Old 23rd May 2010, 22:37   #1061  |  Link
Zathor
Originally Posted by alexcel View Post
  • If a create a job to encode, and then close megui, and then open megui later to execute pending jobs, jobs do not start as cuvid server is not running. I have to start it manually
  • Autoencode fails: after selecting avs script, pressing autoencode nothing happens and later when trying to abort megui crashes
  • In avs creator, Analyse stream fails, nothing happens and megui crashes
Please try to disable the usage of the CUVIDServer in the MeGUI settings (you have to create the avs files again or edit them to use dgmultisource()).
I need to have a look at your first problem. The server should be started automatically.
Zathor is offline   Reply With Quote
Old 24th May 2010, 08:04   #1062  |  Link
quantum5uicid3
while the bitrate calc is being looked at, any chance that defaults for container, audio type/bitrate, and target size could be saved. even better would be having the option to bypass the current bitrate calculator window completely and just have the chosen default selections automatically plugged into the video length to calculate encoder bitrate.
i'd be happy either way.
quantum5uicid3 is offline   Reply With Quote
Old 24th May 2010, 21:25   #1063  |  Link
alexcel
I have disabled CUVIDServer and all problems are gone, even my first one as I have disabled the use or need for cuvidserver.. You are great.
By the way, I think this option should be disabled by default or even removed
alexcel is offline   Reply With Quote
Old 24th May 2010, 23:30   #1064  |  Link
I agree that DGMultiSource() should be the default now. The new version DGDecNV 2008 coming in a few hours will have the Quick Start guide revised that way. CUVID server was created only because originally DGMultiSource() would not work with the pre-Zathor builds.
Old 25th May 2010, 11:25   #1065  |  Link
Zathor
I will switch it in the next build.
But it will be of course only switched for new installations because already existing settings will not be changed.
Old 25th May 2010, 13:21   #1066  |  Link
Betsy25
What is the point of the "Subtitles" input field in the Avisynth Script creator window, when it doesn't add them ?
In the script source window, there is
LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_plugin\VSFilter.dll")
VobSub("S:\My DVDs\2012\VIDEO_TS\VTS_01_0.idx")
But in the final encoding, there were no hardcoded subs at all ?
Betsy25 is offline   Reply With Quote
Old 25th May 2010, 16:45   #1067  |  Link
Nightshiver
Quality Freak
Use textsub.
Nightshiver is offline   Reply With Quote
Old 25th May 2010, 19:47   #1068  |  Link
Emp3r0r
Emp3r0r's Avatar
Originally Posted by Dal View Post
And when I enter the Bitrate calculator and select output size (both audio and video info seems to be filled out here too), but the Apply button remains greyed out. Here's a picture:
I am not able to reproduce. When I open the bitrate calculator, the video and audio details are filled in but the Total File Size says "Not calculated" and I must choose a size. Once I choose a size the apply button is active.
Can anyone else reproduce?
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server
Emp3r0r is offline   Reply With Quote
Old 25th May 2010, 20:54   #1069  |  Link
Betsy25
Originally Posted by Nightshiver View Post
Use textsub.
Are you serious ? TextSub for .idx files ?
Anyway I have to revert to both Megui and StaxRip.
MeGUI which is able to extract the correct language streams while StaxRip can't.
Staxrip for doing the actual conversion because it is able to hardcode the .idx subs correctly while MeGUI can't....
Old 25th May 2010, 23:12   #1070  |  Link
quantum5uicid3
load the sub, not the idx
VobSub("S:\My DVDs\2012\VIDEO_TS\VTS_01_0.sub")
and with blurays, use suptitle
http://www.zachsaw.co.cc/?pg=suptitl...visynth_plugin
example
SupTitle("F1_T8_Subtitle - English.sup")
Old 26th May 2010, 02:39   #1071  |  Link
Betsy25
example
Thanks, I cannot see the VobSub("") sequence in the StaxRip .avs, but it works, perhaps Zathor can fix the Avisynth Script Editor so that choosing subtitles to hardcode from it will select the .sub and not the .idx by default.
Old 26th May 2010, 06:09   #1072  |  Link
quantum5uicid3
loading the idx should work also, but maybe a version mismatch or something is occuring. the idx is a text only index file
Old 26th May 2010, 22:32   #1073  |  Link
Dal
Very strange.
I have no problem reproduce every time I try
For my sake, I hope someone else are able to reproduce
Thanks
Dal is offline   Reply With Quote
Old 27th May 2010, 10:24   #1074  |  Link
zelenin
zelenin is offline   Reply With Quote
Old 27th May 2010, 19:11   #1075  |  Link
zanuda
zanuda's Avatar
the same problem
the "new" bitrate calculator doesn't work
zanuda is offline   Reply With Quote
Old 27th May 2010, 22:05   #1076  |  Link
Emp3r0r
Emp3r0r's Avatar
Can somebody with the bitrate calculator problem open DebugView and paste any exceptions you see when choosing total file size?
DebugView: http://technet.microsoft.com/en-us/s.../bb896647.aspx
Old 27th May 2010, 22:13   #1077  |  Link
zelenin
when i choose Total file size:
[1652] MeGUI.exe Error: 0 :
[1652] System.FormatException: Input string was not in a correct format.
[1652] at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
[1652] at System.Number.ParseSingle(String value, NumberStyles options, NumberFormatInfo numfmt)
[1652] at System.Single.Parse(String s, NumberStyles style, NumberFormatInfo info)
[1652] at MeGUI.packages.tools.calculator.CalcData.CalcQualityCodecModifier()
[1652] at MeGUI.packages.tools.calculator.CalcData.CalcByTotalSize()
[1652] at MeGUI.Calculator.Calculate()
Old 28th May 2010, 16:13   #1078  |  Link
Emp3r0r
Emp3r0r's Avatar
thanks @zelenim I have identified the issue and I'm working on a patch
Old 28th May 2010, 16:18   #1079  |  Link
Dal
I get this when I open Bitrate Calculator from the MeGui Tools menu:
[3224] MeGUI.exe Error: 0 :
[3224] System.ArgumentException: Frames must be greater than zero.
[3224] Parameternavn: frames
[3224] ved MeGUI.packages.tools.calculator.CalcData..ctor(Int64 frames, Decimal fps, ContainerType container, VideoCodec codec, Boolean bframes, AudioBitrateCalculationStream[] audios)
[3224] ved MeGUI.Calculator.Calculate()
[3224] System.InvalidOperationException: Et objekt som kan nullstilles må ha en verdi.
[3224] ved System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
[3224] ved System.Nullable`1.get_Value()
I'm not sure what I can translate "Et objekt som kan nullstilles må ha en verdi" into, that is Norwegian as it is now.
Old 28th May 2010, 17:44   #1080  |  Link
Emp3r0r
Emp3r0r's Avatar
Zelenin or Dal: can you try this exe and see if it fixes your problem with the culture parsing of the modifier values:
http://jvance.com/files/MeGUI.zip
