#1 | Link |
HDConvertToX author
HDConvertToX v.2.2.492.3692 (XviD/DivX/X264/WMV/SAP/NMT)
welcome to my lastest application: HDConvertToX
HDConvertToX (HDC in short) is a gui aimed for converting video files (vob/mkv/avi/m2ts/ts...) with XviD or DivX or X264 or WMV codec, and muxed in AVI/MKV/MP4/WMV/M2TS container. Is also supported muxing in AVCHD and BluRay structure it also offer a wide range of audio and subtitle management here some screenshot ![]() ![]() ![]() ![]() ![]() ![]() Full Download (please download also the updates) -> http://www.64k.it/andres/data/hdconv...2.492.3692.rar Full Donwload MIRROR (please download also the updates) http://www.mirror.adubvideo.net/HDCo...2.492.3692.rar , Thanks to Merlin7777 Update -> http://www.64k.it/andres/data/hdconv...ConvertToX.exe Update MIRROR http://www.mirror.adubvideo.net/HDConvertToX.exe , Thanks to Merlin7777 Manual http://www.64k.it/andres/data/hdconv...onvertToX.html How to convert Blurays with HDConvertToX http://www.adubvideo.net/how-to/how-...h-hdconverttox , a great guide by Adub! Required Software ffdshow tryout - > http://sourceforge.net/projects/ffds...d.exe/download haali media splitter -> http://haali.cs.msu.ru/mkv/MatroskaSplitter.exe AviSynth -> http://downloads.sourceforge.net/avi..._mirror=heanet XviD -> http://www.koepi.info/Xvid-1.2.1-04122008.exe also make sure you allow Haali Media Splitter to handle Mpeg/PS file during installation (you can always reinstall Haali Media Splitter) and, in FFDShow, allow mpeg2 AND DVD Support as decoding Note for Windows Vista/Windows7 Users make sure you check compatibility mode for AVIMux-Gui. Right click on AVIMux-Gui in \applications and on compatibility mode set it to Windows Xp SP2 Note for Windows 7 Users check this thread -> http://forum.doom9.org/showthread.php?t=146910 Guide for installing HDConvertToX on Windows7 by rickatnight11 -> http://forum.doom9.org/showthread.ph...34#post1318934 For decoding M2TS with VC-1 codec on ffdshow set VC-1 decoding to WMV9 For AviSynth MultiThread (MT) check this thread ->http://forum.doom9.org/showthread.php?t=144852 For Neuron2 DG NVTools HDC fully support great NVTools by Neuron2. NVtools allow GPU decoding of streams (and not only). Please check Neuron2 site -> http://neuron2.net/ Also please NVTools on Doom9 -> http://forum.doom9.org/showthread.php?t=141104 and for latest beta -> http://forum.doom9.org/showthread.php?t=147945 WMV Encoding If you wish to encode in Windows Media formats you will need several software additions. * The Windows Media Encoder 9 Series, which can be downloaded here. * Windows Media Player 11, which you can download here for WinXP. * If you are unable to install Windows Media Player 11, you can install the WMFdist11, which includes all the needed files. There is a mirror here. * Vista User: must disable DEP. Look here. For 5.1 Audio look here. You can use FFDShow or AC3Filter It is recommended you install wmvencoder (series 9) before you install Windows Media Player 11. BHH Last edited by buzzqw; 11th October 2009 at 18:46. Reason: update |
#2 | Link |
How come x264 is not in the list of available codecs? There is also no NeroAAC support.
Oh BTW, does this GUI support MT avisynth? There is no way to just encode one file like in AutoMKV (like you must press add to quene and press start quene)? Also, what's the deal with the changelog (v3.13)? Buzzqw, just one question. Why the sudden change? AutoMKV was a fantastic piece of software that you've supported for years. Why start all over again, and fix the numerous bugs that are typical in an early stage of a software? If it is the need of a changable x264 settings menu, it could have just been an extra "advanced x264 settings" tab in AutoMKV. Last edited by Chengbin; 11th March 2009 at 03:14. |
#3 | Link |
Fighting spam with a fish
That does seem to be a bug, as he included x264.exe in the applications folder.
Another is that .avi doesn't seem to be on the accepted files list. And it muxes my avi to mkv as soon as I select it! Is this the desired behavior?
FAQs:Bond's AVC/H.264 FAQ,Bond's MPEG-4 ASP FAQ Sites:Adubvideo,MeGUIWiki,MeGUI Ipod Conversion Guide |
#4 | Link | ||||
HDConvertToX author
2) hit "Analyze file" 3) set target size/codecs 4) hit start don't understud your problem Quote:
BHH |
#11 | Link |
Stupid should Hurt!!!
Awesome. When I have it I will donate...
