Old 12th September 2009, 04:02   #201  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
I updated the avisynth.dll and the src. Links are in the first post.
I also updated the instructions to build the dll at the bottom of the first post.
What changed? I fixed the bug Gavino reported using the code he provided to fix the bug, and I made the name change atak snapjera requested.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity.
Jeremy Duncan is offline   Reply With Quote
Old 12th September 2009, 08:55   #202  |  Link
Gavino
Avisynth language lover
(I take it this refers to the audio cache bug.)
Thinking about the MT implications of this led me to have a look at the source code of CacheMT::GetAudio.
I see that it is the same as Avisynth 2.57 and does not include the changes made (to Cache) in Avisynth 2.58. Ironically, this also means that it does not suffer from the bug (when SetMTMode is used), but really CacheMT::GetAudio should be the same as Cache::GetAudio.
Old 12th September 2009, 17:31   #203  |  Link
Jeremy Duncan
Didée Fan
Interesting. I wonder if it would be faster if it has the 2.5.8 code in the cachemt?
I updated the dll and src links in the first post.
Old 12th September 2009, 23:08   #204  |  Link
Gavino
Most scripts would show no difference, since the audio cache only comes into play if the same section of audio is accessed more than once (eg when mixing channels).
The main reason for making them the same is for consistency and ease of future maintenance. In the longer term (Avisynth 2.6?), it might be better to derive Cache and CacheMT from a common parent class and put the audio code in that parent.
Old 29th September 2009, 02:01   #205  |  Link
thewebchat
Advanced Blogging
This is probably a dumb question, but how does AviSynth MT behave when no instances of MT or SetMTMode have been called? Is it functionally equivalent to normal AviSynth?
thewebchat is offline   Reply With Quote
Old 29th September 2009, 19:20   #206  |  Link
cweb
cweb's Avatar
I'm getting odd behaviour when I use SetMTMode before directshowsource
SetMtMode(2,2)
video=directshowsource("00003.ts").KillAudio()
My source is converted from my camera's hdvideo (50p).
If I put the SetMtMode after the directshowsource all is fine.
Otherwise I get some strange jerkiness or repeats of previous parts of the video throughout..
I will try to prepare a sample for you as soon as I can.
Mediainfo reports the following on my source ts file (not sure why it's saying NTSC, I think it should say PAL!).
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Duration : 6mn 25s
Bit rate : 13.6 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 50.000 fps
Standard : NTSC
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.296
Stream size : 626 MiB (92%)
PC specs for bug reports: Athlon 64-bit Phenom II X6 2.8Ghz Win7/Linux PCI express NVIDIA GTX 285 graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 29th September 2009, 20:11   #207  |  Link
saint-francis
too much lurking
saint-francis's Avatar
SetMtMode(2,2)
SetMTMode (2) doesn't work with DirectShowSource. That is the classic example of SetMTMode (2) and DSS. You're lucky it completed encoding. The reason you don't have the issues when you put it after DSS is because it isn't getting called. If you use SetMTMode you have to begint he script with it. You can change between modes during the script but you need to begin with it.
What you need to do is begin the script with SetMTMode (3) and after DSS is called use mode 2. I have found that mode 3 causes havoc with some other filters I usually use.
saint-francis is offline   Reply With Quote
Old 30th September 2009, 00:13   #208  |  Link
BigDid
Actually in reserve
Originally Posted by thewebchat View Post
... but how does AviSynth MT behave when no instances of MT or SetMTMode have been called? Is it functionally equivalent to normal AviSynth?
I had already verified that (with a 2.58 avisynth-mt.dll) there was nearly no difference scripting no MT or scripting with setmtmode(2).
Here is a more complete test that confirm there is no or very little speed difference between the different scripting exception being the MT() mode.
I use last SET avisynth MT 2.58 dll:
http://forum.doom9.org/showthread.ph...10#post1301410
A slow dual-core with avisynth 2.58 mono or MT dll
Script is mpeg2source+ crop+lanczosresize+
#( the Setmtmode or MT scripting is inserted here when needed)
fft3dfilter(plane=4, sigma=1, bt=4).lsfmod()
1/ 2.58 Mono-dll => 7,25 fps
2/ 2.58 MT-dll, no MT scripting => 7,19fps
3/ 2.58 MT-dll, setmtmode(2) => 7,15fps
4/ 2.58 MT-dll, MT("...") => 10,19 fps
Conclusion being: for a marginal gain, if you own a single core, stick to avisynth 2.58 mono dll. If you own a multiple core, use the 2.58 MT dll and try to get the MT() mode to work
Nota: anybody with a quad-core wanting to redo these simple tests is welcome cause mileage may vary.
Did
Edit: the conclusion applied to the question in the above post gives the following answer: don't worry with the setmtmode(2) it should not be quicker than normal scripting IF you have the avisynth 2.58 MT dll.
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first
Want to exchange on AutoGK? try doom10.org
In reserve (inactive) for an undefined period of time.
