Old 12th June 2010, 20:37   #1621  |  Link
Originally Posted by Clumpco View Post
Mainly because I am busy encoding something at the moment
You can't run DGSplit during an encode? Your computer is single-tasking?
Old 12th June 2010, 20:54   #1622  |  Link
yesgrey
Encoding result with 64 bit tools for Baraka cropped to 1920*872 on my new rig :
29.28 fps encoding speed. It's better than real time!
It would be cool if you also posted the result with 32 bit tools, for comparison...
Old 12th June 2010, 21:15   #1623  |  Link
How do I force Avisynth 32 without jumping through hoops?
Old 12th June 2010, 21:25   #1624  |  Link
nixo
nixo's Avatar
...and load the plugin manually - or change the plugin directory in the registry.
nixo is offline   Reply With Quote
Old 12th June 2010, 21:26   #1625  |  Link
GZZ
how do you make Avisynth 64 bit working. I have tried this one: http://85.230.118.163/showthread.php?t=152800 and my avisynth script is like this:
LoadPlugin("d:\dgdecnv2011\x64_Binaries\DGMultiDecodeNV.dll")
DGMultiSource("d:\Encoding\MR73\Video.dgi")
I cant play my avs file in mpc and x264 just say failed to load avisynth.
Also when I run the avisynth install is says: 64-bit windows not detected. This is wrong, because I'm running 64 bit windows 7... So are you using the same avisynth as me ?
GZZ is offline   Reply With Quote
Old 12th June 2010, 21:32   #1626  |  Link
Thank you, Stephen and nixo.
64: 29.28
32: 26.70
So the gain from 32 -> 64 is not so great (although 10% is not insignificant). I was remarking more on the boost from the i7-980X versus my old E8500 dual core. I'm not used to real-time encoding of HD video.
Blue_MiSfit was right:
"It will make whatever you had before seem like a toy!"
Old 12th June 2010, 21:35   #1627  |  Link
Yes. Have you followed the installation instructions exactly? If so, you really ought to post in that thread as it is a bit OT here.
Old 12th June 2010, 21:35   #1628  |  Link
Inspector.Gadget
GZZ, I don't want to take this too far OT, but make sure:
1) You've installed joshyd's build by running the install.cmd as an admin AFTER installing Avisynth x86.
2) You've copied the 64-bit DGMultiDecodeNV.dll to your plugins64 directory.
3) You have a 64-bit YV12 decoder (e.g., ffdshow installed and configured) and are previewing the script in a 64-bit build of MPC-HC.
4) You're attempting to encode with a 64-bit build of x264.
Inspector.Gadget is offline   Reply With Quote
Old 12th June 2010, 21:38   #1629  |  Link
GZZ
Thanks Neuron2 and inspector. I will reboot and redo everything to see if it works...
Old 12th June 2010, 21:46   #1630  |  Link
Clumpco
Clumpco's Avatar
D'oh!
I forgot about DGSplit. (Please note though that until 17 minutes ago I was also recording BBC HD while encoding and I didn't want to push my luck doing much else, also the Missus had urgent on-line shopping to do).
OK we have two samples: one edited by VideoRedo and one trimmed by DGSplit. The VideoRedo one causes the error, the DGSplit one doesn't.
BBCHDEditedByVideoRedo.rar
BBCHDTrimmedByDGSplit.rar
Please note that using DGIndexNV's "Output trimmed TS" produces a TS that then provokes the error if you try to index it again in DGIndexNV.
Also note that VideoRedo have a similar file trimmer, but it too must change something because its output also provokes the error.
The stream came from BBC HD (on Sat) via a Technisat Skystar HD2 card, captured using DVBViewer Pro 4.2.1.0. DVBViewer is set to "Adjust PAT/PMT" as this was necessary in the past for BBC HD; it may no longer be so.
Finally, the unedited stream, indexed with in and out points in DGIndexNV, seems to be successfully encoding in MeGui, it passed the "hang point" at the end of the first pass where the edited version failed.
Thanks in advance.
Clumpco is offline   Reply With Quote
Old 12th June 2010, 21:50   #1631  |  Link
I didn't want to push my luck doing much else, also the Missus had urgent on-line shopping to do.
LOL. Who's wearing the pants around your place?
Get out! No way, Jose. I'll investigate right away...when I get back from the pool.
Old 12th June 2010, 22:46   #1632  |  Link
InsulinJunkie
InsulinJunkie's Avatar
not to mention the problems it will cause with other users. Why not ditch that stupid theme?
It's not worth the effort to fix it, but it's not one theme - it's pretty much every Vista/Win7 theme with the exception of the non-Aero Windows "Classic"/"Basic" themes.
I've always noticed the issue Clumpco described (I imagine many Vista/Win7 users have), but it's not a big deal. Since you're running XP, it makes sense you wouldn't see it.
