Old 12th November 2009, 15:29   #541  |  Link
The audio is marked in the PMT as scrambled, but obviously it isn't. This puts me in a bind because I added the check to prevent crashing when trying to process a scrambled stream. Tell me about where the TS came from.
Looking at the upscaling issue...
EDIT: OK, I have the upscaling fixed. I'll try to put out a new version tonight with fixes for both issues.
Old 12th November 2009, 20:05   #542  |  Link
opieant
The TS is an extract from a satellite mux in which scrambling was temporarily disabled. You could still check for scrambling via the bits in "transport_scrambling_control" since they're generally going to be more reliable. The info in the PMT only indicates that packets with particular PIDs may be scrambled, not that they necessarily are all of the time.
opieant is offline   Reply With Quote
Old 12th November 2009, 20:10   #543  |  Link
adiabatic
adiabatic's Avatar
I hit a little issue with DG NV tools 2.0.0 beta 2 on this capture sample converting from 1080i MPEG-2 TS to 720p x264. The source is a capture from a Motorola PVR copied to PC with CapDVHS and strangely I didn't have issues with a couple of earlier captures (though those were from a different channel).
When I don't use DG NV tools and deinterlace with tdeint the output is correct.
Script:
MPEG2Source("SpeedNov03b_edit.d2v")
tdeint()
spline36resize(1280,720)
colormatrix()
When I use NV Tools the whole ~45 minute capture comes out 30 seconds slow and then (of course) out of sync with the audio when I mux it back in.
Script:
LoadPlugin("C:\utilities\video\NVBeta11\DGDecodeNV.dll")
DGSource("SpeedNov03b_de.dgm",deinterlace=1)
colormatrix()
I've got Nvidia drivers version 191.07, EVGA GTX275 card, x264 r1222M, Windows 7 RC 32-bit
x264 commands used in MeGUI:
program --profile high --pass 2 --bitrate 3800 --stats ".stats" --level 4.1 --ref 2 --direct auto --subme 5 --trellis 0 --partitions p8x8,b8x8,i4x4,i8x8 --vbv-bufsize 50000 --vbv-maxrate 50000 --thread-input --cqmfile "C:\utilities\video\Matrices\eqm_avc_hr.cfg" --output "output" "input"
adiabatic is offline   Reply With Quote
Old 12th November 2009, 21:11   #544  |  Link
As stated in the DGDecodeNV user manual:
"Also note that setting deinterlace to 1 or 2 forces the field operation to be "Ignore Pulldown", regardless of the project setting."
Your stream has irregular pulldown so treating it with ignore pulldown will kill AV sync.
The correct way would be to use Force Film mode but that is not yet implemented (I'm working on it now). Until then you can:
1. Use Honor Pulldown and then deinterlace with another filter. It's not ideal because most of the stream is progressive.
2. Use Force Film mode in DGIndex.
Old 12th November 2009, 23:18   #545  |  Link
adiabatic
adiabatic's Avatar
Ah, I see. Thanks, Donald. I'm just moving out of the point-and-click realm of video conversion. Lots to learn.
It's a really weird source even when watching on the cable box... it seems to be pieced together from SD and HD cameras with segments where the video just looks odd. The "irregular pulldown", I guess.
How would I determine had irregular pulldown in future captures? Is there a freeware tool or are you just stepping through frame-by-frame.
Old 12th November 2009, 23:31   #546  |  Link
Jeff Flowerday
DTS stream extraction next?
Jeff Flowerday is offline   Reply With Quote
Old 13th November 2009, 00:25   #547  |  Link
Do a preview and if the number of fields repeats is not equal to half the number of coded frames, then it is irregular.
Old 13th November 2009, 00:29   #548  |  Link
You mean in MPEG program streams?
Old 13th November 2009, 06:22   #549  |  Link
turbojet
Is there any chance for an option to demux the AC3 from TrueHD?
Old 13th November 2009, 14:27   #550  |  Link
Possibly, but it will have to wait for some more important stuff to get done.
Old 13th November 2009, 15:33   #551  |  Link
Jeff Flowerday
The DTS audio from anything. VOBs in particular.
Old 14th November 2009, 00:20   #552  |  Link
laserfan
Aging Video Hobbyist
I'm considering a Sony All-in-One PC for a guest bedroom which has an Nvidia GT240M (note: mobile) chipset. I can't find this chipset to be supported with Nvidia's latest 186.81 for Vista/7 64-bit. Instead, there's a download on Sony's site which is listed as 8.15.11.8647. I can't relate this to anything: does anyone here know if 8.15=186.81?
Alternatively, does anyone here have a GT240M and use it successfully w/DGIndexNV?
laserfan is offline   Reply With Quote
Old 14th November 2009, 00:47   #553  |  Link
turbojet
OK thanks.
That's 186.47. 186.81 driver version is 8.16.11.8681. As far as I can remember the last 5 digits match the setup version. Driver version can also be found in the inf files that are extracted.
I haven't used GT240M with DGNV.
Old 14th November 2009, 04:38   #554  |  Link
adiabatic
adiabatic's Avatar
Is it also OK if the number of Field Repeats is 0? To see what you said for myself I opened a source that earlier converted without sync issues but the number of repeats is zero.
Old 14th November 2009, 06:11   #555  |  Link
So there is no soft pulldown at all. Thus there is no pulldown to ignore and thus no possible AV sync issues due to ignoring irregular soft pulldown. The guideline I gave you applies only to streams with soft pulldown (pulldown using flags rather than hard field duplication).
Old 14th November 2009, 15:28   #556  |  Link
laserfan
Many thanks for your input. It appears therefore that Sony's specific driver is behind Nvidia's, which is to be expected of course. I will have to re-think my attraction to the All-in-One concept, as all the designs I've seen use "mobile" and/or proprietary components...
Old 14th November 2009, 20:40   #557  |  Link
Version 2.0.0 beta 3
* Revise detection of scambled audio so that streams that are marked as scrambled in the PMT but which are not actually scrambled are not rejected.
* Fix crashes when upscaling streams with soft pulldown.
* Implement Force Film mode for MPEG2.
MPEG2 pulldown handling is now complete, including frame pulldown. Work is ongoing to complete full pulldown handling for AVC and VC1. Currently AVC can be Honor or Ignore but not Force Film, and VC1 can only be Ignore. Neither AVC nor VC1 yet support frame pulldown.
http://neuron2.net/dgavcdecnv/dgdecnv200b3.zip
Old 15th November 2009, 00:17   #558  |  Link
olex99
Is the force film mode meant to remove the 3:2 pulldown and change the framerate to 23.976? I've just tried it out and when looking at the output it still has the 3:2 pulldown, it also has the same number of frames as the input. From what i can see it has just changed the framerate to 23.976 as the video is now about 10 minutes longer than before.
When comparing to the same option in DGindex 1.5.6 my output is 61171 frames and around 42 minutes where as the NVTools version is 76464 frames and around 53 minutes.
olex99 is offline   Reply With Quote
Old 15th November 2009, 00:32   #559  |  Link
adiabatic
adiabatic's Avatar
I tried Beta3 with the problem capture (irregular pulldown) mentioned above. Used Force Film in DGIndexNV then encoded with
LoadPlugin("<path>\DGDecodeNV.dll")
DGSource("SpeedNov03b_de.dgm",deinterlace=1, resize_w=1280,resize_h=720)
colormatrix()
and my 45:07 29.97 fps source video ended up as a 55:42 23.976 fps file... I think I'm misunderstanding what you said in Post #544.
Old 15th November 2009, 01:52   #560  |  Link
The field operation is applied only when serving through your script. I forgot to mention that.