BigDid is offline   Reply With Quote
Old 1st October 2009, 02:11   #209  |  Link
aegisofrime
MT() Breaks some filters, like TGMC for example. Tried and tested on my side. For TGMC SetMTMode(2,4) on my Phenom II X4 955 along with a Distributor() at the end of the script gives me a very nice boost.
aegisofrime is offline   Reply With Quote
Old 1st October 2009, 08:25   #210  |  Link
Gavino
Originally Posted by aegisofrime View Post
... along with a Distributor() at the end of the script gives me a very nice boost.
Doesn't Distributor() get added automatically? (see here)
What effect does adding another one have?
Old 1st October 2009, 18:26   #211  |  Link
Bluedeep
Thank's for this version
Do you accept donations?
Bluedeep is offline   Reply With Quote
Old 1st October 2009, 19:11   #212  |  Link
Jeremy Duncan
Didée Fan
Your welcome.
No.
Old 3rd October 2009, 22:14   #213  |  Link
BigDid
Actually in reserve
... For TGMC SetMTMode(2,4) on my Phenom II X4 955 along with a Distributor() at the end of the script gives me a very nice boost.
Glad for you but that doesn't give any numbers for comparison!?
Did
Old 4th October 2009, 04:45   #214  |  Link
thewebchat
Advanced Blogging
To do parallel temporal processing, would it be reasonable to do something like this?
StackVertical(SelectEven,SelectOdd)
MT("filter",2,0)
Interleave(Crop(last.width,0,0,0-last.height/2),Crop(last.width,last.height/2,0,0))
Or maybe something like this?
AssumeFieldBased
Weave
MTi("filter")
SeparateFields
AssumeFrameBased
Old 6th October 2009, 12:59   #215  |  Link
Jeremy Duncan
Didée Fan
thewebchat,
I couldn't tell you since I don't use that code.
Everybody,
I have updated the src and avisynth.dll and linked to them in the first post.
Old 6th October 2009, 16:00   #216  |  Link
aegisofrime
Originally Posted by BigDid View Post
Did
My bad, wasn't keeping track of this thread.
As TGMC does take a while for the FPS numbers to more or less "settle down", I waited until 1 minute of processing to do a measurement.
Without Distributor()
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\RemoveGrainSSE3.dll")
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\RepairSSE3.dll")
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\nnedi.dll")
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\mt_masktools-25.dll")
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\mvtools2.dll")
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\MT.dll")
import("C:\Program Files (x86)\AviSynth 2.5\plugins\TGMCAlpha_3.avsi")
SetMTMode(2,4)
DGDecode_mpeg2source("F:\Raws\Test.d2v",info=3,idct=5)
TempGaussMC_Alpha3(2, 1, 1, EdiMode="NNEDI2")
FPS: 5.89
With Distributor at the end,
SetMTMode(2,4)
Distributor()
FPS: 14.1
Edit: I would like to clarify that the above results are with the pre-rendering job on MeGUI. Interestingly, if encoded with x264 @ CRF21 (that is, pre-rendering mode turned off), the speed difference shrinks to around 7 FPS for non-distributor and 7.5 FPS for Distributor O.o
I believe this is due to x264 actually being a bottleneck... Before anyone asks, the reason why I use pre-rendering is that I have noticed some filters require it. FFT3DGPU gives me crap when I do a TGMC 1 pass encode...
Old 6th October 2009, 19:22   #217  |  Link
Gavino
October 6, 2009
I updated some files in the src, core folder. I got the new ones from SEt's 2.6 src. I read the bug fix he made in that 2.6 thread of his today and so decided to make a new dll with the fix and thought it would be cool to include other mt files from his src so I did.
I forget which ones though.
Do you realise how lame that sounds?
Don't you understand the importance of software configuration management to a project like this?
Old 6th October 2009, 19:26   #218  |  Link
If you followed this thread from the beginning you would know the answer to that question.
Old 7th October 2009, 01:38   #219  |  Link
Jeremy Duncan
Didée Fan
I know which files but I didn't want to be specific and say certain ones.
Here is the list I made in this link:
core folder
avisynth_c.cpp
cache.cpp
cachemt.cpp
main.cpp
mt.cpp
mt.h
softwire_helpers.cpp
I know it's not softwirehelpers. I think I tried main but that didn't work. One of the mt, I think mt.cpp didn't work. And I think avisynth_c didn't work either.
That leaves cache, cachemt and one of the mt files I ported from the 2.6 src to my 2.5.8 build.
The cachemt didn't work so I had to splice the new code into my old code and so it's a mix.
Old 20th October 2009, 00:08   #220  |  Link
Arshad07
Jeremy Duncan Fan
Arshad07's Avatar
I'm getting an error while using MT although i've got c++ installed;
Error :
this application has requested the Runtime to terminate it in an unusual way
Please contact the applications support team for more information
Arshad07 is offline   Reply With Quote
