Old 3rd July 2009, 10:07   #1  |  Link
Zachs
Suptitle, MediaPlayer.NET
SupTitle: an AviSynth PGS (.SUP) Subtitle Plugin
Hi folks,
I've looked around for an AviSynth plugin to hard sub (I mostly hard sub the forced subtitles) my rips but was unable to find any.
So I've created an AviSynth plugin called SupTitle to do just that. It handles .SUP files extracted from eac3to (both HD and BD). Note that some users have tried to use SupTitle on DVD and HDTV subs and complained it doesn't work. So let me reiterate - SupTitle handles HD-DVD and Bluray .SUP files extracted by eac3to.
You'll need Microsoft .NET Framework 4 installed.
Cheers.
Current version: v2.0.8
Download: http://www.zachsaw.com/?pg=suptitle_pgs_avisynth_plugin
*** Make sure you read the installation guide in detail or you'll get an error message from AviSynth complaining "Could not load plugin".
Zachs is offline   Reply With Quote
Old 3rd July 2009, 10:14   #2  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by Zachs View Post
If there's enough interest, I'll make it available for download.
yes, please...
You'll need .NET 2 framework installed.
why ?
Old 3rd July 2009, 12:45   #3  |  Link
Zachs
The plugin is coded in MC++ and C#. But, all the frame-to-frame intensive ops are coded in ASM.
Old 5th July 2009, 22:17   #4  |  Link
sneaker_ger
I'm also interested. Please put it online - I'm pretty sure Kurtnoise and I aren't the only ones who'd like to give it a try.
Old 6th July 2009, 03:39   #5  |  Link
Zachs
Ok, here it is.
# Supported colorspaces - YV12, YUY2, RGB24, RGB32
# SIMD optimizations
# Alpha channel transparency blending
# Handles both HD-DVD and Blu-ray .SUP subtitle files extracted by eac3to
# Perfect for hardsubbing forced subtitles with forced flag detection (e.g. subs for foreign dialogues)
# Supports seek and jump
Note: It takes a while to start especially with large SUP files. SupTitle reads, verifies and caches all the SUP metadata on startup.
Old 6th July 2009, 16:18   #6  |  Link
b66pak
b66pak's Avatar
thanks...
_
Old 7th July 2009, 12:32   #7  |  Link
sneaker_ger
Thank you!
Old 8th July 2009, 08:41   #8  |  Link
Zachs
SupTitle version 1.0.1 available
New version v1.0.1 is available. I've implemented additional optimizations. Speed improvement is definitely noticeable. Test the latest version instead.
Cheers.
Old 8th July 2009, 18:48   #9  |  Link
GrofLuigi
Member of a Library
Sorry for my noobishness, but can this be useful for SD-DVD? Is there something that can rip DVD to .SUP format that this plugin accepts?
GL
GrofLuigi is offline   Reply With Quote
Old 9th July 2009, 01:41   #10  |  Link
Zachs
This plugin accepts blu-ray and hd-dvd sup files extracted by eac3to. If you can convert DVD subs to the same format, then chances are SupTitle will not reject it.
Old 9th July 2009, 15:01   #11  |  Link
GrofLuigi
Member of a Library
Thank you for your reply, that's what I thought. Will try to make it work somehow in the future (I'm busy with other things right now).
GL
Old 10th July 2009, 17:11   #12  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
I have to ask, why the hell would you do that? There are already subtitle plugins for SD DVD's. VSFilter anyone? There is no point in converting to a HD format (and losing quality in the process), when you could just sub the SD version using already available tools.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 10th July 2009, 23:10   #13  |  Link
GrofLuigi
Member of a Library
I had a stupid idea to hardcode the original subtitles as they appear (bitmaps, .sub & .idx, not rendered with fonts). VSFilter can't do that, I think... Can it?
No conversion to HD planned.
GL
Old 11th July 2009, 15:12   #14  |  Link
Wilbert
Am I correct that you are not allowed to use it in a commercial setting (because that's what this eula is saying)? I would be nice if you could release it as open source.
Old 13th July 2009, 01:38   #15  |  Link
Zachs
Yes you're right.
No plans for open source ATM.
Old 13th July 2009, 17:46   #16  |  Link
Gokumon
Posts: n/a
The VS in VSFilter is for VobSub so of course it supports Vobsub format sub/idx. It also supports the MicroDVD format of bitmapped subtitles.
Old 19th August 2009, 00:07   #17  |  Link
sneaker_ger
I'm having a problem with your plugin. The subtitle in this sample is displayed in blue instead of the correct red.
Sample
Old 20th August 2009, 06:20   #18  |  Link
Zachs
Hmm. Which app did you use to display the subtitle?
I think it depends on how the app converts YUV to RGB.
SupTitle uses the following formula:
YUV to RGB Conversion
B = 1.164(Y - 16) + 2.018(U - 128)
G = 1.164(Y - 16) - 0.813(V - 128) - 0.391(U - 128)
R = 1.164(Y - 16) + 1.596(V - 128)
From here http://www.fourcc.org/fccyvrgb.php
Which app created the sup file?
Old 20th August 2009, 09:05   #19  |  Link
Zachs
Also, there seems to be some unknowns in the PGS format such as the sequence of the Y'cbcr bytes.
That's the reason you get to swap cr/cb in BDSup2Sub.
I'd be interested to see how a standalone player displays the subtitle.
Old 20th August 2009, 14:34   #20  |  Link
sneaker_ger
I tried creating the subtitles with PunkGraphicStream, avs2bdnxml + bdssup2sub and avs2bdnxml + bdsubedit. I don't have a standalone blu-ray player yet, but in MPC-HC and Power DVD all the subtitles are displayed in the correct red colors.
I'm using AviSynth's "blankclip" and it happens in RGB24, RGB32, YUY2 and YV12. While the subtitles appear blue in all four color spaces, in RGB24 and RGB32 the whole image gets green (overlaying anything that was beneath it). For playing I use VirtualDub and MPC-HC.
avisynth, hard sub, plugin, subtitle, suptitle
