Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 29th May 2009, 15:51   #21  |  Link
jdobbs
Originally Posted by dgwak View Post
[02:32:26] PHASE ONE, Encoding
- [02:32:26] Extracting audio/subs [VID_00001]
- [02:40:06] Reencoding: VID_00001 (1 of 2)
- [09:36:08] Extracting audio/subs [VID_00002]
- Audio/PGS sizing issue. Continued...
- [09:42:20] Reencoding: VID_00002 (2 of 2)
- [09:42:24] DoEncoding() 00009 8
I really want to keep this at BD-9 instead of BD-25.
One more note. If you are posting the LOG, please use the LOG from the most recent version. The error reporting has changed completely and the error shown in this log is now meaningless. Thanks.
Website: www.jdobbs.net
Old 29th May 2009, 19:48   #22  |  Link
dgwak
After the second pass? That message comes at the beginning of an encode (before the first pass). That means that you must be getting the message on the second stream (VID_00002).
That error is confusing... is that exactly what it said? I don't think I have any error messages like that.
Indeed, there is a second stream that I didn't notice. But why? I only chose movie only for BD9 backup. How do I get rid of it?
dgwak is offline   Reply With Quote
Old 29th May 2009, 21:18   #23  |  Link
kaiman
The same error, with the new version, I,robot and ice age 1 always get the same result
[10:21:58] BD Rebuilder v0.21.01 (beta)
- Source: IROBOT_US
- Input BD size: 26.45 GB
- Approximate total content: [01:54:44.252]
- Target BD size: 4.27 GB
- MOVIE-ONLY mode enabled
[10:21:58] PHASE ONE, Encoding
- [10:21:58] Extracting audio/subs [VID_00001]
- [10:26:40] Reencoding: VID_00001 (1 of 2)
- [15:09:52] Extracting audio/subs [VID_00002]
- [15:11:46] Reencoding: VID_00002 (2 of 2)
- [15:11:48] DoEncoding() 00009 2008
[Status]
LABEL=IROBOT_US
VERSION=v0.21.01 (beta)
SOURCE_SIZE=28400295936
SOURCE_VIDEO_SIZE=28400295936
TARGET_SIZE=4581228544
REDUCTION=.161309183338223
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;spa;
BACKUP_MODE=1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
[00001]
AUDIO=100000
PGS=1100000
M2TS_TARGET=4581223589
RATE=4369
NSIZE=3971868672
FLINK=0
MLINK=0
[00002]
M2TS_TARGET=4955
kaiman is offline   Reply With Quote
Old 29th May 2009, 21:57   #24  |  Link
dgwak
[00002]
M2TS_TARGET=4955
Yep, you have the same problem. It somehow tries to work on [0002] stream after the main movie finishes.
Any solutions to this?
Old 30th May 2009, 04:55   #25  |  Link
jdobbs
You don't. It's actually part of the main-movie MPLS. I'll go out and find I-Robot and see if I can repeat the issue.
What VC-1 decoder are you using?
Old 30th May 2009, 17:39   #26  |  Link
dgwak
I am a noob at this HD decoding. I think what I have ffdshow. I do have WMP10 installed so it should have VC-1 capability. I just installed what was recommended which was ffdshow and Haali splitter along with BD-Rebuilder program... How do I tell?
Old 30th May 2009, 23:14   #27  |  Link
jdobbs
I would recommend installing Windows Media Player 11 (its free). Then go into FFDSHOW and disable VC-1. That way the WMP11 codec will be used. It is the most compatible VC-1 codec right now.
Old 30th May 2009, 23:32   #28  |  Link
kaiman
I'm using windows media 11, i believe that's not the problem
Old 31st May 2009, 13:56   #29  |  Link
dgwak
Yes in fact me too. I have been using WMP11 and VC-1 disabled in ffdshow codec option menu.
Would this problem be solved if I choose a different audio stream (ac3 instead of DTS)?
Old 31st May 2009, 17:26   #30  |  Link
jdobbs
I finally repeated it. It was a really weird issue in which the short (1 sec.) follow-on stream had no audio even though the MPLS indicated it should. When I first tested it I had "don't reencode DTS" set -- and it went through fine, duh...
I fixed it for the next release (v0.21.02). I'm doing some testing, but you should see it posted today.
Old 1st June 2009, 03:07   #31  |  Link
dgwak
I just used the posted newer version to make BD9 of I, Robot. It got stuck for a hour at this place.
Here is my work files when I aborted.
Old 1st June 2009, 03:08   #32  |  Link
dgwak
I just used the posted newer version to make BD9 of I, Robot. However, it got stuck for a hour at this place.
Here are my work files when I aborted.
Old 1st June 2009, 06:16   #33  |  Link
jdobbs
Something has to be wrong on your end either in your system or in your rip -- I did the exact same movie/region earlier today with no issues.
Just to be sure, I just started the encode again -- we'll see if it is complete in the morning.
Old 1st June 2009, 07:07   #34  |  Link
kaiman
The new version works fine with me, i chose one language 2 subtitles, movie only bd5, im gonna try it with ice age, that always got me that message
Old 1st June 2009, 13:58   #35  |  Link
jdobbs
Well I got up this morning and it is completed correctly. Sorry.
Old 1st June 2009, 18:46   #36  |  Link
kaiman
I tested the new version with ice age, and it worked fine, finally i backup i robot and ice age 1.
The only title that i still have problems is Vicky Cristina Barcelona because of its 3.0 audio
Old 2nd June 2009, 15:39   #37  |  Link
jdobbs
Interesting. How does BD-RB report that track on the STREAMS list?
Old 2nd June 2009, 21:20   #38  |  Link
kaiman
This is how it looks.
The problem is that it only mixes the left and right channel, so the results its a movie with only ambient sound and no dialogue.
This is a thread with options to resolve that problem, i don't know if there is a hidden option that a i can put in bdrebuilder
http://forum.doom9.org/showthread.ph...ight=barcelona
Old 2nd June 2009, 22:23   #39  |  Link
jdobbs
I should be able to fix it easy enough with AVISYNTH commands.
