Old 9th January 2009, 17:32   #1  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Simple x264/x265 Launcher v3.01 (2020-12-08)
This application is a lightweight GUI front-end for the x264 H.264/AVC
as well as the x265 H.265/HEVC encoder, based on the Qt toolkit.
Some key features of the Simple x264/x265 Launcher software include:
* Support for creating H.264/AVC (x264) and H.265/HEVC (x265) files
* Fully self-contained, *no* additional Codecs or Plugin's are required
* 64-Bit as well as 32-Bit encoder binaries are fully supported
* Optionally the "high bit-depth" encoder variants can be selected
* Batch encoding (job control) support is implemented
* If desired, multiple encoding jobs can be executed concurrently
* Adding new jobs via command-line interface is supported
* Input from the Avisynth *and* VapurSynth frame servers is supported
* 32-Bit Avisynth/VapourSynth can be mixed with 64-Bit x264/x265
* Straightforward encoder setup thanks to the Preset and Tuning system
* Custom encoder parameters can be added, if desired
* Easily manage your encoder configurations with user-defined templates
* Consistent "look & feel" on all systems thanks to the Qt toolkit
System Requirements:
* Windows Vista with Service Pack 2 or any later Windows system
* 64-Bit Windows is highly recommended (32-Bit Windows works as well)
* The CPU must support at least the MMX and SSE instruction sets
* Avisynth input only available with Avisynth 2.5+ installed
* VapourSynth input only available with VapourSynth R19+ installed
* YV16/YV24 color spaces require Avisynth 2.6 (see section 10)
Simple x264 Launcher is 100% standalone, i.e. it does *not* require
Mircrosoft.NET, Java Runtime Environment or other dependencies.
The required Qt DLLs and encoder binaries are included in the setup.
Download the latest version here:
See also:
Note: Occasionally your Antivirus program may mistakenly detect "malware" (virus, trojan, worm, etc.) in some of the files here.
This is called a "false-positive" and the files are actually innocent (clean). It's a failure in your specific Antivirus software.
In case you encounter such problems, go to http://www.virustotal.com/ and check the file again with multiple Antivirus engines!
And take care with results like "suspicious", "generic" or "packed". Those are *not* real hits, they are just wild speculation...
Old 9th January 2009, 18:40   #2  |  Link
LoRd_MuldeR
Software Developer
352x288 with "slow" settings on WindowsXP x64-Edition:
Source: C:\TEMP\x264\sample.avs
Params: --crf 22 --subme 9 --me umh --bframes 4 --b-adapt 2 --b-pyramid --direct auto --ref 6 --mixed-refs --trellis 2 --weightb --8x8dct
[Mode: 32-Bit, Pipe Buffer: 0 MByte]
encoded 2262 frames, 49.21 fps, 463.48 kb/s
encoded 2262 frames, 49.48 fps, 463.48 kb/s
encoded 2262 frames, 49.43 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 0 MByte]
encoded 2262 frames, 56.84 fps, 463.48 kb/s
encoded 2262 frames, 56.31 fps, 463.48 kb/s
encoded 2262 frames, 56.97 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 1 MByte]
encoded 2262 frames, 55.11 fps, 463.48 kb/s
encoded 2262 frames, 56.88 fps, 463.48 kb/s
encoded 2262 frames, 55.23 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 2 MByte]
encoded 2262 frames, 55.89 fps, 463.48 kb/s
encoded 2262 frames, 47.14 fps, 463.48 kb/s
encoded 2262 frames, 55.85 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 4 MByte]
