Old 18th March 2009, 09:02   #121  |  Link
Mike Chen
Originally Posted by evdberg View Post
Hi Mike,
I am a bit confused. MakeMKV complains that it can't read the VID from the disc (just like cddump), but there is no way to provide the VID to MakeMKV to read from the original disc?
It should be able to read VID automatically. Does it give any specific error messages? Please enable "show debug messages" in preferences,restart the program, and try to open disc.
Mike Chen is offline   Reply With Quote
Old 18th March 2009, 13:25   #122  |  Link
evdberg
@Mike,
Did as you asked, and this is the result:
FAILURE: Code 2 at rIS~%I$w}N4L5D]`*:121262095
FAILURE: Code 0 at 2cCq8J8*@Y!@}90<U[:213129823
FAILURE: Code 1 at 2cCq8J8*@Y!@}90<U[:213129823
FAILURE: Code 2 at 2cCq8J8*@Y!@}90<U[:213129823
FAILURE: Code 3 at 2cCq8J8*@Y!@}90<U[:213129823
FAILURE: Code 4 at 2cCq8J8*@Y!@}90<U[:213129823
Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
The volume key is unknown for this disc - video can't be decrypted
FAILURE: Code 0 at 4NOxj\Jn:o# i2qL:121262141
FAILURE: Code 0 at 4NOxj\Jn:o# i2qL:121262440
Failed to open disc
evdberg is offline   Reply With Quote
Old 18th March 2009, 13:47   #123  |  Link
loo3aem3ON
His drive is patched so it will send the volume id even if authentication failed (e.g. due to revocation). Simply ask for the volume id regardless if the authentication was successful or not. Don't invalidate the AGID before that.
loo3aem3ON is offline   Reply With Quote
Old 18th March 2009, 18:35   #124  |  Link
Mtz
Mtz's Avatar
The latest version 797 of MakeMKV is freezing my PC when I want to set the source. With older versions, no problem.
WindowsXP.
enjoy,
Mtz
Mtz is offline   Reply With Quote
Old 18th March 2009, 20:32   #125  |  Link
setarip_old
setarip_old's Avatar
@Mtz
Is this what you're talking about?
With Build 797, the initial analysis period APPEARS to be stalled, but look at the timers of both bars. After from 45 seconds to 1 minute, the blocks on the two bars start accumulating - and then the rest of the analysis goes more quickly than earlier version.
On previous versions, the blocks started accumulating almost immediately...
setarip_old is offline   Reply With Quote
Old 18th March 2009, 22:29   #126  |  Link
Mtz
Mtz's Avatar
Even only closing the program and no other thing done will freeze my PC.
enjoy,
Mtz
Old 18th March 2009, 22:40   #127  |  Link
setarip_old
@Mtz
I can only tell you that I've encountered no such problem running this version (1.03B797) on a system running XP SP3...
Have you tried it with several different discs, or only one?
Old 19th March 2009, 01:20   #128  |  Link
setarip_old
@Mike Chen
Hi!
I'm pleased to let you know that v.1.03 Build 797 now appears to properly process BluRay discs containing VC-1 video ;>}
Old 30th March 2009, 16:22   #129  |  Link
Mtz
Mtz's Avatar
Also the problem is with the 778 version. The latest working is 722.
This is the ONLY program installed on my PC with this problem. And I have many installed. Also I have XP SP3.
enjoy,
Mtz
Old 30th March 2009, 22:24   #130  |  Link
loo3aem3ON
Doesn't Windows have some kind of logfile which could tell you what happend (e.g. kernel panic)?
Old 30th March 2009, 23:23   #131  |  Link
Mtz
Mtz's Avatar
I can only power off the PC from the button.
enjoy,
Mtz
Old 31st March 2009, 08:45   #132  |  Link
Mike Chen
enjoy,
Mtz
I wonder if this is a drive problem. Can you try the following - to disable your dvd drive in device manager, start makemkv and see if it will freeze the pc or not. What is your drive model?
Old 31st March 2009, 09:42   #133  |  Link
lchiu7
Well I encountered a disc with VC1 video and makemkv created a file that is not playable. It seemed to decode the title okay and create a mkv file but when I try to play it on a Popcorn Hour, it's jerky.
The file seems to be broken. Tried to re-encode the file to something smaller using megui (which calls x264) and x264 just hangs. mkvtoolnix can't demux the VC1 video either.
lchiu7 is offline   Reply With Quote
Old 31st March 2009, 09:45   #134  |  Link
Mtz
Mtz's Avatar
Drive Information
Manufacturer: HL-DT-ST
Product: DVDRAM GSA-H10N
Revision: JL11
Firmware date: 2006-05-19 12:34:56
Daemon Tools (with 4 virtual drives)
Virtual Clone Drive
MakeMKV Version 797
First I disabled the dvd drive. The freezing come after about 1 minute. Then I was trying to reduce the numbers of daemon virtual drives. That seems to work for another few minutes.
Installing 772, enabling again the LG DVD Drive. Things work correct.
