Old 25th June 2010, 14:25   #221  |  Link
markanini
what can one expect when running nnediX in eediX compared to pure nnediX? Would results be in-between nnedi and eedi?
markanini is offline   Reply With Quote
Old 25th June 2010, 16:41   #222  |  Link
Great Dragon
Great Dragon's Avatar
Now I can do fine deinterlacing using supersampling with TGMC (in reasonable time ),
It is slow as hell. It takes 2 mins to process one frame on my Q6600 with all 4 cores loaded for 100%.
But if you hold your breath and wait till it finished you'll be happily surprised about quality.
Default TGMC
EEDI3_SS with nnedi2
Great Dragon is offline   Reply With Quote
Old 25th June 2010, 17:50   #223  |  Link
Didée
2 minutes per frame? Cool. That makes a processing time of only 83 days for one 40-minutes PAL clip.
___
Since that's Anime, it can be assumed the input is not of the category "video"-interlaced. And when it is not, then the number of different motion states (on the field-separated level) is not equal in forward and backward direction. As a consequence of this unsymmetry, the internal motion search of TGMC is not working optimally. (Due to the temporally-symmetric preprocessing.)
TGMC is intended for video-type interlaced sources, and nothing else. In most cases the internal safeguarding is good enough to avoid "obvious" errors when feeding sources with other types of interlacing. But you can't expect an optimal result when using a tool for something it wasn't designed for.
Old 26th June 2010, 05:10   #224  |  Link
Bi11
Architect
Bi11's Avatar
Originally Posted by Gavino View Post
Spline64Resize is also present in Avisynth 2.58, but not in 2.57 or the MT version derived from it.
I am using Avisynth 2.5.8 MT. So I guess it already has Spline64Resize built-in.
Yes, it is impractically slow. Using avs2avi clip.avs -o n, on a Core i5 750 @3.4GHz, with a 720x540 clip gives 0.13fps with setMTmode(2). Using eedi3_ss outside of TGMC gives 0.3fps, again with setMTmode(2).
Have you tried doing only one call to eedi3, like so:
 \   : (EdiMode=="eedi3")  ? clp.eedi3(field=-2, sclip=clp.nnedi3(field=-2))
It is much faster (10x as fast @1.3fps) and looks close to eedi3_ss, but without connecting "micro" jagged edges.
Scaling that rate, on an overclocked Core i7 860 w/ HT, processing a 40-minute PAL clip with EdiMode="eedi3" in TGMC would take 6.4 hours.
I think it should be possible to get the same effect as eedi3_ss without the supersampling, with only two consecutive calls to eedi3, or maybe first call to nnedi3 then second call to eedi3. The second call would configure eedi3 to be more aggressive at connecting very short lines.
I'll have to keep experimenting...
Update:
After some experimenting, it seems eedi3_rpow2 is entirely responsible for anti-aliasing jagged edged. So nnedi3 could be used for deinterlacing, which would give less artifacts than eedi3, and still look nearly identical to eedi3_ss, like so
 \   : (EdiMode=="nnedi3+eedi3_ss") ? clp.nnedi3(field=-2,nsize=nsize,nns=nns,qual=qual).eedi3_rpow2(rfactor=2,cshift="spline64resize",fwidth=clp.width,fheight=clp.height)
Runs @0.25fps.
Bi11 is offline   Reply With Quote
Old 26th June 2010, 07:20   #225  |  Link
Terka
on DV content is nnedi2 better, so i suppose also on all dvd/blueray also.
for anime you say there nnedi3 wins. anime has a lot of flat areas.
maybee nnedi3 could be optimised - for flat areas use some speedy algoritm, for details current nnedi3. is something like this possible, Tritical?
Terka is offline   Reply With Quote
Old 26th June 2010, 07:39   #226  |  Link
Didée
This feature is already implemented, and used by default. Dive into the readme, and see the "pscrn" parameter.
Old 26th June 2010, 07:53   #227  |  Link
Great Dragon
Thanks to your script example I did and I have to say it's MUCH faster and still do the job well. Actually now it's practically useful.
This is still frame in the end of scene where default TGMC fails.
There is no such big difference in visual quality on "normal" frames but with EEDI3+NNEDI3 these looks a little more cleaner/sharper.
TGMC default
EEDI3+NNEDI3 one call
Old 29th June 2010, 12:35   #228  |  Link
D3C0D3R
2 Tritical
can you implement this useful thing for much faster EEDI2 or add speedy option to EEDi3 (ex. using networks of smaller sizes)?
blendhater
D3C0D3R is offline   Reply With Quote
Old 29th June 2010, 14:29   #229  |  Link
WorBry
The last frame is always a dud. Obviously, one way to avoid it is to pad the end of the source clip with a few extra frames and excise afterwards.
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 30th June 2010, 15:06   #230  |  Link
tritical
eedi2 already does this, but not using a neural network (it builds an edge mask). I could replace eedi2's edge mask building with nnedi2/nnedi3's prescreener, but I don't really want to work on on eedi2 anymore. Prescreening for eedi3 isn't as useful since it must process entire lines. How each pixel is interpolated is dependent on how every other pixel in the line contributes to the cost function. I could run the prescreener and not process any lines where it detects all pixels can use cubic, but I don't think it will save any significant time. If you want eedi3 to be faster there are really four settings to change from the defaults: mdis/nrad/cost3/ucubic. (ucubic=false,cost3=false,nrad=1,mdis=10) is 4-5x faster than the defaults, but of course the result isn't quite as good (and with mdis=10 lines of very small slope: < 1/10 wont be connected). As for smaller networks, neither eedi2/eedi3 use neural networks so there are none to make smaller. Once I get nsizes 16x4 and 32x4 added to nnedi3 I'm going to work on improving the speed/accuracy of the prescreener. I haven't touched the prescreener since the original nnedi.