encoded 2262 frames, 56.91 fps, 463.48 kb/s
encoded 2262 frames, 56.15 fps, 463.48 kb/s
encoded 2262 frames, 56.93 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 8 MByte]
encoded 2262 frames, 56.53 fps, 463.48 kb/s
encoded 2262 frames, 56.50 fps, 463.48 kb/s
encoded 2262 frames, 56.05 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 16 MByte]
encoded 2262 frames, 55.59 fps, 463.48 kb/s
encoded 2262 frames, 56.22 fps, 463.48 kb/s
encoded 2262 frames, 55.62 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 32 MByte]
encoded 2262 frames, 54.38 fps, 463.48 kb/s
encoded 2262 frames, 51.74 fps, 463.48 kb/s
encoded 2262 frames, 54.73 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 64 MByte]
encoded 2262 frames, 51.80 fps, 463.48 kb/s
encoded 2262 frames, 51.59 fps, 463.48 kb/s
encoded 2262 frames, 51.37 fps, 463.48 kb/s
[Mode: 64-Bit, Pipe Buffer: 128 MByte]
encoded 2262 frames, 45.06 fps, 463.48 kb/s
encoded 2262 frames, 45.00 fps, 463.48 kb/s
encoded 2262 frames, 45.18 fps, 463.48 kb/s
352x288 with "fast" settings on WindowsXP x64-Edition:
Params: --crf 22 --subme 2 --me hex --analyse none
encoded 2262 frames, 373.14 fps, 542.81 kb/s
encoded 2262 frames, 386.07 fps, 542.81 kb/s
encoded 2262 frames, 392.37 fps, 542.81 kb/s
encoded 2262 frames, 362.85 fps, 542.82 kb/s
encoded 2262 frames, 357.46 fps, 542.82 kb/s
encoded 2262 frames, 358.31 fps, 542.82 kb/s
encoded 2262 frames, 403.21 fps, 542.82 kb/s
encoded 2262 frames, 396.63 fps, 542.82 kb/s
encoded 2262 frames, 374.07 fps, 542.82 kb/s
encoded 2262 frames, 378.96 fps, 542.82 kb/s
encoded 2262 frames, 386.01 fps, 542.82 kb/s
encoded 2262 frames, 391.21 fps, 542.82 kb/s
encoded 2262 frames, 370.27 fps, 542.82 kb/s
encoded 2262 frames, 389.19 fps, 542.82 kb/s
encoded 2262 frames, 370.21 fps, 542.82 kb/s
encoded 2262 frames, 323.84 fps, 542.82 kb/s
encoded 2262 frames, 328.25 fps, 542.82 kb/s
encoded 2262 frames, 331.28 fps, 542.82 kb/s
encoded 2262 frames, 300.32 fps, 542.82 kb/s
encoded 2262 frames, 355.66 fps, 542.82 kb/s
encoded 2262 frames, 378.01 fps, 542.82 kb/s
encoded 2262 frames, 329.02 fps, 542.82 kb/s
encoded 2262 frames, 368.34 fps, 542.82 kb/s
encoded 2262 frames, 334.37 fps, 542.82 kb/s
encoded 2262 frames, 393.39 fps, 542.82 kb/s
encoded 2262 frames, 316.81 fps, 542.82 kb/s
encoded 2262 frames, 330.56 fps, 542.82 kb/s
encoded 2262 frames, 394.49 fps, 542.82 kb/s
encoded 2262 frames, 328.30 fps, 542.82 kb/s
encoded 2262 frames, 312.00 fps, 542.82 kb/s
Seems bigger pipe buffer doesn't help much here. Default value (0 MByte) aka "let Windows choose" already gives good results
Maybe 1 MB or 2 MB may be a good choice ???
Old 9th January 2009, 19:15   #3  |  Link
Fishman0919
FishmanMod Android Dev
Fishman0919's Avatar
loadplugin("DGAVCDecode.dll")
AVCSource("file.dga")
Spline64Resize(1280,720)
trim(0, 3500)
ConvertToYV12()
First 3501 frames from Journey to the Center of the Earth (2008)
BluRay 1080p
Vista 64
Source: C:\Temp\test.avs
Params: --crf 22
encoded 3501 frames, 30.45 fps, 2896.24 kb/s
encoded 3501 frames, 31.07 fps, 2896.24 kb/s
encoded 3501 frames, 31.15 fps, 2896.24 kb/s
encoded 3501 frames, 31.61 fps, 2896.23 kb/s
encoded 3501 frames, 31.96 fps, 2896.23 kb/s
encoded 3501 frames, 31.98 fps, 2896.23 kb/s
encoded 3501 frames, 32.22 fps, 2896.23 kb/s
encoded 3501 frames, 32.27 fps, 2896.23 kb/s
encoded 3501 frames, 31.88 fps, 2896.23 kb/s
encoded 3501 frames, 32.26 fps, 2896.23 kb/s
