#1 | Link |
BDtoAVCHD v3.1.6 - One Click Blu-Ray 2D/3D to BD5/BD9/BD25/MKV
BDtoAVCHD is a tool to create AVCHD discs from Blu-Ray or HD MKV files. As output we get the folder structure ready to burn to a DVD5 or DVD9. The software compresses the video to achieve the desired overall size of 4.7 GB or 8.5 GB with the highest possible quality.
The AVCHD format allows playback the same type of content that a Blu-Ray and holding high definition (1080p) but on DVD5 or DVD9 media. It is ideal for backing up Blu-Ray with much smaller size and maintaining high quality. BDtoAVCHD is created with the idea that is very simple and quick to use and obtain the best possible quality in a DVD5 media. To achieve this avoids unnecessary conversions and do not need any codec installed as avisynth, ffdshow or Haali media splitter. The recorded discs obtained are compatible with almost any Blu-Ray player and PS3. Also can convert Blu-Ray to MKV, MKV to AVCHD, Blu-Ray 3D to AVCHD/MKV 3D SBS/TAB and ability to encode MKV's using x265/HEVC codec. ![]() KEY FEATURES
DOWNLOAD
CHANGELOG __________________ BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 5th April 2025 at 19:02. Reason: new version |
#2 | Link |
AVCHDCoder developer
I noticed this tool a while ago. I was interested in the bitrate calculator so I compared it with my AVCHDCalculator. I was stunned of how close the results are. Most of the time only a couple of kbps different then AVCHDCalculator. Also your Media selection sizes are surprisingly the same as AVCHDCoder's ouput sizes so I thought I'd find AVCHDCalculator in your package. But I couldn't find it. So my question is: how did you do it?
#3 | Link | |
http://en.wikipedia.org/wiki/DVD and output sizes ...many hours of work and much research ![]() Sample: Code:
... size = audio * Video[i_v].duracion; n_packets = size / (1536-head); over = n_packets * head; media -= size; media -= over; n_packets = media / 1536; over = n_packets * 81; media -= over; media -= (300 * 8 * Video[i_v].frame_count); bitrate = (int)(media / (Video[i_v].duracion * 0.9893)); .... BDtoAVCHD - Create an AVCHD disc (DVD5/DVD9/BD25) from a Blu-Ray or HD MKV Last edited by pistacho; 5th February 2011 at 13:33. |
#4 | Link | |
#5 | Link |
@pistacho
Looks like a great GUI, have not tested it yet because I am not at home this week, but will be testing as soon as possible ![]() I am using RipBot as my defult GUI for creating AVCHD back-up's of my Blu-Ray collection, but I only have the need for AVCHD output, so maybe your GUI is better for me..... Well, have a question before I start using your GUI: 1. Is there any way to tweak the x264 settings for my personal needs ? 2. What x264 settings does your GUI use by default ? 3. Does BDtoAVCHD support multiple subtitles and audio tracks in the final AVCHD output file ? Hope you can answer my questions and I am looking forward to see where future development takes BDtoAVCHD ![]() Best regards. Dennis |
#6 | Link | |||
![]() Quote:
![]() __________________ BDtoAVCHD - Create an AVCHD disc (DVD5/DVD9/BD25) from a Blu-Ray or HD MKV Last edited by pistacho; 5th February 2011 at 13:34. |
#7 | Link | |||
Hi pistacho.
Your program works like a charm, but I have some sggestions for futher development: 1. Allow multiple subs and audio streams. 2. Allow HD audio on dvd 9. 3. Allow different encoding presets, right now you are using a very fast x264 preset, resulting in low quality encodes, but wery fast encoding times. Please add slower encoding for better quality. I used Media info for your x264 encoding settings, and they look like this: Quote:
![]() Quote:
Best Regards Dennis |
#9 | Link | |
@Denner
Thanks for your suggestions. Take them into account in future versions of the software. ![]() Only a detail: Quote:
x264 presets: ultrafast, superfast, veryfast, faster, fast, medium, slow, slower, veryslow, placebo I prefer to let the codec choose the correct parameters by changing only the presets. But I can add the option to let the user choose some presets ![]() @neuron2 Sorry I did not think __________________ BDtoAVCHD - Create an AVCHD disc (DVD5/DVD9/BD25) from a Blu-Ray or HD MKV Last edited by pistacho; 5th February 2011 at 13:34. |
#10 | Link |
@ pistacho.
