Old 4th March 2011, 20:49   #721  |  Link
fabje
Originally Posted by cweb View Post
IMHO it should work. Remember to use the 64 bit Yadif.
I'd like to encourage people to port plugins to 64 bits as it helps with the adoption of the 64 version...
I'm using a 64Bit version of Yadif, but I keep getting this error:
Unable to load C Plugin: E:\Staxrip\Applications\AviSynth\plugins\Yadif\yadif.dll(E:\source temp files\source.avs, line 1)
I got the 64bit Yadif from here.
When I disable Yadif the encoding will start.
CPU: i7 3930K @ 4.5Ghz MEM: 16GB GPU:NVIDIA GeForce GTX680 OS: Windows 7 64Bit
fabje is offline   Reply With Quote
Old 4th March 2011, 21:03   #722  |  Link
cweb
cweb's Avatar
I haven't tried using yadif since I usually use DGIndexNV for GPU-based deinterlacing.. perhaps you could try this.
PC specs for bug reports: Athlon 64-bit Phenom II X6 2.8Ghz Win7/Linux PCI express NVIDIA GTX 285 graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 4th March 2011, 21:09   #723  |  Link
fabje
Well I'm using FFMPEG and the reason for that is because it speeds up the encoding of an 1280x720 mkv file with 40fps more. Well at least when I was using DGAVCIndex.
When I'm using DGIndexNV I get this error: Unable to load ("DGDecodeNV.dll"), but the path to the file is correct.
Old 12th March 2011, 23:35   #724  |  Link
fabje
Someone knows how to solve this?
Old 12th March 2011, 23:58   #725  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
I take it that you switched out Staxrip's version of the Yadif plugin, and replaced it with your own?
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 13th March 2011, 00:18   #726  |  Link
fabje
Yes this is what I replaced with a 64bit version.
I changed this to 64bit:
Avisynth
FFDShow
Autocrop
Yadif
x264
The only thing that I didn't find was Lanczos in 64bit.
Old 16th March 2011, 22:05   #727  |  Link
fabje
Nobody?
Old 17th March 2011, 08:06   #728  |  Link
cweb
cweb's Avatar
Nobody?
I might try it if I find some time in the coming days.
As I said I use the GPU's deinterlacing that's why I had never tried the 64 bit yadif.
Old 18th March 2011, 02:49   #729  |  Link
Delerue
Sorry if this sound a little off-topic, but since GPU deinterlacing requires DXVA (or am I wrong?) do you know any kind of CPU deinterlacing that uses vector adaptive technology?
Edit: is there a 64 bit version of QTGMC?
Thanks
Delerue is offline   Reply With Quote
Old 18th March 2011, 02:58   #730  |  Link
Mr VacBob
There are several non-realtime motion adaptive deinterlacers available as Avisynth scripts. Try yadif and see if you're unhappy with it.
Mr VacBob is offline   Reply With Quote
Old 18th March 2011, 04:20   #731  |  Link
Delerue
Sorry, I mean vector adaptative. Yadif isn't a vector adaptive technology, right?
Old 18th March 2011, 12:35   #732  |  Link
trevaaar
QTGMC is a script, not a plugin. As long as you get a 64-bit version of all its dependencies it runs fine, I'm using it right now for an encode.
trevaaar is offline   Reply With Quote
Old 18th March 2011, 18:42   #733  |  Link
Delerue
@trevaaar, thanks for the tip. I'll try later.
Old 20th March 2011, 09:25   #734  |  Link
Delerue
I've tried to run QTGMC with all 64-bit dependencies, but no success. It crashes instantly with MPC-HC x64 1.5.2.2972 + FFDShow x64 3760. I've tried to use with avisynth tab inside FFDShow (checking 'Add ffdshow video source') using only this line of code:
QTGMC( Preset="Medium" )
Here's the list of the dependencies I have:
nnedi3_64.dll (0.9.2.0)
mt_masktools-25-x64.dll (2.0.48.0)
mvtools2.dll (last 'official' version of Joshua Duncan from the first page of this very thread)
avisynth.dll (same as above)
Repair.dll and Removegrain.dll (from here: http://code.google.com/p/avisynth64/wiki/PluginLinks)
Any idea?
Old 23rd March 2011, 09:36   #735  |  Link
camorra
Any idea?
Same problem here...
win7 x64 prof. I tried all QTGMC versions but no results.
camorra is offline   Reply With Quote
Old 23rd March 2011, 18:06   #736  |  Link
Delerue
Try this, unchecking the option 'Add ffdshow video source':
setMTMode(2,4)
ffdshow_source()
ComplementParity()
QTGMC( Preset="Medium", EdiThreads=4 )
distributor()
Old 7th April 2011, 08:52   #737  |  Link
camorra
setMTMode(2,4)
ffdshow_source()
ComplementParity()
distributor()
nope, doesnt works :/
Old 8th April 2011, 04:10   #738  |  Link
Delerue
You also should have this installed: http://www.microsoft.com/downloads/e...3-d6acabd5d13b
If even with this you don't get any success, maybe you should download the new full package in the first page of this thread.
Old 20th April 2011, 13:53   #739  |  Link
camorra
got 2008, 2005... still same problem. :/
Old 20th April 2011, 14:21   #740  |  Link
Didée
@ camorra: You're a bit vague with your initial "same problem here". Is it specifically when you try to use QTGMC within ffdshow-tab/Avisynth in MPC-HC64? Can you load & run that script in VeeDub64, or not?
In any case, try it without "distributor()" ....