encoded 3501 frames, 32.24 fps, 2896.23 kb/s
encoded 3501 frames, 31.71 fps, 2896.23 kb/s
encoded 3501 frames, 31.83 fps, 2896.23 kb/s
encoded 3501 frames, 32.03 fps, 2896.23 kb/s
encoded 3501 frames, 32.14 fps, 2896.23 kb/s
encoded 3501 frames, 32.05 fps, 2896.23 kb/s
encoded 3501 frames, 31.56 fps, 2896.23 kb/s
encoded 3501 frames, 30.77 fps, 2896.23 kb/s
encoded 3501 frames, 31.13 fps, 2896.23 kb/s
encoded 3501 frames, 29.90 fps, 2896.23 kb/s
encoded 3501 frames, 29.98 fps, 2896.23 kb/s
encoded 3501 frames, 29.97 fps, 2896.23 kb/s
encoded 3501 frames, 27.69 fps, 2896.23 kb/s
encoded 3501 frames, 27.80 fps, 2896.23 kb/s
encoded 3501 frames, 27.65 fps, 2896.23 kb/s
Params: --crf 22 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-pyramid --keyint 24 --min-keyint 2 --direct auto --b-adapt 2 --subme 7 --trellis 2 --partitions all --8x8dct --me umh --merange 24 --no-fast-pskip
encoded 3501 frames, 13.99 fps, 3174.75 kb/s
encoded 3501 frames, 14.05 fps, 3174.75 kb/s
encoded 3501 frames, 14.03 fps, 3174.75 kb/s
encoded 3501 frames, 15.15 fps, 3174.75 kb/s
encoded 3501 frames, 15.22 fps, 3174.75 kb/s
encoded 3501 frames, 15.21 fps, 3174.75 kb/s
encoded 3501 frames, 15.26 fps, 3174.75 kb/s
encoded 3501 frames, 15.27 fps, 3174.75 kb/s
encoded 3501 frames, 15.29 fps, 3174.75 kb/s
encoded 3501 frames, 15.25 fps, 3174.75 kb/s
encoded 3501 frames, 15.24 fps, 3174.75 kb/s
encoded 3501 frames, 15.17 fps, 3174.75 kb/s
encoded 3501 frames, 15.20 fps, 3174.75 kb/s
encoded 3501 frames, 15.07 fps, 3174.75 kb/s
encoded 3501 frames, 15.08 fps, 3174.75 kb/s
encoded 3501 frames, 15.09 fps, 3174.75 kb/s
encoded 3501 frames, 14.68 fps, 3174.75 kb/s
encoded 3501 frames, 14.64 fps, 3174.75 kb/s
encoded 3501 frames, 14.70 fps, 3174.75 kb/s
encoded 3501 frames, 14.37 fps, 3174.75 kb/s
encoded 3501 frames, 14.33 fps, 3174.75 kb/s
encoded 3501 frames, 14.32 fps, 3174.75 kb/s
"Cinderella story. Outta nowhere.
A former greenskeeper, now,
about to become the Masters champion.
It looks like a mirac…
It's in the hole! It's in the hole! It's in the hole!"
Fishman0919 is offline   Reply With Quote
Old 9th January 2009, 23:37   #4  |  Link
turbojet
X2 3800+ at 2.5 ghz, Vista 64
CoreAVC feeding a 1920x1080 stream, just directshowsource in avs.
Params: --crf 22
encoded 1377 frames, 4.10 fps, 9437.87 kb/s
encoded 1377 frames, 3.78 fps, 9437.87 kb/s
encoded 1377 frames, 3.89 fps, 9437.87 kb/s
encoded 1377 frames, 4.06 fps, 9437.88 kb/s
encoded 1377 frames, 4.08 fps, 9437.88 kb/s
encoded 1377 frames, 4.14 fps, 9437.88 kb/s
encoded 1377 frames, 4.12 fps, 9437.88 kb/s
encoded 1377 frames, 4.10 fps, 9437.88 kb/s
encoded 1377 frames, 4.22 fps, 9437.88 kb/s
encoded 1377 frames, 4.30 fps, 9437.88 kb/s
encoded 1377 frames, 3.47 fps, 9437.88 kb/s
encoded 1377 frames, 3.48 fps, 9437.88 kb/s
encoded 1377 frames, 4.48 fps, 9437.88 kb/s
encoded 1377 frames, 4.40 fps, 9437.88 kb/s
encoded 1377 frames, 4.15 fps, 9437.88 kb/s
encoded 1377 frames, 4.17 fps, 9437.88 kb/s
encoded 1377 frames, 4.11 fps, 9437.88 kb/s
encoded 1377 frames, 4.07 fps, 9437.88 kb/s
encoded 1377 frames, 4.34 fps, 9437.88 kb/s
encoded 1377 frames, 4.23 fps, 9437.88 kb/s
encoded 1377 frames, 4.18 fps, 9437.88 kb/s
encoded 1377 frames, 3.90 fps, 9437.88 kb/s
encoded 1377 frames, 3.93 fps, 9437.88 kb/s
encoded 1377 frames, 3.97 fps, 9437.88 kb/s
Thanks for your launcher app btw, I've been getting some good use out of it.
