Old 17th May 2010, 05:53   #161  |  Link
Selur
Selur's Avatar
Hybrid ver.100517
*fixed*
- analysing of raw audio input
- hopefully all autocrop problems
*cosmetics*
- new Hybrid icon -> thanks to FAUST
*added*
- some additional sanity-checks
*adjusted*
- avsInfo output analysis
*updated*
- windows 32bit package
sidenote: includes now an avsInfo and an avsInfo64 binary, if you want to use avisynth 64bit change to the avsInfo64 one in the Misc->Tools menu
(you need to enable Misc in the Main-Tab to enable the Misc-Tab)
Reset Defaults in Misc-Tab on first start
-> updated links in 1st post
Old 17th May 2010, 15:52   #162  |  Link
netcasthd
DVD Input does not work. If you check the DVD Input box, go to a DVD folder, it will analyis the DVD video but stay grayed out. It does not give you back control.
netcasthd is offline   Reply With Quote
Old 17th May 2010, 15:54   #163  |  Link
Selur
Selur's Avatar
Yup, it's a bug and I'm hunting it.
Old 17th May 2010, 20:23   #164  |  Link
Selur
Selur's Avatar
*updated*
- all the downloads in first post since old versions were broken
(switched aften, mediainfo and fixed some typos in Hybrid that caused the problems)
-> you should update to current version
Old 18th May 2010, 11:25   #165  |  Link
ckmox
just a noob question is there an Framerate (FPS) option on Hybrid similar to Handbrake's Framerate (FPS) that can be set to "same as source"
im thinking of retaining the original Framerate of the source so that on sources like VFR the audio will not be out of sync
ckmox is offline   Reply With Quote
Old 18th May 2010, 16:19   #166  |  Link
CpT
In the filtering tab make sure "Scale output frame rate" isn't checked
CpT is offline   Reply With Quote
Old 18th May 2010, 16:50   #167  |  Link
Selur
Selur's Avatar
and if you find a problem post it / pm me and I'll try to fix it
(haven't done much testing with vfr content, since I normally don't encounter it)
Old 19th May 2010, 04:18   #168  |  Link
ckmox
ok thanks for that
and thanks for the awesome program selur this gui of yours is better than MeGUI because this is much more portable
Old 19th May 2010, 07:31   #169  |  Link
Selur
Selur's Avatar
Hybrid ver.100519
*fixed*
- crash with multi subtitles
- audio tagging of raw streams on passthrough
(not needed when updating from 100517)
Old 29th May 2010, 10:38   #170  |  Link
Selur
Selur's Avatar
Hybrid ver.100529
*changed*
- using '-vf' scale,crop,pad instead of Crop/Pad Left/Right/Top/Botton and scale in ffmpeg
(-> Hybrid needs newer ffmpeg version)
- CropView FFmpeg renamed to Avisynth
*fixed*
- audio lang tagging of raw streams
- vbv buffer from 40000 to 3000 for BD
- subtitle order
*added*
- experimental (blind) cut support
- load/save joblist options
*updated*
'Reset Defaults' in Misc-Tab on first start
Old 29th May 2010, 17:37   #171  |  Link
Selur
Selur's Avatar
Hybrid ver.100529_1
*100529_1*
*fixed*
- recalc bitrate for multiple audio streams
(not needed when updating from 100529)
Old 30th May 2010, 21:27   #172  |  Link
Selur
Selur's Avatar
Hybrid ver.100530
*fixed*
- mp4 muxing of he-aac reencoded material
- missing " "- around mplayer path when analysing dvd
- bug when extracting audio with ffmpeg
- audio downmix unintended switching to toMono on multiple stereo input
- ac3 in .avi analyse
(not needed when updating from 100529 or later)
Old 31st May 2010, 15:04   #173  |  Link
Selur
Selur's Avatar
For those interested, I made a Hybrid build with (experimental) Blu-ray/.mpls input support. When in Blu-ray mode, select the PLAYLIST folder, if not you can select .mpls from a blu-ray as input.
(got no blu-ray's myself but I tested with the x264 BD Demo and another BD Demo bigotti5 form the german doom9 forum authored for me and it seems to work )
Cu Selur
Old 31st May 2010, 15:07   #174  |  Link
CpT
ooo sweet.
I have a ton of blu-ray's. When I get a min I'll test it.
Old 1st June 2010, 16:58   #175  |  Link
Selur
Selur's Avatar
did you find some time to test it?
Old 1st June 2010, 17:01   #176  |  Link
CpT
I got busy with another project.
Downloading it now
Old 1st June 2010, 17:17   #177  |  Link
CpT
Hybrid crashed while doing the initial analysis.
Old 1st June 2010, 17:19   #178  |  Link
Selur
Selur's Avatar
give me a minute (seems like a bug I added with my last changes before compiling,..)
Old 1st June 2010, 17:34   #179  |  Link
Selur
Selur's Avatar
redownload, should work now (accidentally deleted a line of code on my winxp system)
Old 1st June 2010, 17:42   #180  |  Link
CpT
Analysis works now.
I'm setting up the rest and will test shortly. Thanks.
