version (TimeScapes.2012.2304p.CineForm.x264-WiKi).
The resolution is not perfect all the time. Sometimes there are jagged edges ... it's better than 2K but not perfect all the time ...
If anyone has tested the Cineform version can confirm that the same thing ?
Old 13th October 2014, 12:18   #36  |  Link
kolak
There is clearly some issue there.
Looks similar like when you interpret progressive footage as interlaced
