#1 | Link |
Scenarist BD 5.1 Can`t Rebuild!
Hi,All!
I have a new problems! I demux from an existing disc, 1.Drag the primary video stream to scenarist BD 5.1. 2.Build a movie clip 3.Drag this clip to playlist. 4.Build title and drag playlist to here 5.MUX start 6.Error! I am very sure the problem is that video stream... How to do it? thanks! ![]() Last edited by 24673583; 3rd September 2009 at 17:02. |
#5 | Link |
so,i feel very strange!
when i close mux monitoring,then tips: Error : [Mux] Mux processed error. For details, refer to the MUX Remoting Server log. GUID: [f0dd29a0-a7b9-42b5-8bf2-8cb95a2c3342] server log tips see picture 2 |
#8 | Link |
Your pictures finally showed up... Not sure what the deal was, but I couldn't see them or download them, they weren't even clickable links...
You have a buffer underflow in the video file, it's not spec compliant. That's why Scenarist is rejecting it. The original disc was probably created with a software package that doesn't check the assets for spec compliance. Your only option, if you want to use Scenarist, is to re-encode the video and try to get a proper stream. What disc is this from? |
#10 | Link |
Heh, oops, didn't even look at that...
![]() Hmm, wouldn't expect a studio title to have this problem, but it also wouldn't be the first time I've seen it happen... It would be interesting to see if it would mux in Scenarist 4.5. They may have increased the detail of the spec compliance in the 5.x version... We don't even get the movie until next week (in the US), so I can't try it until then. Last edited by rik1138; 8th September 2009 at 05:58. |
#11 | Link |
It can drag to 4.2/4.3/4.5,but can`t be rebuild, see upload picture! It can`t drag to 5.0/5.1! tips: Error : The picture is not encoded as multi-slice picture with 4 or more slices per picture in case of Level 4.1.(Slice:1) So,I try to re-encode the video and get a proper stream. Then,It can drag to 4.2/4.3/4.5/5.0/5.1,But it is still can`t be rebuild! |
#12 | Link |
What did you use to re-encode it?
I'll be getting the US version of Van Helsing on Tues... I'll try it with that, it'll be interesting to see if they used the exact same video for both releases... Is it the feature you are trying to re-do? Why are you re-doing it, anyway? Would something like tsMuxer work better? If you just want the video to play on a BD player, tsMuxer might work for you... Last edited by rik1138; 12th September 2009 at 00:35. |
#14 | Link | |
#15 | Link |
Do you need the PiP? tsMuxer can remove the PiPs and create a playable stream (if you don't want them, that is...)
I got the US version of the movie, demuxed it and tried it in Scenarist 5.1.2 (not using 5.1.3 just yet), and I couldn't make it import either. It gets all the way to 99% of the MUI creation, and then fails with an error (not the same error you got, something about 'DTS' at the end of the file (note- DTS is not referring to the audio, it stands for something video-encode related, but I forget what...) This isn't the first time I've seen Scenarist fail to accept a file from a replicated disc (even the DVD version of Scenarist would do this sometimes)... I'm going to try it in 4.5.3 just for laughs, see if I get different results. Sometimes you just can't make it work, not sure why. |
#16 | Link | |
I don`t want remove it! So,I must need Scenarist BD rebuild it! you can try to re-encode the video ,maybe can be import either! This Error,I remember i have done so! |
#17 | Link | |
I don`t want remove it! So,I must need Scenarist BD rebuild it! you can try to re-encode the video ,maybe can be import either! This Error,I remember i have done so! my software is expired! so,i can not use Scenarist BD 5.1.2 do it! I can only use scenarist 4.3... |
