2nd April 2010, 11:23 | #441 | Link | ||
Programmer (or just 教务长)
r1309M:
r1510: Quote:
I think the difference is not with the switches but with the patch [x264_hrd_pd_interlace.16_r1301.diff] which is working. I'll have to find the latest x264 revision which works with this hddvdmux and report back. Last edited by deank; 2nd April 2010 at 11:30. |
2nd April 2010, 19:04 | #442 | Link | |
I'm getting very good results with x264 now- I wish someone made a GUI to make x264 more like finish product. DS, how can I force I frames (for chapters)? Can I segment re-encode? Thx |
2nd April 2010, 23:43 | #444 | Link |
Sorry if this has been asked a million times by now..
But is the pulldown option in current spec supporting hardware devices? i.e would my WDTV Live recognize a pulldown flag in an H264 encode? And is this intended to be used for VFR sources? I.e Anime? I've never encoded anything other than VFR MKV's so I know little about how pulldown works, etc.. What would be the process of encoding a file with pulldown? How do you specify where to flag pulldown scenes, etc? If there is some kind of documentation someone could link to.. I might like to read that to see if its of any potential use for me. Thanks. |
2nd April 2010, 23:49 | #445 | Link | |
3rd April 2010, 01:25 | #447 | Link | ||||
"Sorry if...": one of those weak conditional apologies.
3rd April 2010, 09:08 | #449 | Link |
--nal-hrd <string> Signal HRD information (requires vbv-bufsize) - none, vbr, cbr (cbr not allowed in .mp4)
3rd April 2010, 10:02 | #451 | Link |
Just a wrong assumption, some switches lack <string>, --profile, --preset etc.
The default value for --nal-hrd is none, right?
3rd April 2010, 12:52 | #452 | Link |
Software Developer
void x264_param_default( x264_param_t *param ) { [...] param->i_nal_hrd = X264_NAL_HRD_NONE; [...] }
3rd April 2010, 22:14 | #453 | Link |
x264 developer
x264 build with (hopefully) HRD fixed.
Test this build and see if it passes muxing--if it does, we'll push it and x264 will be Blu-ray compliant. Really, this time! |
4th April 2010, 08:42 | #454 | Link |
Ok, i've got it. Result from me not before tomorrow, time to encode...
Encoding will be with : @echo off SET E_SRC=%6%1.avs SET E_DST=%3%1.264 SET STAT_FILE=%1.stats SET TUNING=%4 SET LOG_FILE_1=%1_log_1.txt REM Set of max bitrate (ici le bitrate max) set MAX_BR=39000 REM Set of Buffer (ici le buffer) set BUF_BR=30000 x264_x86.exe --profile "high" --preset "placebo" --tune %TUNING% --bitrate %2 --stats %STAT_FILE% --level "4.1" --qpmin 0 --qpstep 2 --vbv-maxrate %MAX_BR% --vbv-bufsize %BUF_BR% --keyint 24 --min-keyint 2 --mvrange 511 --ref 4 --bframe 3 --slices 4 --b-pyramid "strict" --aq-mode 2 --aud --nal-hrd "vbr" --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --qpfile %5 --threads 0 --thread-input --output %E_DST% %E_SRC% 2> %LOG_FILE_1% tuning : animation bitrate : 39000 Last edited by jpsdr; 4th April 2010 at 08:45. |
4th April 2010, 12:46 | #455 | Link | |
4th April 2010, 13:17 | #456 | Link | |
x264 developer
4th April 2010, 16:42 | #457 | Link |
Well... I never said it is x264's fault...
I'm not much into c++ programming, but I took the liberty to edit the source of this tool which seems to use code fragments from h264_info. For some reason it can't properly detect/find the required data to start decoding the frames... I added some log lines and here is what I get: The working: Code:
(9)Access unit delimeter (7)Sequence parameter set (8)Picture parameter set (6)SEI (6)SEI (5)Coded slice of an IDR picture (9)Access unit delimeter (6)SEI (1)Coded slice of non-IDR picture (9)Access unit delimeter (6)SEI (1)Coded slice of non-IDR picture (9)Access unit delimeter (6)SEI (1)Coded slice of non-IDR picture Code:
(9)Access unit delimeter (7)Sequence parameter set (8)Picture parameter set (9)Access unit delimeter <<-- I guess here it gets confused because it misses 3 important packets (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (?)unknown value (7)Sequence parameter set (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (7)Sequence parameter set (8)Picture parameter set (2)Coded slice of data partition A (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (9)Access unit delimeter (3)Coded slice of data partition B (9)Access unit delimeter (7)Sequence parameter set (8)Picture parameter set (?)unknown value the working stream has 00 00 00 01 06, while the non working has 00 00 01 06 --- and that's exactly what confuses the tool (the red-bold text above). Probably it doesn't recognize the bitstream. I also tried with 0 and 4 slices with the same result. The resolution in 2 packets back is proper: (04 16) (07 8C) while in the other is (48 28) (07 8C)... I'm probably completely wrong to compare these things, but I just wanted to report my limited findings. I hope it is not a complete waste of your time to check it. Dean Last edited by deank; 4th April 2010 at 17:02. |
4th April 2010, 19:27 | #460 | Link |
Pig on the wing
Does anybody have any figures how much more efficient the interlaced encoding should now be compared to the previous version without this patch? I did a test on an interlaced clip (5000 frames) and the bitrates were almost the same with r1471 and r1510. I did apply the TFF option in r1510 and "interlaced" in r1471. Other settings stayed the same.