~DarC
My Installer's || |
#12 | Link |
Life looks better in HDTV
Nice one Buzz
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#13 | Link |
HDConvertToX author
Thanks
![]() Got more experience on programming and encoding.. so i hope to build better programs any feedback is appreciated BHH P.S. any interest of asking for external subs when input is avs/d2v/dga ? P.S.S for MT support i need an example of script for studing. Would be a lot better if based on avisynth script already build by hdencodertoX |
#14 | Link | |
http://forum.doom9.org/showthread.php?t=145519 |
#15 | Link |
HDConvertToX author
i can do this:
if mt.dll is present in system folder i will add to script Setmemorymax(512) # or more ??? SetMTMode(2, 0) # 2 or 0 ??? it's ok ? EDIT : MT support added (as explained before) also added the possibility to personalize the encoding profiles. Now is missing only IFO/SUBS support for replacing automkv BHH Last edited by buzzqw; 13th March 2009 at 10:08. |
#16 | Link |
Can you add a final size option?
For example, some user want to reencode some MKV to MKV. He will load the MKV, (set the resolution), set the final size and press start. He don't want to demux the streams and make some calculations (video, audio, overhead). Some things that maybe can be added/fixed: - preview not working for some MKV file tested - remember last directory - set the working directory - fix the x264 enocoder settings (now is not available, is XViD instead of X264), but I think the default made by you are OK. - set another default settings like: SAP unchecked, no filters to be loaded, copy audio - delete the temporary files after closing the program. - Also at the subtitles tab you can add an option to load some external srt subtitle. If MKV conversion is possible, I think you can add another option called "NMT Compatibility", or other name for people with Popcorn, etc. This compatibility is needed at least for the bframes settings. enjoy, Mtz Last edited by Mtz; 13th March 2009 at 13:26. |
#17 | Link | |||||||||
HDConvertToX author
new full package HDConvertToX 0.1.18.363
fixed lots of bug on subs and more is now possible to edit the encoding preset, just edit the profile.txt added support for avisynth mt @Mtz Quote:
already herethe main problem is bitrate computing when copying audio Quote:
BUT i will not implemet this till program is beta Quote:
and i will add a check for enabling/disabling options BHH |
#18 | Link | |||||
Tests are on a 5 minutes sample.
At the Set Resolution cursor maybe you can add these values written under the cursor: 1920, 1280, 720. enjoy, Mtz |
#19 | Link | ||||||
HDConvertToX author
please explain step by step what are you doing also post the queue (just add encoding to queue) Quote:
anyway if you copy audio normalize is ignored Quote:
also, the default denoise level is very light. If user is concerned about denoising , can always change it Quote:
plase report your problem about xvid and preview! ![]() BHH |
#20 | Link |
Ok, step by step:
- starting the program - uncheck the SAP option - X264+MKV - Basic video settins > is showing the XviD settings. The encoding is done with X264 - load mkv file - analyze. OK - set resolution - back to video settings. still xvid. Screenshot: ![]() XviD settings after selecting X264+MKV. Also I wrote the 1920, 1280, 720 values, because I think these are the most used. Queue: Code:
"C:\Program Files\HDConvertToX\applications\eac3to.exe" "E:\HD\1080p-dts.mkv" 1:"C:\Program Files\HDConvertToX\hdconverttox.h264" "C:\Program Files\HDConvertToX\applications\DGAVCIndex.exe" -i "C:\Program Files\HDConvertToX\hdconverttox.h264" -o "C:\Program Files\HDConvertToX\movie.dga" -f 0 -e "C:\Program Files\HDConvertToX\applications\eac3to.exe" "E:\HD\1080p-dts.mkv" 2: "C:\Program Files\HDConvertToX\hdencodertoxvid-pid2.dts" "C:\Program Files\HDConvertToX\applications\x264.exe" --pass 1 --bitrate 22694 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 4 --mixed-refs --trellis 0 --ref 1 --filter -1,-1 --subme 2 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --weightb --b-adapt 2 --no-chroma-me --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --output "C:\Program Files\HDConvertToX\hdconverttox_1080p-dts.h264" "C:\Program Files\HDConvertToX\hdconverttox_1080p-dts.avs" "C:\Program Files\HDConvertToX\applications\x264.exe" --pass 2 --bitrate 22694 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 4 --mixed-refs --trellis 0 --ref 4 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 2 --no-chroma-me --8x8dct --aud --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --output "C:\Program Files\HDConvertToX\hdconverttox_1080p-dts.h264" "C:\Program Files\HDConvertToX\hdconverttox_1080p-dts.avs" "C:\Program Files\HDConvertToX\applications\mkvmerge.exe" -o "E:\HD\movie.mkv" --default-duration 0:23.976fps --aspect-ratio -1:2.4000 "C:\Program Files\HDConvertToX\hdconverttox_1080p-dts.h264" "C:\Program Files\HDConvertToX\hdencodertoxvid-pid2.dts" Mtz |
| Tags |
| hdc, hdconverttox, m2ts |
| Thread Tools | |
| Display Modes | |
