Old 12th May 2010, 22:54   #1  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Encoding Video for Blu-Ray using H264/AVC
Here is part of specification that apply when encoding with H264/AVC codec, all parameters showed here are not guessing, it's based on original Blu-Ray specification, which are not available in public.
NOTE: This is discussion about settings that are for creating 100% compliant Blu-Ray structures, not for encoding from Blu-Ray sources to matroska/mp4 or other media, if you encode to those skip this nightmare
1. GENERAL CONSTRAINTS FOR MPEG-4 H264/AVC
1.1 ALLOWED RESOLUTIONS/FRAMERATES
1.2 ALLOWED LEVELS, PROFILES, REFERENCE FRAMES, VBV
1.2.1 Primary Video Rules
1.2.2 Secondary Video Rules
NOTE: In case of 1080 and 720 resolutions same rules apply as Primary video, while 576 and 480 resolutions have stricter parameters showed in table:
1.3 SIMPLE ASPECT RATIO
1.4 COLOR CHARACTERISTICS
1.5 OTHER REQUIRED PARAMETERS
8-bit (4:2:0) Colorspace is only allowed
Main and High profiles are allowed
Maximum 3 B-Frames is allowed
NAL-HRD Type 2 capable encoder is needed
2. ENCODE BLU-RAY VIDEO USING x264
2.1 MANDATORY PARAMETERS
Every encode for Blu-Ray must contain this parameters, without it will not meet Blu-Ray specification.
--bluray-compat
Enforce x264 to create BD compliant stream, that will reduce x264 settings to BD compatible: bframe<=3, ref<=4 for 1080, ref<=6 for 720/576/480, bpyramid<=strict, weightp<=1, aud=1, nalhrd=vbr
--level
Blu-Ray level, see the table for the appropriate level
--keyint
Maximum number displayed pictures in GOP. If you set Maximum bitrate less or equal to 15mbps you can use 2 second long GOP otherwise, 1 second GOP must be used.
--vbv-maxrate
Maximum allowed bitrate. Depend of destination media, for normal BD Media, maximum settings is allowed (40000), while for DVD Media (eg BD-5 or BD-9) there is no maximum per Blu-Ray specification, but is strongly recommended that use less or equal to 15000, since DVD reading is slower.
--vbv-bufsize
Maximum allowed buffer, buffer size is in relation with maxrate. Since STD Buffer Delay for Blu-Ray allows maximum 1 second. This mean to divide buffer with maxrate and see if result is less or equal to 1, if not, buffer is need to be reduced to lower value that meet 1 second STD. For BD media, maximum settings is allowed (30000), but if not meet STD Buffer Delay, then need to be reduced to lower value. For DVD media there is no maximum in Blu-Ray specification, but is strongly recommended that use less or equal to 15000, and again need to meet STD delay of 1 second.
For example:
--vbv-bufsize 30000 --vbv-maxrate 40000 is allowed
--vbv-bufsize 30000 --vbv-maxrate 30000 is allowed
--vbv-bufsize 15000 --vbv-maxrate 30000 is allowed
--vbv-bufsize 30000 --vbv-maxrate 15000 is not allowed (delay is greater than 1 second)
Basicly vbv-bufsize should newer been greater than vbv-maxrate, that is whole point.
--sar
Simple Aspect Ratio, must present in stream, see the table for the appropriate settings
--slices
Only when encoding with --level 4.1, slices need to be set to 4 or greater, otherwise you can skip this setting or set it to 1.
-o xxx.264
Output file must be in raw 264 elementary stream (extension .264) otherwise settings will not applied correctly. DO NOT USE MKV OR MP4.
2.2 OPTIONAL PARAMETERS
This parameters is optional and not need for every encode.
--colorprim
--transfer
--colormatrix
Specify color primaries, transfer characteristics and color matrix. This is optional, and not need to be present, see the table for the appropriate settings.
--pic-struct
Need only when fake interlaced is used, and it's default on with interlaced and pulldown. It's fine with progressive aslo, and some BD verification tools request to be present in stream.
--open-gop
Use non-IDR pictures instead classic IDR picture, this will tend to resolve pulsing picture problem that is usually came with short GOP's.
--fake-interlaced
Since 25p or 30p video is not allowed for Primary Video, encoding progressive video that meet Blu-Ray specification is only possible with this option. If use this option you aslo need to specify --pic-struct
--qpfile
Need for chapters.
2.2 EXAMPLES
Progressive
1080p
720p
576p
480p
Interlaced
1080i
576i
480i
shon3i is offline   Reply With Quote
Old 12th May 2010, 23:19   #2  |  Link
b66pak
b66pak's Avatar
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 12th May 2010, 23:46   #3  |  Link
Please advise when it is complete so we can make it a stickie. Thank you.
Old 13th May 2010, 00:31   #4  |  Link
AnonCrow
Little nitpick : since you're using images and you're hosting them yourself, might want to optimize them for smaller size - pics 1 and 2 went from 50 KiB and 62 KiB to 13 and 16 KiB, respectively , just by decreasing bit-depth and using maximum PNG compression. This without even resorting to PNGOUT or Pngcrush.
