Old 24th February 2009, 18:52   #21  |  Link
Typhoon859
Banned
Originally Posted by Sagekilla View Post
All of the Spline and Lanczos resizers are very sharp. The differences between Spline16, 36, and 64 are minute. Likewise, for Lanczos(taps=0-10). There's not much comparison to be done between Spline16 and Spline36, but vs the other resizers like Bicubic, Bilinear, etc there is a worthwhile comparison to be made.
IMO:
Spline64 > Spline36 > Spline 16 > Bicubic ~= Gauss >= Bilinear
Spline >= Blackman > Lanczos
Bilinear is the softest I know of, while Gauss* has adjustable sharpness. Bicubic is sort of like Gauss except you can make it absurdly sharp and ringy, or very blurry (by adjusting b and c). IIRC, at c=0.6 or higher, Bicubic rings too much and Lanczos does better. Spline is sharp like Lanczos, but doesn't ring from what I've seen. Blackman on the other hand, I haven't used much but it seems to be very similar to Spline.
*Gauss is interesting, if you use too low of a p the image is completed blurred. Otherwise, it's like a slightly softer bicubic to me.
"Spline64 > Spline36 > Spline 16 > Bicubic ~= Gauss >= Bilinear
Spline >= Blackman > Lanczos" - That's in terms of sharpness right?
Umm, in terms of sharpness, the default for Spline and Lanczos are pretty identical.. The differences I see are how it effects minor details, especially blurry details. That's actually why I prefer Spline16 over 36/64. It seems to preserve minor details better with almost identical sharpness.
-Thanks
Typhoon859 is offline   Reply With Quote
Old 24th February 2009, 19:34   #22  |  Link
Sagekilla
x264aholic
Yes, in terms of sharpness. Spline and Lanczos are pretty much identical for all intents and purposes. The biggest difference is spline tends to ring a lot less than lanczos. Also, Spline64 should retain more fine detail than Spline16 when downscaling, and do a better job when upscaling too.
4096x2304 -> 768x432 -> 1920x1080:
Lanczos4
Spline64
Both have ringing around the pole. But the spline is more controlled. (Zooming 200% or 300% helps a bit here)
Sagekilla is offline   Reply With Quote
Old 24th February 2009, 21:17   #23  |  Link
Typhoon859
Banned
Lanczos4
Spline64
Hmmm, well actually, when I zoom in, I can see that Lanczos4 produces a bit sharper image. There's more ringing from the resize probably because of the extra sharpness. The ringing is sharpened as well XD
In the end, it just narrows down to what is your preference. Comparing such subtle differences can drive a person crazy, with your face all up in the screen, lol
Old 25th February 2009, 01:29   #24  |  Link
Seraphic-
Forum Member
How does Spline64 compare to Spline36 for upscaling (and some downscaling)?
Seraphic- is offline   Reply With Quote
Old 25th February 2009, 02:29   #25  |  Link
Typhoon859
Banned
These are upscales from 720x480 to 1280x720. Try to see the difference for yourself. What I see is that Spline64 is a bit sharper but at the same time, if you look at the roof on the bottom left corner of the picture (the one above the window), it removes a bit of details. On the top right section of that section of the roof XD Open the two pictures in two different tabs and switch between them after you maximized them. Scroll both to the bottom-left so that you can see that roof area first though. Maybe it'd be more apparent if I resized it even more.
Spline36
Spline64
Old 25th February 2009, 06:37   #26  |  Link
Sagekilla
x264aholic
Wait, did you upscale it then encode it? Because it looks like you did (and that's the wrong thing to do). Those two images should look nearly identical, but in the bottom left corner there's a lot of differences. If you're comparing resizers, don't encode. Just save the raw frame directly out of AvsP or your GUI of choice as a png.
What you just did is compare how whatever encoder handles spline36 vs spline64, not the actual sharpness.
Old 25th February 2009, 07:34   #27  |  Link
Typhoon859
Banned
Well, yeah. That's the point. I did the resize from 720x480 to 1280x720, then used the x264 codec to encode the clip @ 5000kbps. x264 is what I'm always going to use so this particular comparison I actually made for myself. I want to see how differently each one works with the codec. What's the point of testing it without the effect that the codec you're going to use has? You might get the exact opposite results in terms of what's better/worse..
Old 25th February 2009, 07:47   #28  |  Link
Sagekilla
x264aholic
You're missing my point. If you're comparing the sharpness of one resizer to another, you need to do so based on the raw output from the resizers.
