#28622 | Link | |
MPC-HC Developer
#28625 | Link |
by using an avisynth script or editor like AvsPmod you are losing chapter, subtitle switching, audio language switching and other stuff avisynth can't really handle or at least not with a simple change like pressing s to change the subtitle. on top of it if you want to change a small thin you have to restart the hole video or you can't use madVR.
i personally don't use stuff like this. i use avisynth for encoding. but i totally understand why people want to use it in realtime to alter there videos. |
#28626 | Link | |
![]() Could you please create a debug log with v0.87.17. And also one with an older version where everything still worked? Last edited by madshi; 1st April 2015 at 22:40. |
#28627 | Link | ||
MPC-HC Developer
#28628 | Link | |
it is like using shader in mpc-hc. at least that is what people want to do with it. |
#28629 | Link | |
http://s000.tinyupload.com/?file_id=...40585588491897 Last edited by Tom Keller; 2nd April 2015 at 00:25. |
#28631 | Link |
Strange issue when using MadVR With DSplayer
Since Madshi announced the integration of MadVR with Kodi via DSplayer (yess!!!) I started to play with it. Unfortunately I found an issue that seems odd to me:
Issue: Some MKV videos have very dark pictures (wrong, missing colors) when I play them in Kodi using MadVR in either full screen exclusive or full screen overlay. As soon as I press CTRL+Enter to get out of Full screen mode, the picture corrects itself. but if I press CTRL+Enter again, the same problem comes back. I tested DSPlayer with EVR, MPC-HC with same MadVR / LavFilters and MediaBrowser Theater with LAV & MadVR but I couldn't repro this bug in any of the other environments. So I assume it's something to do with DSPlayer and MadVR integration. Here are screenshots: https://www.dropbox.com/sh/pxhs1fgk4...zWaICkxsa?dl=0 My GPU is a NVidia GTX 760 running the latest NVidia drivers. Any clue of what may be causing this ? |
#28634 | Link |
10-bit H.264 will always use software decoding, no hardware supports 10-bit H.264 (only HEVC). This isn't related to madVR.
madVR options explained |
#28636 | Link |
I'd like to report a bug.
I'm not sure which program is at fault here but if you are playing a video with mpc-hc and then close it when you have amd gaming evolved (raptr) running then mpc-hc will get stuck running in the background and it will eat up one of your cpu cores until you close it via task manager. If I do not use madvr this does not occur. Also if I close raptr while mpc-hc is stuck in the background I will then get a message that mpc-hc has stopped working and it will close. If I don't have raptr running then everything is fine. I'm going to guess its raptr having the problem as I've tried madvr 87.14 and I still get the problem there. |
#28637 | Link | |
Anime Otaku
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
#28638 | Link |
madshi got a big request for madvr , its been bugging me ever since the support for OSD elements by madvr and am suprised this issue hasnt been tackled earlier , so ive noticed madvr has always had issues with rendering OSD elements smoothly aka theres a noticeable delay between OSD elements this has been both noticed on potplayer and kodis latest dsplayer madvr build this can be easily reproduced by simply up and downing the volume in potplayer or kodi or backing into the kodi home navigation screen while a video is being rendered , mind you ive tried already by putting prerendered frames to 1 and deselecting wait for renderqueue is full for window and exclusive as well did i try it with cranked down upscaling ,yet as said all to no avail , id appreciate a fix alot
#28640 | Link | |
I think this is a player issue not a madVR issue.