AnonCrow is offline   Reply With Quote
Old 13th May 2010, 02:24   #5  |  Link
ajp_anton
ajp_anton's Avatar
What does "Max bitrate BD, DVD and with or without 2 sec GOP" mean?
And to do 25fps progressive, you have to either double the framerate to 50fps, or encode it as 25fps interlaced?
Old 13th May 2010, 03:11   #6  |  Link
creamyhorror
Thanks for doing this. I think a specific x264 section with recommended commandlines and workflow notes would be essential.
creamyhorror is offline   Reply With Quote
Old 13th May 2010, 07:30   #7  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@AnonCrow, thanks for tip. i probably will upload later here as attach, but i will optimize as much as possible.
It mean, if you target is BD media and if you set VBV maxrate <=15000 then you can use --keyint from Max Frames in 2 sec. GOP. Or if you target media is DVD (BD5/BD9) you aslo may not use higher maxrate/buffer than 15000, coz DVD spin speed is lower, that is some error free maximum for DVD. Still if you set maxrate to 15000 you can choose what you want to use 1 second or 2 second GOP, for BD or DVD.
You need encode it as interlaced, or convert to 720p50.
To be continued with explanation, examples, and few more tables.
Old 13th May 2010, 08:00   #8  |  Link
Snowknight26
Doesn't actually have to be interlaced, can just be flagged as interlaced yet contain progressive frames.
Snowknight26 is offline   Reply With Quote
Old 13th May 2010, 08:23   #9  |  Link
kieranrk
If you had an encoder that can do adaptive PAFF/MBAFF then yes.
Or you could force it manually since the spec says frame_mbs_only shall be 0.
kieranrk is offline   Reply With Quote
Old 13th May 2010, 10:03   #10  |  Link
bob0r
Pain and suffering
bob0r's Avatar
May i advice, that instead of an image, maybe make a .html page or something silimar.
So in case of link down, or user absense, people can easy update or repost when needed.
bob0r is offline   Reply With Quote
Old 13th May 2010, 10:06   #11  |  Link
kypec
User of free A/V tools
kypec's Avatar
+++ Images are nice but hardly maintainable nor usable (copy/paste) and so on.
kypec is offline   Reply With Quote
Old 13th May 2010, 11:26   #12  |  Link
kolak
I'm preaty sure that 25p is allowed for secondary video stream.
Andrew
Old 13th May 2010, 11:31   #13  |  Link
mp3dom
Infact it's mentioned in the tab
I would like to add that even if it's allowed to have a fullHD secondary video, it's better to prefer SD secondary video because not all the standalone players are able to handle 2 fullhd stream at once.
Old 13th May 2010, 12:06   #14  |  Link
shh
Originally Posted by kieranrk View Post
If you had an encoder that can do "full" PAFF/MBAFF then yes.
Is x264 able to do this already? (= flagging the stream interlaced, but just coding progressive frames)
I've got many progressive PAL-sources (most satellite-streams are p anyway), and wouldn't like to encode that "interlaced".
shh
shh is offline   Reply With Quote
Old 13th May 2010, 13:07   #15  |  Link
kieranrk
You could modify x264 to write frame_mbs_only flag as zero. You'd have to write pic_struct too but the spec isn't clear whether it wants you to signal the frame as two fields or as one frame.
Old 13th May 2010, 13:31   #16  |  Link
ajp_anton
ajp_anton's Avatar
But the "with or without 2 sec GOP" means it is 15000 *always*, whether or not you use 2 sec GOP, and this is false, because if you use 1 sec GOP with BD, it's 40000 and not 15000.
Sure 15000 can be used, but it's not max, which is what this tries to tell you.
IMO it should say something like
Max bitrate
2 sec GOP BD
DVD
Old 13th May 2010, 14:55   #17  |  Link
rack04
Thanks for taking the time to put this together. Here are my comments:
1.) "RESOLITIONS" should be spelled "RESOLUTIONS"
2.) Add a section that includes mandatory items like --aud, --bframes 3, --nal-hrd vbr, etc. I know you mention bframes 3 in the title section of Section 2 but that could easily be overlooked by people who concentrate on big pretty pictures.
rack04 is offline   Reply With Quote
Old 13th May 2010, 15:00   #18  |  Link
Sharc
Thanks a lot shon3i for your initiative
+++ Would indeed be very helpful.
Could it eventually be included in x264 as 'device presets' or similar?
Old 13th May 2010, 15:24   #19  |  Link
poisondeathray
Nice work sho3ni!
And another option would be to do the slowdown to 24p or 23.976p if you can tolerate the audio shift
Old 13th May 2010, 15:52   #20  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Max bitrate
2 sec GOP BD
DVD
Not exactly because situation looks like this:
1. 15000 is max for DVD
2. 15000 is max i you want use 2 sec GOP besides you use DVD or BD
3. you can still use 1 sec gop.
so if you don't use 2 sec GOP that mean you will use 1 second instead. I will somehow fix this.
@all, be patient