InsulinJunkie is offline   Reply With Quote
Old 12th June 2010, 23:22   #1633  |  Link
yesgrey
Well... 10% of a little thing is still a little thing, but 10% of a big thing is relevant. I have some encodes waiting because each will take me around 24h!... now I could do them in "only" 22h.
Old 13th June 2010, 01:24   #1634  |  Link
So, when you trimmed you cut off the SPS and PPS needed by the first frame. Therefore, the error message is correct. But it is irritating. So I changed it to silently just skip stuff until it has the SPS and PPS that it needs. The fix will be in the next build. Thank you for pointing this out.
Both the VideoRedo and DGIndexNV TS trimmers could be more intelligent about this but it would be tricky to implement. If they do it, I'll do it.
Old 13th June 2010, 02:19   #1635  |  Link
The dgi/avs produced after this error hangs at 1 second from the end of the 1st pass of encoding with MeGui/x264.
That's not good. I'll look at that next. It's probably an incomplete picture at the end but DGNV shouldn't hang. I should see EOF and terminate gracefully.
Old 13th June 2010, 08:00   #1636  |  Link
tormento
Acid fr0g
tormento's Avatar
I don't use GUIs for encoding in any environment.
How do you feed the avs to x264?
@turment on Telegram
tormento is online now   Reply With Quote
Old 13th June 2010, 08:43   #1637  |  Link
hydra3333
Well, here's an example - drag and drop a PAL 1440x1080i TFF .mpg onto this .bat file.
@echo on
REM HD 1080i for WDTV Live (not 1088i)
REM SETLOCAL ENABLEDELAYEDEXPANSION
set PARF1=%~f1%
set PARF2=%~dpn1%
set parpath=%~dp1%
set pard2v=%~dpn1%.d2v
set pardgi=%~dpn1%.dgi
set PARtemp=%~1%-temp.MP4
set PARmp4=%~dpn1%.MP4
set PARAC3mp4=%~dpn1%.AC3.MP4
set PARMP2mp4=%~dpn1%.MP2.MP4
set parAC3=%~dpn1%.ac3
set parMP2=%~dpn1%.mp2
"C:\software\DGindex\DGIndexNV.exe" -i "%PARF1%" -a -o "%pardgi%" -e
IF EXIST "%parAC3%" DEL "%parAC3%"
FOR %%A in ("%~dpn1*ms.ac3") DO (
ECHO ------------------
ECHO Deleting "%parAC3%"
DEL "%parAC3%"
ECHO Renamnig "%%~A" to "%parAC3%"
MOVE "%%~A" "%parAC3%"
IF EXIST "%parMP2%" DEL "%parMP2%"
FOR %%A in ("%~dpn1*ms.mp2") DO (
ECHO Deleting "%parMP2%"
DEL "%parMP2%"
ECHO Renamnig "%%~A" to "%parMP2%"
MOVE "%%~A" "%parMP2%"
SET avs1=%PARF2%.avs
echo # "%avs1%" > "%avs1%"
echo LoadPlugin("C:\SOFTWARE\DGindex\DGMultiDecodeNV.dll")  >> "%avs1%"
echo LoadPlugin("C:\SOFTWARE\DGindex\DGDecode.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\NNEDI2.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\Yadifmod.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\DePan.dll") >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\AGC.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\Cnr2.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\dctfilter.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\fft3dfilter.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\degrainmedian.dll") >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\Convolution3d.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\despot.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\WarpSharp.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\aWarpSharp.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\mt_masktools.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\mvtools2.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\Unfilter.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\AddgrainC.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\hqdn3d.dll")  >> "%avs1%"
echo # ------------------------------------------------------------------------------------- >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\VariableBlur.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\FFTQuiver.dll")  >> "%avs1%"
echo #LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\RemoveGrain.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\RemoveGrainSSE2.dll")  >> "%avs1%"
echo #LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\Repair.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\RepairSSE2.dll")  >> "%avs1%"