Installing again 797, disabling LG, and now MakeMKV even can't start and this is the error:
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="makemkvcon.exe" FILTER="GRABMI_FILTER_PRIVACY">
    <MATCHING_FILE NAME="cddump.exe" SIZE="155648" CHECKSUM="0xE892A789" MODULE_TYPE="WIN32" PE_CHECKSUM="0x273BA" LINKER_VERSION="0x0" LINK_DATE="03/17/2009 02:15:29" UPTO_LINK_DATE="03/17/2009 02:15:29" />
    <MATCHING_FILE NAME="driveio.dll" SIZE="18432" CHECKSUM="0xF1D9A5CC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x10D61" LINKER_VERSION="0x0" LINK_DATE="02/13/2009 08:58:43" UPTO_LINK_DATE="02/13/2009 08:58:43" />
    <MATCHING_FILE NAME="libdriveio.dll" SIZE="18432" CHECKSUM="0x825DE218" MODULE_TYPE="WIN32" PE_CHECKSUM="0x108E9" LINKER_VERSION="0x0" LINK_DATE="03/17/2009 02:10:40" UPTO_LINK_DATE="03/17/2009 02:10:40" />
    <MATCHING_FILE NAME="libmakemkv.dll" SIZE="183296" CHECKSUM="0x127AA2BB" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2D435" LINKER_VERSION="0x0" LINK_DATE="03/17/2009 02:10:46" UPTO_LINK_DATE="03/17/2009 02:10:46" />
    <MATCHING_FILE NAME="makemkv.exe" SIZE="3549184" CHECKSUM="0x876954AC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x36F14F" LINKER_VERSION="0x0" LINK_DATE="03/17/2009 02:18:51" UPTO_LINK_DATE="03/17/2009 02:18:51" />
    <MATCHING_FILE NAME="makemkvcon.exe" SIZE="2880000" CHECKSUM="0xC91462D4" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2CECDB" LINKER_VERSION="0x0" LINK_DATE="03/17/2009 02:16:38" UPTO_LINK_DATE="03/17/2009 02:16:38" />
    <MATCHING_FILE NAME="mkvdll.dll" SIZE="183808" CHECKSUM="0x410FE53D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x2E9DE" LINKER_VERSION="0x0" LINK_DATE="02/13/2009 08:58:49" UPTO_LINK_DATE="02/13/2009 08:58:49" />
    <MATCHING_FILE NAME="uninst.exe" SIZE="65302" CHECKSUM="0xAB0678E0" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="05/03/2008 14:08:42" UPTO_LINK_DATE="05/03/2008 14:08:42" />
</EXE>
<EXE NAME="libdriveio.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
    <MATCHING_FILE NAME="kernel32.dll" SIZE="989696" CHECKSUM="0x7D737C09" BIN_FILE_VERSION="5.1.2600.5512" BIN_PRODUCT_VERSION="5.1.2600.5512" PRODUCT_VERSION="5.1.2600.5512" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.5512 (xpsp.080413-2111)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF44A2" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.5512" UPTO_BIN_PRODUCT_VERSION="5.1.2600.5512" LINK_DATE="04/14/2008 00:11:24" UPTO_LINK_DATE="04/14/2008 00:11:24" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
The last setup was Virtual Clone Drive and 2 devices from Daemon.
enjoy,
Mtz
Old 31st March 2009, 12:50   #135  |  Link
loo3aem3ON
Drive Information
Revision: JL11
Is this drive executing the original firmware? Your manufacturer string looks like a LG drive in safe mode.
Old 31st March 2009, 14:19   #136  |  Link
Inspector.Gadget
Are you using ffdshow to decode VC1? Don't. Use the WMVideo Decoder DMO.
Inspector.Gadget is offline   Reply With Quote
Old 31st March 2009, 14:56   #137  |  Link
Mtz
Mtz's Avatar
If a DVD is working with all programs except 2 versions of one program, I think is not the DVD fault.
enjoy,
Mtz
Old 31st March 2009, 21:08   #138  |  Link
lchiu7
No - I am trying to play on a Popcorn Hour.
I tried all kinds of strategies to fix the file. In the end passed the file from makemkv through Handbrake and re-encoded the video at a lower bit rate and now it plays fine.
But I know it's not a bit rate issue since I have put full BD titles on a HD with no compression and the Popcorn plays them fine from a USB drive. I think it's a problem with Makemkv and VC1 video
Old 1st April 2009, 00:03   #139  |  Link
setarip_old
@lchiu7
What's the title of this disc? (Is it BluRay or HD-DVD?)
Old 1st April 2009, 01:16   #140  |  Link
lchiu7
Originally Posted by setarip_old View Post
@lchiu7What's the title of this disc? (Is it BluRay or HD-DVD?)
BR - Body of Lies (region B)
But once I ran the file through handbrake and configured it to be 720P and a lower bitrate, it played fine.
I don't use makemkv much (don't like the fact that it produces an output format that is not that flexible) so I can't comment much on whether this is a one off or normal behaviour for VC1 video