If your intention is to go beyond 32 vs 64 bit and do a good benchmark from different cpus, might I make a suggestion to make a more accurate test? That's include a small 1080p m2ts, dgavcdecode.dll, .dga and 2 avs for 720p and 1080p, and have a 'fast' encode setting and 'normal' encode setting both as a part of the benchmark.
Old 10th January 2009, 02:11   #5  |  Link
LoRd_MuldeR
Software Developer
My intention is mainly to find out whether the 64-Bit version (using piped input) is truly faster than the 32-Bit version (using native AVS input).
Also I try to find out whether any user-defined buffer size can give a benefit over the default buffer size (aka "let Windows decide").
Old 10th January 2009, 03:35   #6  |  Link
RunningSkittle
Skittle
RunningSkittle's Avatar
DGDecode_mpeg2source("D:\dvdrips\totoro\VTS_07_VOBID_009_CELLID_001_1.d2v")
tfm(order=1).tdecimate(mode=1)
crop( 8, 6, -6, -14)
LanczosResize(720,384)
Q6600@ 3.0ghz
Vista X64
4gb DDRII 800
Short clip from R1 Totoro:
Source: D:\dvdrips\totoro\VTS_07_VOBID_009_CELLID_001_1.avs
Params: --crf 18 --ref 5 --mixed-refs --bframes 3 --b-adapt 2 --b-pyramid --weightb --deblock -1:-1 --trellis 2 --partitions all  --8x8dct --me umh --aud
encoded 437 frames, 21.55 fps, 1792.72 kb/s
encoded 437 frames, 21.60 fps, 1792.72 kb/s
encoded 437 frames, 21.68 fps, 1792.72 kb/s
encoded 437 frames, 24.09 fps, 1792.72 kb/s
encoded 437 frames, 23.86 fps, 1792.72 kb/s
encoded 437 frames, 23.92 fps, 1792.72 kb/s
encoded 437 frames, 24.29 fps, 1792.72 kb/s
encoded 437 frames, 24.15 fps, 1792.72 kb/s
encoded 437 frames, 24.17 fps, 1792.72 kb/s
encoded 437 frames, 24.02 fps, 1792.72 kb/s
encoded 437 frames, 23.98 fps, 1792.72 kb/s
encoded 437 frames, 23.90 fps, 1792.72 kb/s
encoded 437 frames, 23.53 fps, 1792.72 kb/s
encoded 437 frames, 23.37 fps, 1792.72 kb/s
encoded 437 frames, 23.60 fps, 1792.72 kb/s
encoded 437 frames, 23.38 fps, 1792.72 kb/s
encoded 437 frames, 23.83 fps, 1792.72 kb/s
encoded 437 frames, 23.89 fps, 1792.72 kb/s
encoded 437 frames, 23.47 fps, 1792.72 kb/s
encoded 437 frames, 23.74 fps, 1792.72 kb/s
encoded 437 frames, 23.58 fps, 1792.72 kb/s
encoded 437 frames, 23.12 fps, 1792.72 kb/s
encoded 437 frames, 22.65 fps, 1792.72 kb/s
encoded 437 frames, 22.50 fps, 1792.72 kb/s
encoded 437 frames, 22.57 fps, 1792.72 kb/s
encoded 437 frames, 23.23 fps, 1792.72 kb/s
encoded 437 frames, 23.04 fps, 1792.72 kb/s
RunningSkittle is offline   Reply With Quote
Old 10th January 2009, 14:50   #7  |  Link
RunningSkittle
Skittle
avcsource()
trim(0,999)
First 1000 frames from Dead space. 1080p.
encoded 1000 frames, 3.26 fps, 17443.48 kb/s
encoded 1000 frames, 3.28 fps, 17443.48 kb/s
encoded 1000 frames, 3.58 fps, 17443.48 kb/s
encoded 1000 frames, 3.50 fps, 17443.48 kb/s
encoded 1000 frames, 3.47 fps, 17443.48 kb/s
encoded 1000 frames, 3.49 fps, 17443.48 kb/s
encoded 1000 frames, 3.52 fps, 17443.48 kb/s
encoded 1000 frames, 3.51 fps, 17443.48 kb/s
encoded 1000 frames, 3.63 fps, 17443.48 kb/s
encoded 1000 frames, 3.64 fps, 17443.48 kb/s
encoded 1000 frames, 3.62 fps, 17443.48 kb/s
encoded 1000 frames, 3.45 fps, 17443.48 kb/s
encoded 1000 frames, 3.60 fps, 17443.48 kb/s
encoded 1000 frames, 3.57 fps, 17443.48 kb/s
Old 10th January 2009, 15:12   #8  |  Link
roozhou
Once I have 64-bit Windows installed, i will try to add directshow input support, which is already done in win32, to 64-bit x264.
