#521 | Link |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 12th July 2015 at 08:04. |
#522 | Link |
契約者
Not sure about over twice the performance, but what's the catch here? I thought its a common knowledge that you must disable internal threading in plugins if you use them i'm multithreaded avisynth/vapoursynth. As well as the other way - disable all avisynth threads if you have a gpu-filter in the chain. Even setting source filter threads to 1 sometimes makes slight difference.
#523 | Link | |
After a quick test with nnedi3_rpow2, that's about right. The internal OpenMP implementations in nnedi3 and eedi3 are quite inefficient.
And don't forget that some people strongly dislike reading documentation and searching forums. ![]()
Groucho's Avisynth Stuff |
#525 | Link | |
/人 ◕ ‿‿ ◕ 人\
And it was kinda discussed here http://forum.doom9.org/showthread.ph...18#post1576518 |
#526 | Link | |
ангел смерти
![]() Join Date: Nov 2004
#527 | Link |
There have been a number of updates to nnedi3 by jpsdr but for those of you who want to use the original nnedi3 0.9.4, don't need the additional color spaces and also want to take advantage of the substantial speed increase that TP7's "FTurn" brings for nnedi3_rpow2() I have built a DLL that does just that.
Tritical's 0.9.4 code is unaltered except:
The DLL is built with ICL10. Download here. Some performance tests on my i5 2500K (4 cores): Script: Code:
avsmt_threads = 1 edi_threads = 4 (avsmt_threads > 1) ? setmtmode(2, avsmt_threads) : nop() colorbars(width = 1536, height = 1024, pixel_type = "yv12").killaudio().assumefps(50, 1).trim(0,999) nnedi3_rpow2(rfactor = 2, nsize = 0, nns = 4, qual = 2, threads = edi_threads) Code:
[Runtime info] Frames processed: 1000 (0 - 999) FPS (min | max | average): 11.64 | 13.69 | 13.60 Memory usage (phys | virt): 476 | 488 MB Thread count: 14 CPU usage (average): 77% Time (elapsed): 00:01:13.539 Code:
[Runtime info] Frames processed: 1000 (0 - 999) FPS (min | max | average): 3.231 | 149148 | 16.84 Memory usage (phys | virt): 572 | 626 MB Thread count: 23 CPU usage (average): 97% Time (elapsed): 00:00:59.375 Code:
[Runtime info] Frames processed: 1000 (0 - 999) FPS (min | max | average): 5.305 | 255682 | 17.02 Memory usage (phys | virt): 560 | 600 MB Thread count: 31 CPU usage (average): 96% Time (elapsed): 00:00:58.751 Last edited by Groucho2004; 11th August 2015 at 17:23. |
#528 | Link | |
Apparently Fturn (the actual Fturn, not normal turn function) is built in, but used as normal turn with Avisynth+.
From the Avisynth+ changelog (24th November 2013): Quote:
#529 | Link | ||
[Runtime info] Frames processed: 1000 (0 - 999) FPS (min | max | average): 11.82 | 13.45 | 13.35 Memory usage (phys | virt): 74 | 91 MB Thread count: 25 CPU usage (average): 76% Time (elapsed): 00:01:14.901 Code:
[Runtime info] Frames processed: 1000 (0 - 999) FPS (min | max | average): 11.83 | 13.49 | 13.39 Memory usage (phys | virt): 74 | 91 MB Thread count: 25 CPU usage (average): 75% Time (elapsed): 00:01:14.658 |
#532 | Link |
Soul Architect
I have a question about turnleft/turnright. How does that work? If I'm applying EEDI3 + NNEDI3, should I call it in this order?
EEDI3, turnleft, NNEDI3, turnright and if I'm calling NNEDI3(4), is it automatically calling turnleft/turnright? In that case, NNEDI3(2) + NNEDI3(2) wouldn't give the same output as NNEDI3(4) ? Anything else I should know about this? |
#533 | Link |
TurnLeft/TurnRight rotates the video on its side so that nnedi3/eedi3's height doubling can be used to double the width of the image. If you use the rpow2 functions, they'll handle the turning to double both the width and height in one function call. If you use the base functions with dh=true, you need to call them twice with TurnLeft/TurnRight in between.
For example, the following two lines do basically the same thing, assuming you're using jpsdr's nnedi3. nnedi3_rpow2(2) TurnRight().nnedi3(1, dh=true, nsize=0, nns=3).TurnLeft().nnedi3(1, dh=true, nsize=0, nns=3) Last edited by Desbreko; 2nd September 2015 at 18:58. |
#534 | Link |
After putting it off for a long time, seeing jpsdr make improvements to nnedi3_rpow2 in his builds finally gave me the motivation to write a better rpow2 function that also supports the other edi plugins, so here we go.
edi_rpow2 v1.0 (Also requires ResizeX) It supports jpsdr's nnedi3, nnedi3ocl, eedi3, and eedi2, and includes all the improvements jpsdr made plus more, such as...
#535 | Link |
Soul Architect
I mentioned that NNEDI3's multi-threading was inefficient. I just realized it's weirder than that.
I'm running these scripts with AvsMeter to see how many threads are created. I'm running in MT mode with 8 threads. This creates 16 threads. nnedi3_rpow2(2, cshift="Spline16Resize", threads=1) This creates 32 threads. nnedi3_rpow2(2, cshift="Spline16Resize", threads=2) This creates 128 threads. nnedi3_rpow2(2, cshift="Spline16Resize", threads=1) When running without MT and asking NNEDI3 to use a single thread, it creates 2 more threads. What's going on here? |
#538 | Link |
Might want to say which bolded one you refer to.
#540 | Link |
The image enthusyast
Desbreko, the edi_rpow2 v1.0 looks like fine! it's what I need.
I have seven questions about: 1) The jpsdr nnedi3 that edi_rpow2 v1.0 supports is nnedi3 v0.9.4.20, with all original parameters (Update maden in 5th September)? 2) Does eedi3, nnedi3ocl and eedi3, in your plug-in, have the same improvements that jpsdr made in nnedi3? More your improvements, course! 3) Your plug-in works only with nnedi3_rpow2, nnedi3ocl_rpow2, eedi3_rpow2 and eedi2_rpow2 functions, with all original parameters, or works with nnedi3, nnedi3ocl, eedi3 and eedi2 functions too, with all original parameters? 4) If works with nnedi3, nnedi3ocl, eedi3 and eedi2 too, this functions has the jpsdr's improvements and, of course, the yours? 5) There's no chroma and luma shift neither any type of chroma and luma flaws in your plug-in, in all functions and parameters it supports. Am I right? 6) Any future quality improvements plans? 7) You correct only AviSynth internal resizers chroma shift or correct chroma shift of some other resize, such Spline 144, Jinc,... (If yes, please, upload your corrected Avisynth external resizers)? Please, answer all my questions.
Searching for great solutions Last edited by luquinhas0021; 7th October 2015 at 16:09. |