The temporal version of nnedi3 is on hold for now.
tritical is offline   Reply With Quote
Old 1st July 2010, 11:16   #231  |  Link
Great Dragon
If there are many scenes with such bad frames in a source clip it's a real pain.
Old 1st July 2010, 18:11   #232  |  Link
WorBry
The 'dud frame' will (should) only occur once at the end of a processed clip, not at (internal) scene changes. Of course, if you are processing each scene separately, it becomes more tedious, but so is splitting and splicing anyway.
Old 2nd July 2010, 01:00   #233  |  Link
plonk420
amd & h.264 fanboy
plonk420's Avatar
all i can say is that eedi3+nnedi2 is AMAZING! :O
plonk420 is offline   Reply With Quote
Old 9th July 2010, 04:01   #234  |  Link
hartford
hartford's Avatar
eedi3 misbehaving
I got an error when trying to load EEDI3 with Avisynth v2.5.7:
The instruction at "0x012198f4" referenced memory at "0x011c3ca8". The memory could not be "read".
So, I updated to Avisynth 2.5.8 and got a simple error:
"LoadPlugin: unable to load "c:\program files\avsplugins\eedi3.dll"
(c:\..\blah.avs, line blah")
I have checked paths and syntax several times.
Script:
loadplugin("c:\program files\avsplugins\nnedi2.dll")
loadplugin("c:\program files\avsplugins\eedi3.dll") # the path is correct
avisource("blah.avi") # the avs file resides in the same directory as the avi
eedi3(sclip=nnedi2())
Any idea about what is causing the error?
Other stuff:
Windows XP sp2
eedi3 v0.9 for Avisynth 2.5x; file version 0.9.0.0; 24Jun10
nnedi2 v1.5 for Avisynth 2.5x; 16May2010
hartford is offline   Reply With Quote
Old 9th July 2010, 05:32   #235  |  Link
tritical
I didn't mention it, but since the last version uses openmp, and I compiled it with vs2005, you will need to have the visual studio 2005 redistributable installed (for vcomp.dll).
If you already have the redistributable then I'm not sure.
Old 10th July 2010, 04:05   #236  |  Link
hartford
hartford's Avatar
I did a search on my harddrive for vcomp.dll and did not find it.
I installed visual studio 2005 redistributable. I did a search for vcomp.dll
and found it in this directory:
c:\windows\x86_Microsoft.VC80.OpenMP_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0ee63867
but I got the same error (LoadPlugin: unable to load "c:\program files\avsplugins\eedi3.dll").
Yes, I did reboot after installing the redistributable from MicroSoft.
Odd thing was that I didn't find it when I did a search of "c:\" but I did find it when I did
a search of "c:\Windows"
I don't know what that means except that paths were not established.
I'm open for suggestions.
I copied the dll to the system32 directory but no joy.
*edit for missing a copy-paste character*
Old 10th July 2010, 04:32   #237  |  Link
Bi11
Architect
Bi11's Avatar
Remove the loadplugin() calls and place eedi3.dll in Avisynth 2.5/plugins folder.
If that doesn't work then:
Do a clean uninstall of AviSynth and clear the plugins directory. Reboot.
Do a default install of SEt's AviSynth MT 2.5.8.
Copy eedi3.dll to the default AviSynth 2.5\plugins directory.
Run the script below (without the loadplugin()) to see if it works :
BlankClip(pixel_type="YV12")
eedi3()
Old 11th July 2010, 03:57   #238  |  Link
hartford
hartford's Avatar
@Bi11
<i>Remove the loadplugin() calls and place eedi3.dll in Avisynth 2.5/plugins folder.</i>
That did not work.
<i>If that doesn't work then:
Copy eedi3.dll to the default AviSynth 2.5\plugins directory.</i>
Doesn't work. I get an "Import error."
After putting the AviSynth MT dll in the system32 directory I tried to
register it without success. I get the error:
LoadLibrary("C:\WINDOWS\system32\avisynth.dll") failed - the specified module could not be found.
I'm totally perplexed. I've installed previous versions of avisynth MT with no problem.
I've tried EEDI2 just to see what it could do and had no problem.
So now I have EEDI3 and Avisynth MT not working.
Problems are compounding, but thanks for the suggestions.
Old 11th July 2010, 04:00   #239  |  Link
hartford
hartford's Avatar
That did not work.
Old 13th July 2010, 11:35   #240  |  Link
Gavino
Avisynth language lover
nnedi2/3 incorrectly handling RGB24
nnedi3 does not interpret the field parameter correctly when the input is RGB24.
With this script:
b = BlankClip(height=240, pixel_type="RGB24")
w = BlankClip(b, color=color_white)
Interleave(b, w)
AssumeFieldBased().AssumeTFF()
Weave()
nnedi3(field=0) # same rate, keep bottom field
the result should be all-white (bottom field), but in fact an all-black frame is produced.
If pixel_type is changed to "YUY2", a white frame is correctly obtained.
Similar problems occur when dh=true.
I suspect that the implementation does not allow for Avisynth storing RGB frames 'upside-down', so interprets top fields as bottom and vice-versa.
Edit: The same behaviour is also present in nnedi2.