echo #LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\RemoveDirt.dll")  >> "%avs1%"
echo LoadPlugin("C:\Program Files\AviSynth 2.5\plugins-zzz\RemoveDirtSSE2.dll")  >> "%avs1%"
echo Import("C:\Program Files\AviSynth 2.5\LimitedSharpenFaster.avs") >> "%avs1%"
echo Import("C:\Program Files\AviSynth 2.5\Deblock_QED_MT2.avs") >> "%avs1%"
echo DGMultiSource("%pardgi%",deinterlace=2) #deinterlace=2 means double rate deinterlacing  >> "%avs1%"
echo AssumeTFF() >> "%avs1%"
echo Assumefps(25) >> "%avs1%"
echo trim(1,-999999) # fix a double-framerate bug in NV per http://forum.doom9.org/showthread.php?p=1391556#post1391556 >> "%avs1%"
echo #LAST.HEIGHT==1080 ? AddBorders(int left, int top, int right, int bottom) : LAST >> "%avs1%"
echo LAST.HEIGHT==1080 ? AddBorders(0,0,0,8) : LAST >> "%avs1%"
echo #Deblock_QED_MT2() #default quant1=24 >> "%avs1%"
echo #Deblock_QED_MT2(quant1=28) >> "%avs1%"
echo #Deblock_QED_MT2(quant1=32) >> "%avs1%"
echo #Deblock_QED_MT2(quant1=36) >> "%avs1%"
echo #Deblock_QED_MT2(quant1=40) >> "%avs1%"
echo #Deblock_QED_MT2(quant1=44) >> "%avs1%"
echo #Deblock_QED_MT2(quant1=48) >> "%avs1%"
echo #Deblock_QED_MT2(quant1=24,aOff1=1,bOff1=2,quant2=24,aOff2=2,bOff2=4) >> "%avs1%"
echo #Deblock_QED_MT2(quant1=36,aOff1=1,bOff1=2,quant2=24,aOff2=2,bOff2=4) >> "%avs1%"
echo Deblock_QED_MT2(quant1=48,aOff1=1,bOff1=2,quant2=24,aOff2=2,bOff2=4) >> "%avs1%"
echo #LimitedSharpenFaster(smode=4,strength=100) >> "%avs1%"
echo UnFilter(15,15) >> "%avs1%"
echo AssumeTFF() #choose the SAME field order like before deinterlacing >> "%avs1%"
echo SeparateFields().SelectEvery(4,0,3).Weave() #reinterlace. >> "%avs1%"
echo AssumeFPS(25) >> "%avs1%"
echo LAST.HEIGHT==1088 ? cropbottom(8) : LAST >> "%avs1%"
echo SetPlanarLegacyAlignment(True) >> "%avs1%"
"C:\software\X264\x264.exe" --thread-input --threads 3 --profile high --level 4.1 --preset fast --interlaced --tff --no-cabac --bitrate 8000 --sar 4:3 -o "%PARtemp%" "%AVS1%"
IF NOT EXIST "%parMP2%" "C:\software\ffmpeg\0-LATEST-BETA\bin\ffmpeg.exe" -i "%PARF1%" -y -ar 44100 -ac 2 -ab 224k -acodec mp2 -vol 768 "%parMP2%"
IF EXIST "%parAC3%" "C:\SOFTWARE\MP4box\MP4Box.exe" -add "%PARtemp%" -add "%parAC3%":lang=eng -new "%PARAC3mp4%"
IF EXIST "%parMP2%" "C:\SOFTWARE\MP4box\MP4Box.exe" -add "%PARtemp%" -add "%parMP2%":lang=eng -new "%PARMP2mp4%"
DEL "%PARtemp%"
DEL "%parAC3%"
DEL "%parMP2%"
DEL "%avs1%"
DEL "%pard2v%"
pause
exit
REM SAR = DAR / PAR
REM for 16:9 720x576i   use --sar=16:11 (most 4:3 are in 16:9 shell frame nowadays, so use this)
REM for 16:9 1440x1080i use --sar=4:3
REM for 16:9 1920x1080i use --sar=1:1
REM
REM http://developer.divx.com/docs/divx_plus_hd/Creation_with_x264/
REM Interlaced resolution 	 Support SARs
REM 1920x1080i50                  1:1   (16:9 frame)
REM 1440x1080i50                  1:1   (4:3 frame),        4:3 (16:9 frame)
REM 720x576i50              1:1, 16:11 (16:9 frame), 12:11 (4:3 frame)
REM 704x576i50              1:1, 16:11 (16:9 frame), 12:11 (4:3 frame)
REM 480x576i50              1:1, 24:11 (16:9 frame), 18:11 (4:3 frame)
REM 352x576i50              1:1, 32:11 (16:9 frame), 24:11 (4:3 frame)
REM
REM 1920x1080i60                  1:1   (16:9 frame)
REM 1440x1080i60                  1:1   (4:3 frame),        4:3 (16:9 frame)
REM 720x480i60              1:1, 40:33 (16:9 frame), 10:11 (4:3 frame)
REM 704x480i60              1:1, 40:33 (16:9 frame), 10:11 (4:3 frame)
REM 640x480i60                    1:1   (4:3 frame)
REM 480x480i60              1:1, 20:11 (16:9 frame), 15:11 (4:3 frame)
REM 352x480i60              1:1, 80:33 (16:9 frame), 20:11 (4:3 frame)
REM
Old 13th June 2010, 09:42   #1638  |  Link
Audionut
x264.exe --preset slow --tune film --crf 20 --aq-mode 2 -o x:\output.mkv x:\input.avs
http://www.7-zip.org/
Old 13th June 2010, 12:03   #1639  |  Link
Clumpco
Clumpco's Avatar
Thanks Neuron2, nice to know I wasn't imagining things.
And again thanks
Old 13th June 2010, 12:39   #1640  |  Link
I just type an x264 command line in a DOS window as Audionut shows above, although my parameters are a bit different.