Unfortunately i cannot run your test coz i don't have 64-bit Windows installed at present.
roozhou is offline   Reply With Quote
Old 10th January 2009, 16:02   #9  |  Link
LoRd_MuldeR
Software Developer
That certainly would be an interesting option, but we'd still need to use 64-Bit DirectShow filters and 64-Bit Avisynth. So it may be good for certain purposes (use DirectShow input, have a suitable DirectShow 64-bit Decoder available and don't need Avisynth), but it doesn't solve the basic problem - the lack of 32-Bit Avisynth input. Therefore it's not hard to predict that the pipe method will be around for quite some time...
Old 10th January 2009, 23:07   #10  |  Link
roozhou
Most of avisynth plugins are open source. Try to make them compile for 64-bit. If it fails, just drop it.
P.S. ffdshow's built-in filters are awesome. Resizer in ffdshow runs 50%~100% faster than avisynth's.
Old 10th January 2009, 23:09   #11  |  Link
LoRd_MuldeR
Software Developer
Good luck with that
Old 10th January 2009, 23:10   #12  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
it looks like 4mb buffer works well
Old 10th January 2009, 23:13   #13  |  Link
LoRd_MuldeR
Software Developer
Agreed. More than 4 MB seems to be no good. Also "slow" settings seem to profit from 64-Bit more than "fast" settings.
Old 10th January 2009, 23:17   #14  |  Link
Atak_Snajpera
I'm not surprised
Old 17th January 2009, 10:09   #15  |  Link
turbojet
Do you plan on adding a queue system to the launcher?
If you did add a queue system I'd use it regularly, at the speeds I run at every little bit of speed helps.
I'm not aware of any gui with x64 264 support and a queue system. So I might not be the only one wanting something like this.
I like the simple ui, one thing I do wish I could do is delete saved command lines I don't want to keep. Would that be possible as well?
Also is there a way to define buffer in the command line?
Old 20th January 2009, 11:35   #16  |  Link
vucloutr
vucloutr's Avatar
here with some really slow settings, OS: Server 2008 x64, CPU: Q6600@3GHz
Source: D:\x264launcher\720p.avs
Params: --keyint 240 --min-keyint 24 --bframes 4 --b-adapt 2 --b-pyramid --ref 9 --deblock -3,-2 --crf 19
--ipratio 1.4 --pbratio 1.0 --aq-strength 0.8 --direct auto --weightb --me esa --merange 24 --subme 9
--mixed-refs --8x8dct --no-fast-pskip --no-dct-decimate --deadzone-intra 9 --deadzone-inter 5
--no-psnr --no-ssim --thread-input
encoded 334 frames, 2.50 fps, 10648.77 kb/s
encoded 334 frames, 2.49 fps, 10648.77 kb/s
encoded 334 frames, 2.68 fps, 10648.77 kb/s
encoded 334 frames, 2.67 fps, 10648.77 kb/s
encoded 334 frames, 2.69 fps, 10648.77 kb/s
encoded 334 frames, 2.70 fps, 10648.77 kb/s
encoded 334 frames, 2.66 fps, 10648.77 kb/s
vucloutr is offline   Reply With Quote
Old 21st January 2009, 00:50   #17  |  Link
LoRd_MuldeR
Software Developer
Not planned.
Think 64-Bit support will be added to RipBot264, if not done already.
Edit the INI file
Yes. In the commandline for pipebuf.exe
PipeBuffer by LoRd_MuldeR <mulder2@gmx.de>, Version 1.03
Usage:
  pipebuf.exe <program_out> [<args>] : <program_in> [<args>] : [<buffer_size>]
Options:
  <program_out>  Executable to read stdout from
  <program_in>   Executable to write stdin to
  <args>         Optional command-line arguments
  <buffer_size>  Pipe buffer in MByte [0]
Old 24th January 2009, 04:47   #18  |  Link
LoRd_MuldeR
Software Developer
Updated x264 binaries to r1088 (built by Skystrife) and set default buffer size to 4 MB, as that seems to perform best
Old 27th January 2009, 18:37   #19  |  Link
turbojet
Pity you don't plan on adding a little queue. Do you mind if I have someone try to add one?
Good news about RipBot264 getting x64 support. It's a gui I use every once in awhile.
Where is the .ini file for the launcher?
Thanks for the pipebuf info.
Old 27th January 2009, 18:42   #20  |  Link
LoRd_MuldeR
Software Developer
The sources are attached, available for anybody who thinks they can be helpful
So if anybody feels like implementing a queue, have your fun