What if we decided to sharpen a 720p image with two different resizers, then compressed them as jpgs @ 100 KB for both files? How could you tell that one sharpener does a better job at sharpening? In this case, it would be the one that comes out the crappiest looking, because sharp images tend to take more bits than softer images. If you keep the bitrate the same, then the sharper one is going to lose sharpness and generally turn into a horrible mess compared to the soft one, which will compress nicer.
That's fine if you want to compare it when you're encoding, but if you're talking about the properties of the resizers themselves then you shouldn't be encoding them. Plus, if you take into account sharpness/complexity determines image size, the fact that Spline64 "has less details" is completely logical when you consider you're using a fixed bitrate.
Old 25th February 2009, 08:13   #29  |  Link
Typhoon859
Banned
Wow. That made so much sense. Just from that, I feel like I know twice as much. Really, thanks. Good stuff, good stuff
Old 25th February 2009, 15:43   #30  |  Link
Sagekilla
x264aholic
I mean, if you want to compare how well a resizer does when you're encoding, you're doing it absolutely the right way. I'm just saying that for sharpness comparisons you have to be careful how you do that
Old 25th March 2009, 17:57   #31  |  Link
naughty21
Naughty boy
thanks for the info but i have a doubt that for below 720x320 which is good and for 480p and 720p which one is good
Last edited by Guest; 25th March 2009 at 21:45. Reason: rule 12: don't ask what's best!
naughty21 is offline   Reply With Quote
Old 26th March 2009, 14:09   #32  |  Link
JohannesL
AviSynth/x264 user
JohannesL's Avatar
www.sm64.org/div/Bilinear0.png
www.sm64.org/div/Spline360.png
640x480 to 320x240
Spline36 is sharper, but both look good to me.
JohannesL is offline   Reply With Quote
Old 8th April 2009, 19:56   #33  |  Link
unix_sansei
Wreaking havoc for years
unix_sansei's Avatar
why don't you try using wavelets for resizing? sometimes they ring a bit but they are fast to implement, easy up and downscaling.
unix_sansei is offline   Reply With Quote
Old 8th April 2009, 20:46   #34  |  Link
leeperry
Kid for Today
640x480 to 320x240
so whatever upscaling/downscaling, spline36 is your best option? I think that's what ffdshow is using?
w/ CoreAVC CUDA doing the decoding, I can spline anything I'd like now
mostly SD>720p and 1080p>720p
Old 9th April 2009, 05:31   #35  |  Link
*.mp4 guy
*.mp4 guy's Avatar
Unless you are using overcomplete wavelets and some sort of nonlinear coefficient filtering, the results are going to be equivelent to a FIR filter, just as lanczos/spline/etc. are equivelent to FIR filters.
*.mp4 guy is offline   Reply With Quote
Old 9th April 2009, 21:02   #36  |  Link
unix_sansei
well yes, non-linear coefficients are the way to go. you can throw a myriad of different weightings and basis functions at the image with wavelet. you can also reuse similar code for resize as well as noise reduction, deblurring etc without the high frequency filtering of DCT.
i don't particularly like them because for big images 4k x 6k they get 'lost' in the complex wilderness but for small DVD images they seem to work well.
Old 10th April 2009, 09:56   #37  |  Link
halsboss
likes to tinker
Is Spline64 available in the current MT version of avisynth (2.5.7 I think) ? Blackman ? If not, is there a plugin ?
halsboss is offline   Reply With Quote
Old 10th April 2009, 11:53   #38  |  Link
buletti
in 2.5.7 spline64 is not avaialble (also in the MT version). About blackman I'm not sure.
However, there is a modded 2.5.8 MT version now which is capable of both.
buletti is offline   Reply With Quote
Old 10th April 2009, 14:02   #39  |  Link
Betsy25
I think Spline is recommended at downsizing resolution-wise.
but Lanczos is definatelly recommended at downsizing filesize-wise.
Betsy25 is offline   Reply With Quote
Old 10th April 2009, 20:20   #40  |  Link
cogman
The Crazy Idahoan
I don't get it. Why would you upscale the image before encoding it? If it is to justify the large bitrate, well, tell the encoder to use more bits rather then throw more at the image.
Yeah, I could see it if you are targeting a specific device that doesn't support upscaling/does a crappy job at it. However, most are generally pretty good at it.
cogman is offline   Reply With Quote
