Old 22nd July 2009, 23:28   #1441  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I didn't state that Coreavc has a limitation, just that Cuda does.
Obviously that isn't the issue and was just a guess, as I know the format of the video should play no part in whether an image is displayed by the renderer.
Regardless of the assumption, my first statement is correct.
No, the statement is not correct. CUDA itself doesn't have any such limitations! In fact CUDA kernels can access the complete device memory (1024 MB or even more on modern graphics cards), which is more than enough to store 16 reference frames in 1080p resolution. However most (all?) applications that pretend to use "CUDA" accelerated decoding actually do not implement their own H.264 decoder in CUDA. Instead they simply access the graphic card's "built-in" H.264 decoder through the CUDA interface. And that decoder isn't related to CUDA computing at all! It's a completely separate chip (e.g. VP2) on the graphics board. And since the decoder on that chip is "hardwired", there are inherent limitations, such as a limited MaxDPB size (which limits the number of ref frames that can be supported).
Old 23rd July 2009, 07:28   #1442  |  Link
ryrynz
ryrynz's Avatar
That's interesting to know thanks for the info, perhaps I should have been clearer but my first statement was "That would be due to your decoder"
which as you said was not either outputting mod16 or YV12 and is obviously the cause.
Old 24th July 2009, 11:44   #1443  |  Link
Thunderbolt8
theres a problem with madVR not displaying 4:3 (mpeg2, 1080i, .ts & mpc-hc) movies correctly (at least on my 5:4 screen). black bars get eliminated and the image is therefore stretched vertically to fill the area where the black bars used to be at top and bottom, resulting in a wrong AR. everything's too slim. occurs in both, window mode and fullscreen.
Thunderbolt8 is online now   Reply With Quote
Old 24th July 2009, 11:48   #1444  |  Link
Anima123
There's a bug madVR with mplayerc-hc that bother me. When pause a file, then full-screen the playback, then play, the player will get nothing but black. mplayerc-hc has to be killed by task manager to restart.
Anima123 is offline   Reply With Quote
Old 24th July 2009, 15:38   #1445  |  Link
Matthias Hutter
Hi @all,
@Anima123:
I've done some testing: Actually, if playback is paused and restarted with another setting (time, resolution) the player hangs up and needs to be killed via the taskmanager - at least on my PC.
Another bug is that luma upres is resetted to bicubic 50 every time. But I think others already mentioned that.
Besides that I noticed that image parts with strong color saturation get blacked out with the default Bradford color transform on my wide gammut monitor.
/Edit: Output-Primaries[x,y]: 0.667 0.333 0.159 0.704 0.150 0.051 0.333 0.347
Regards, Matt
Matthias Hutter is offline   Reply With Quote
Old 24th July 2009, 17:37   #1446  |  Link
yesgrey
There is no defaults in cr3dlut, so, please let me know what have you used. Can you also post an image of what's happenning?
Old 24th July 2009, 20:02   #1447  |  Link
Thunderbolt8
I haven't checkmarked the 3dlut option, is this what you mean?
can make screenshot tomorrow evening.
Old 25th July 2009, 01:40   #1448  |  Link
yesgrey
If you haven't checkmarked the 3dlut option, then you're not using the 3dlut...
The problem should come from other thing...
Please post also the cr3dlut version that you are using.
Old 25th July 2009, 16:00   #1449  |  Link
Thunderbolt8
here they are:
mpc & madvr window
mpc & madvr fullscreen
VLC
how can I find that out, which of the files do I have to check how?
Old 25th July 2009, 16:25   #1450  |  Link
73ChargerFan
73ChargerFan's Avatar
I hope madshi has time to read this thread occasionally, to log these bug reports.
Have you switched to a different render, like overlay?
Or MPC could be at fault for the squeezing of your video. When mpc-hc does something really bad like this, I delete the registry key (instructions at mpc-hc wiki) to reset the software.
Also, for immediate enjoyment, you can widen the aspect ratio using mpc-hc command "num pad 6".
73ChargerFan is offline   Reply With Quote
Old 25th July 2009, 16:25   #1451  |  Link
73ChargerFan
ot - btw, do you like the new vlc?
Old 25th July 2009, 18:55   #1452  |  Link
Thunderbolt8
hm, it looks the same with overlay, but its fine with haali and evr.
dunno, I never really use it to watch anything.
Old 26th July 2009, 01:14   #1453  |  Link
yesgrey
Thunderbolt8, are you Matthias Hutter? My request was for him. I don't see the saturation problem in your pics, can you point it?
Old 26th July 2009, 09:24   #1454  |  Link
Thunderbolt8
whoever matthias hutter may be, its not me
I don't know about any saturation problem as well, only about the wrong AR I can see in those screenshots
Old 26th July 2009, 11:28   #1455  |  Link
yesgrey
So, just forget my replys about cr3dlut, I was replying to Matthias Hutter.
About your AR problems, sorry, but I can't help you...
Old 27th July 2009, 13:39   #1456  |  Link
Matthias Hutter
If I don't specify Chromatic_Adaptation or set Chromatic_Adaptation 2 (Readme says "Use Bradford Transform"), then the colour problems occur.
With the third option (Kries model), the problem doesn't exists, but there is quite much banding. The problematic 3dlut parameters are as follows:
Input_Bit_Depth          8
Input_Video_Format       HD   YCbCr
Output_Bit_Depth         16
Output_Video_Format      HD   RGB_PC
Output_Primaries         9 0.667 0.333 0.159 0.704 0.150 0.051 0.333 0.3470.333 0.347
Sample image:
(such extreme examples are rare)
If you want to reproduce it, try colors.ytp (madTestPatternSource):
If its just me, I would still be happy if you could tell me how to fix it
Old 28th July 2009, 00:53   #1457  |  Link
yesgrey
Matthias,
You forgot to tell me which cr3dlut version you are using. The v2.1 had a problem similar to this that was fixed in v2.2.
Can you please verify it?
Old 28th July 2009, 10:40   #1458  |  Link
Matthias Hutter
@yesgrey3 Yeah, I was using 2.1 - didn't know there was a newer version, i just used the one shipped with madVR 0.10
The Problem seems fixed now - I need further testing though.
Regards, Matthias
Old 28th July 2009, 12:51   #1459  |  Link
yesgrey
Yes, madshi has been out for a while. I've released v2.2 just to fix that problem (someone else has also reported it), but since it was after madVR 0.10, it does not contain it. People who uses cr3dlut should get v2.2 instead of using the version shipped with madVR 0.10.
Old 28th July 2009, 14:01   #1460  |  Link
Matthias Hutter
Yeah, your right. A new bug-fixing madVR release would also be very nice.
Thanks!
