20th February 2009, 10:55 | #21 | Link | |
Avisynth language lover
With SetMTMode switched on, the MT Avisynth treats each filter in a chain distinctly, since this is handled by changes to the parser in the amended avisynth.dll. |
20th February 2009, 17:15 | #22 | Link |
Kid for Today
nice! 2.5.8 should allow mod2 in LSF, where 2.5.7 is mod4 only
but I've tried it on a few mod2 samples, and sometimes it works....but most of the time it's very slow and crashes Last edited by leeperry; 22nd February 2009 at 01:16. |
20th February 2009, 17:53 | #23 | Link | |
The Mpeg2source filter when decoding HD material doesn't like it when SetMTmode is set! It works fine set to 2 for standard definition 720x576 material though, so this may need to be taken in to consideration for other people that different resolutions may lead to different compatibility! Easiest way around this is just to set MT mode after the source filter! Last edited by burfadel; 20th February 2009 at 19:22. |
22nd February 2009, 07:15 | #25 | Link |
ZZZzzzz...
I've got the same problem with mod2 files... Oh well, 2.57 works. Does anyone know if ConvertFPS( benefits with either SetMTMode or MT( ?
Edit: I test convertfps with both MT and SetMTMode and I found no discernible difference on my system (others may differ). Last edited by lych_necross; 25th February 2009 at 07:20. |
12th March 2009, 17:29 | #26 | Link | |
Didée Fan
Go see! Edit. 2 days and nobody says how the dll I made did for them? It is different than the one seraphy made! It should do the mythical mod2 you talk about...try it out and tell us what it did? Last edited by Jeremy Duncan; 12th March 2009 at 17:33. |
13th March 2009, 07:51 | #27 | Link |
ZZZzzzz...
Hi Jeremy, I tried your version of the dll and it seems to work alright. No problems so far. I'll test it some more and report any problems. The only thing I noticed is that when you display the avisynth version in a script, it still says Seraphy (just add version() to the end of a script). You might want to alter that to reflect your additional changes.
@leeperry Does it work on your end? |
13th March 2009, 07:59 | #28 | Link | |
thanks for the dll.
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
13th March 2009, 10:30 | #29 | Link |
Kid for Today
looking good indeed!
I've got a 672x384 AVI file w 7/4 DAR(that becomes 1022*584 after resizing to 1024*768 in ffdshow), I've tried to open it like 20 times...it only crashed once(same as the old buggy DLL), basically it went really slow and crashed my player after a few secs. it also crashes a lot when I seek.. when it's mod2, it seems to stall for a few seconds before starting playback if only ffdshow could resize to 1024* when I ask it to, but it doesn't seem possible.. Last edited by leeperry; 13th March 2009 at 11:19. |
14th March 2009, 08:19 | #36 | Link | |
Didée Fan
"when it's mod2, it seems to stall for a few seconds before starting playback". if you specify the fps and then run your code under that it should be ok. See assumefps My film is 29.970 fps I think. So I use assumefps like this: ffdshow_source() MT(" assumefps(30000, 1000, false) ",2) The false is to show no audio is used in the setting. The stall is due to the avisynth dll having 64 to 32 bit conversion. I think. Last edited by Jeremy Duncan; 14th March 2009 at 08:23. |
14th March 2009, 11:36 | #38 | Link | |
Using MT here will actually slow it down instead of speeding it up - just use assumefps on its own. |
14th March 2009, 17:23 | #39 | Link | |
Didée Fan
Putting it in mt solved this problem. I made another avisynth mt dll today and put it in the first post. I included a build log so you can see it's a release and not a debug. This version had most of the convert warnings fixed. It's more stable I think after testing it with my frame doubler in ffdshow. |
14th March 2009, 19:28 | #40 | Link | |
ffdshow/AviSynth wrangler
AssumeFPS all you want - ffdshow will use the timestamps of the input frames to calculate the output frame timestamps. If your file itself has it's framerate wrong remux it with the correct framerate. np: Fink - If Only (Distance And Time)
now playing: [artist] - [track] ([album]) |
