17th August 2017, 18:29 | #44702 | Link |
Huh. MPC-HC blows up on the start of a movie file on my PC too. I reset madvr and MPC-HC (installed 1.7.13, reset settings and reconfigured to use madvr), but it doesn't help.
I'm using Win10 15063 and a Nvidia 770GTX (driver 385.12) |
17th August 2017, 18:31 | #44703 | Link |
Have a crash also win10 Nvidia 940M , tried dxva2 copy-back&&cuvid , tried running on intel graphics 520 , crashes on start. Once I point the mouse on the movie frame to double click to go to full screen, it crashes.
It crashes right away when the mouse is on the frame of the video before I clicking anything Last edited by kostik; 17th August 2017 at 18:34. |
17th August 2017, 18:38 | #44708 | Link |
No freeze report.
It's a bit weird. With 1.7.13 stable: "actual" crash with some Windows message. With 1.7.13.89: the error message (see screenshot) appears but playback works normally in background. Once you click "ok" player closes. |
17th August 2017, 18:38 | #44709 | Link |
madVR v0.92.0 crashes MPC-BE when opening any video file.
I tried to reinstall it completely (uninstall, remove all files and then install again), but it does not help. Even after restoring default settings with the .bat afterwards. |
17th August 2017, 18:42 | #44711 | Link |
madshi
Thanks for the new version, but I'm getting a crash of MPC-BE x64 on Windows 7 and 8.1. For Win7:
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
17th August 2017, 18:44 | #44713 | Link | |
Faulting application name: mpc-be64.exe, version: 1.5.1.2822, time stamp: 0x599510c4 Faulting module name: madVR64.ax, version: 0.92.0.0, time stamp: 0x5995c42e Exception code: 0xc0000005 Fault offset: 0x00000000000101ce Faulting process id: 0x3ce4 Faulting application start time: 0x01d3177ffe9d4fb0 Faulting application path: C:\Program Files\MPC-BE x64\mpc-be64.exe Faulting module path: C:\Madvr\madVR64.ax Report Id: d068031a-12ce-4701-8148-13ded3606cfd Faulting package full name: Faulting package-relative application ID: MPC-HC Debug: Stack: madvr64+0x101ce madvr64+0x12674 madvr64+0x54244 mpc_hc64+0xb2c0d mpc_hc64+0xb305e mpc_hc64+0x5b3794 mpc_hc64+0x5b571a mpc_hc64+0x5ae93d mpc_hc64+0x5af434 user32!UserCallWinProcCheckWow+0x292 user32!DispatchMessageWorker+0x19f mpc_hc64+0x5caea2 mpc_hc64+0x5cb7ff mpc_hc64+0x7c4a5e mpc_hc64+0x76ab63 kernel32!BaseThreadInitThunk+0x14 ntdll!RtlUserThreadStart+0x21 Last edited by kostik; 17th August 2017 at 18:49. |
17th August 2017, 18:55 | #44714 | Link |
madVR v0.92.1 released
http://madshi.net/madVR.zip Code:
* fixed: depending on madVR settings, v0.92.0 crashed right at initialization * fixed: "display modes" were listed twice in the settings dialog (Note to devs: I know some of you are waiting for me to add dev features for you. Will do that soon now, just wanted to get v0.92.x out the door, first.) |
17th August 2017, 19:00 | #44715 | Link | |
17th August 2017, 19:24 | #44717 | Link | |
What madVR filters do you recommend? thank you |
17th August 2017, 19:29 | #44718 | Link |
D3D11 hardware decoding is not compatible with Windows 7 yet because it uses some features that are only available in 8.1+. It will fall back to software decoding. Nevcairiel has said that he will attempt to make it work on 7 later.
The black screen with latest madvr is a bug in lav/madvr. |
17th August 2017, 19:47 | #44719 | Link | |
In order to get the best possible quality, you may have to use different settings for different situations. E.g. 576i50 -> 1080p50 is quite demanding because the GPU has to render 50 frames per second. 720p24 -> 1080p24 is *much* easier. So for 720p24 upscaling you can use higher quality scaling algorithms. You can use profiles to setup different algorithms for different situations/video files. Well, we've intentionally not blocked anything, just in case we get lucky and it works in Windows 7. I highly doubt it will work. If we find out that it won't work, then we'll simply block the feature in Windows 7 to fix the black screen. |
17th August 2017, 19:48 | #44720 | Link | |
I completely missed that, of course that solves the issue, thanks
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