Sorry, I did not realize that you were using the x264 standard presets, I never do, that is maybe why I did not notice it ![]() I normally use my own settings, I tend to prefer quality over speed, but it all depends on the bitrate. Well I would VERY MUCH appreciate it if you could and would allow the end user to select between the following x264 presets: medium, slow, slower, veryslow, placebo Thanks for the quick answer and keep up the good work ![]() Best Regards Dennis |
#11 | Link |
Hi!
I'm working on a new version that adds the ability to select the x264 preset. You can change the default preset in the general settings and the preset to use in each conversion (if different from default). ![]() I also changed the list of jobs in queue for a tree type control that lets you view the configuration of each conversion when added to the queue. ![]() I hope to finish soon. ![]() __________________ BDtoAVCHD - Create an AVCHD disc (DVD5/DVD9/BD25) from a Blu-Ray or HD MKV Last edited by pistacho; 5th February 2011 at 13:35. |
#12 | Link |
@ pistacho
That is so cool, this gui keeps getting better and better ![]() Maybe you could add a " shutdown after batch encoding is done " function, so that BDtoAVCHD shuts down the computer after encoding i done ? If you need any BETA testers, I would be happy to help out ![]() Best regards Dennis |
#13 | Link |
The new version 1.0.9 is out!
The first post is updated ![]() __________________ BDtoAVCHD - Create an AVCHD disc (DVD5/DVD9/BD25) from a Blu-Ray or HD MKV Last edited by pistacho; 5th February 2011 at 13:35. |
#15 | Link | |
Hi, I tested a conversion with the preset slow and these are the differences with the parameters that the codec choice:
![]() The other presets I have not tried yet... @Denner: You can get most of parameters that you had suggested using the preset slow ![]() __________________ BDtoAVCHD - Create an AVCHD disc (DVD5/DVD9/BD25) from a Blu-Ray or HD MKV Last edited by pistacho; 5th February 2011 at 13:35. |
#16 | Link |
Hi will be encoding a blu-ray tonight using the veryslow preset, I am really looking forward to seeing the results
![]() I just say that I am impressed by how fast you are making the GUI better, how all we need are multiple audio and subtitle tracks ![]() Wow...... Dennis |
#17 | Link |
@ pistacho
I have now done 2 Blu-Ray backup's, using the veryslow preset and they both came out oversized ![]() Backup 1 came out at 8.550.347.636 bytes and backup 2 came out at 8.563.988.860 bytes, so something is not right ? Will try to do the same movies with the normal preset and to see if they come out at the right size. Will you try to look in to the problem ? Best Regards Dennis |
#19 | Link | |
@Denner
I would like to reproduce the problem. I need: the total length of the film (h:mm:ss), fps, the type of output audio (AC3448, 640, DTS 768, Core 1509), sub (none/normal/forced) and actual video bitrate (MediaInfo --> bitrate). 8.550.347.636 ![]() ![]() Quote:
Thanks for doing the tests. Let us know the new output size with "medium" preset. __________________ BDtoAVCHD - Create an AVCHD disc (DVD5/DVD9/BD25) from a Blu-Ray or HD MKV Last edited by pistacho; 5th February 2011 at 13:36. |
#20 | Link |
Sorry, my bad, here are the info from MediaInfo:
[HTML]General ID : 1 Complete name : C:\Users\xxx\xxx\SHERLOCK HOLMES\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : BluRay Video File size : 7.96 GiB Duration : 2h 8mn Overall bit rate : 8 878 Kbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 2h 8mn Bit rate : 7 007 Kbps Nominal bit rate : 6 776 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.141 Stream size : 6.28 GiB (79%) Writing library : x264 core 98 r1649 20cbe10 Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=0 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=6776 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=24000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Duration : 2h 8mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 24 bits Stream size : 1.35 GiB (17%) Language : English Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Language : Danish [/HTML] The total length of the film 2:08:25. It is the retail Blu-Ray of SHERLOCK HOLMES and it is the core audio of the DTS-HDMA soundtrack and the retail Danish subs and they are forced. Info on the other movie will follow ![]() Hope it helps ? Last edited by Denner; 28th June 2010 at 21:27. |
avchd, bdtoavchd, blu-ray ripper, m2ts, ps3 |
